you’d be hard-pressed I think to find anyone that has both as they are fairly recent lights.
The reason I got the JM07 is it has a fantastic beam profile for cycling. Now that I have it in hand, I can also say fit and finish and comfort in hand would be hard to beat, real gem of a light. The F22 also looks like it has a great fit and finish, with a C8 like head and SMO reflector it should throw better but with less flood, and driven at 3A compared with 2.5A it would be a little brighter, albeit less run-time. You wouldn’t go wrong with either, you could contact the seller and get his opinion. Hank from IO or Ric from CNQG.
I just read your review WKJR. Thanks for the contribution!
I am looking for a floodier light as this will be an indoor/neighborhood light. I’ll get either in CW. Which would have the floodier beam? I am concerned about the UI on the JR, as it seems the end cap is still on off? or can i cycle to off through side clicky?
Also, may just come down to the one looks better to my eye.
The JM07 would be floodier as it has a smaller OP head/reflector. The tailcap is a forward clicky which I didn’t mention in the review and only comes on in high mode, no mode cycling. The side clicky cycles modes only. Personally I like the UI, forward clicky for intermittent use and side clicky for extended use and mode changing. It may bother some that it comes on in high mode only though.
