I opened a new bag of the ten for 5 bucks DX keychain lights to replace the one on my keyring. Nine of the ten were just as bad as the old one currently on my key ring. Since I got the bag at least a year ago I figured the batteries had gone bad. Nope. There was no difference in battery voltage between the good one and the bad one. Then I cleaned the led leads with an eraser thinking they had oxidized and didn’t have good contact. Same result. Any ideas on what’s going on here?
Aaahhh, have seen them before Thanks for the link.
Well, plastic “switch”, cell and emitter. If something is wrong - clean contacts If still nothing - dead cell. Dunno you have dead LEDs :~
Even if the voltage is the same, you should try the good one’s cells in the bad one . If it’s still dim, then apparently you got high Vf leds. Bad luck.
Cool, thanks for idea!
Im ordering bunch of green, red, uv and ir 5mm leds and bunch of those 5mm button lights and will replace leds and use them in the field with red/green/uv :)!
Thanks again for the obvious tip!
