Fandyfire STL-V6( skyray thrower clone) substitute for only $26?
22 posts / 0 new
yclongthrow
Last seen: 15 hours 57 min ago
Hello,
I tried dedoming my fandyfire stl-v6, but this failed as the wires leading to the LED ripped off and thus rendered my flashlight nonoperational. I want to replace this light, but do not want to spend the $50 I did the first time I bought it. I was cruising DX and came along the UniqueFire UF-X6S . Now, while this lights head dimensions are listed as being smaller, I do not know if this is true. It appears to be very similar in dimension to the stl-v6 and it only cost $26.50. Does anyone have this light and could you guys please provide the correct dimensions and compare to the FandyFire?
Thank You
scaru
scaru's picture
Last seen: 4 years 10 months ago
If you knocked the wires off you can simply resolder the wires. If you don't want to do that then that light should work. I have the trustfire x6 which uses the same host. However it does run off of 3 18650 not 2.
Slewflash
Slewflash's picture
Last seen: 2 months 4 weeks ago
scaru wrote:
If you knocked the wires off you can simply resolder the wires. If you don’t want to do that then that light should work. I have the trustfire x6 which uses the same host. However it does run off of 3 18650 not 2.
Actually I was eyeing this one too, but I think the host is of similar design, but the DX version is much smaller. 58mm head compared to the X6’s 80mm head
Slewflash
yclongthrow
I meant the actually wires which go to the led die. I completely destroyed them when I lifted off the dome.
yclongthrow
The uf-x6s seems to have a very similar, if not the exact reflector, as the stl-v6. I’m not sure if the 58mm listed on the site is fully accurate.
mazda96hatch
Last seen: 8 months 2 days ago
Head is only 58mm, V2 is 62. 5 mode where as V2 is only 3 and not nearly as bright but
does have a slightly smaller hot spot. I have been waiting for someone to come up
with a good 2cell driver to mod this and a couple of others I have. Yes I did get it to go
with my X6 but was a bit disappointed with it. Pretty good for the money but not quite
the quality overall of the V2. Hope this helps.
Slewflash
Slewflash's picture
Wow the X6 is big. I love it! Thanks for the pictures mazdahatch, they were great Smile
Slewflash
mazda96hatch
One other small thing with the quality of the UF-X6S was if you look at the front you will
notice that the cut-outs on the bezel are all uneven which annoyed me. Or maybe I’m just fussy.
DarkSide
DarkSide's picture
Last seen: 4 years 1 month ago
Nothing compares to visual aids.. That’s a perfect pic.
the smaller X6S and light to its right are almost clone copies of a Surefire M3lT..
I never realized how small and the overall shape is nearly identical..
I have an X6 on its way. Its a beast in size..Hopefully a driver swap will bring out its
potential..Nice pics
mazda96hatch
On the up side, it does have a glass lens and an aluminium reflector but the pill
does not contact much of the body at all. There is at least a 1mm gap between the
pill and body with minimal contact top and bottom. At the very least it probably be have to
wrapped like a P60 to be driven any harder.
TrakTuned
TrakTuned's picture
Last seen: 7 years 5 months ago
Well that is quite the letdown…I thought this light looked promising but as always, price dictates….
BLF members are hilarious:
“That’s like saying “My car has top-speed of 200k millimiles per hour”. Why not to just say 10 Ah?”
yclongthrow
I really appreciate the response mazda96hatch. I guess DX’s measurements are correct after all. I’m disappointed this light can’t match the stl-v2.
Slewflash
Slewflash's picture
What made you doubt DX’s measurements in the first place, if I may ask?
Slewflash
TrakTuned
TrakTuned's picture
I assume it is because people thought they were the same/similar hosts. Therefore the head diameter should have been the same.
yclongthrow
DX isn’t always 100% accurate and the two lights seemed very similar in dimension. I have ordered the Small Sun ZY-T13, and considering it is only $24, I hope it is at least somewhat comparable to the FandyFire.
raccoon city
raccoon city's picture
Last seen: 2 hours 6 min ago
Welcome to the addiction, TrakTuned!
Best0270
TrakTuned1
TrakTuned2
_the_
_the_'s picture
Last seen: 1 week 17 hours ago
mazda96hatch wrote:
Hope this helps.
Doesn't help at all :bigsmile: (still waiting for my X6 to arrive...)
=the=
viffer750
Last seen: 4 years 7 months ago
unique engrish language... Smile
Pulsar13
Pulsar13's picture
Last seen: 11 months 1 week ago
yclongthrow wrote:
DX isn't always 100% accurate and the two lights seemed very similar in dimension. I have ordered the Small Sun ZY-T13, and considering it is only $24, I hope it is at least somewhat comparable to the FandyFire.
Congrats on the buy, the T13 is an excellent light for the price.
All you need is a single 0.5ohm resistor mod for it to reach or surpass STL-V6.
By the way, you do know your STL-V6 emitter is easily replaceable, right? A T6 star is only about $4 shipped on Dinodirect.
Rockspider
Rockspider's picture
Last seen: 7 months 5 days ago
+1 Laughing
Replacing the emitter is easy and cheap
apt323
apt323's picture
Its pretty easy probably takes longer to trar the light down then replace the led
agenthex
agenthex's picture
Last seen: 7 years 11 months ago
mazda96hatch wrote:
On the up side, it does have a glass lens and an aluminium reflector but the pill does not contact much of the body at all. There is at least a 1mm gap between the pill and body with minimal contact top and bottom. At the very least it probably be have to wrapped like a P60 to be driven any harder.
Does this X6s work well or at all with 1 cell? I mean, does it keep a constant current same as 2 cell (~1A)?
Reading this makes you smarter: http://lesswrong.com/
