MRLite LD2
9 posts / 0 new
aurum
Last seen: 2 years 2 months ago
MRLite LD2
hi
I need some support. I don't really understand the user interface Sad
Manual: http://www.mrlite.com/ADMIN/EDITOR/UploadFile/instruction.PDF
There is a normal and a professional mode. But I'm not able to reach the professional mode. If I turn the light off and on in the low setting the Flashlight remains in the normal mode.
thanks
Don
Don's picture
Last seen: 10 months 3 weeks ago
This seems to be the standard Mr.Lite interface.
My LT3 comes on in high, then if you switch levels to medium and then low, then turn off the light then switch it on again quickly you will get all the modes.
Hope that helps.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
aurum
Doesn't work for me Sad My Ld2 comes on in high. If i switch to low, then turn the light off and switch it on again it's still in nomal mode (strobe). I'll try to upload a Video.
Thanks
jekostas
Last seen: 9 years 10 months ago
Great... the standard Mr Lite instruction sheet.
This is a picture that someone on CPF made up, hopefully it makes more sense to you:
Mr Lite
When you turn it "off" at level 2, keep it off for at least 2 seconds.  That's the only advice I can give you.
aurum
I think I've received a bad one ... Doesn't work. I'll have to try to contact Lighttake.
sixty545
Give it another try. I followed the scheme in post #3 and thought that I was still in the upper row.
In fact I was in the lower row, but the levels #2, #3, #4 and High are not much different so I thought that it was just bad switching, the same thing with the two SOS. You have to switch off/on rather quick in the lower row.
The term "standby" I do not understand, it is obvious to me that it is a Beacon mode that flashes every 8 sec's.
aurum
The light died two min. ago ^^ Now I'm not able to switch it on. I'll have to ask Lighttake for replacement.
jekostas
That sounds like a dead battery.  I was unable to switch modes when the battery in my KC-05 died.
aurum
I've tryed several batterys. Still nothing Wink I've contacted Lightake.
