AW ICR10440 350mAh (Blue)
Official specifications:
- 10440 ( AAA )
- 350mAH
Internal resistance has been calculated between 1A and 2A.
There is a good match between the two batteries.
In this test I do overload the batteries, this is possible because it is a unprotected battery.
I uses 500mA as charge current, this is to high for the battery and will reduce the lifetime of it.
Conclusion
This is the first 10440 battery I test, this makes it difficult to say much about the performance compared to other 10440.
With AW behind it I will rate it as a good battery.
Notes and links
Comparison to other LiIon batteries
