Test / Review: Yezl 16340 880mAh (Gray)
18 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 6 days ago
DSC_0536
Official specifications:
  • Capacity 880mAh (Manufacturer Stated) - Our Tests 658mAh
  • 16340 (CR123A) High Quality Li-ion Cells
  • Charge voltage: 4.2V +/-0.05
  • Discharge voltage: 2.75V
  • Protection Built in Li-ion Rechargeable 3.7v battery
  • Size: 16.65mm ±0.1 Diameter x 35.80mm ±0.1
Yezl%2016340%20880mAh%20(Gray)-info
DSC_0534 DSC_0535
DSC_0537 DSC_0538
DSC_0539
DSC_0540
DSC_0541
Yezl%2016340%20880mAh%20(Gray)-Capacity
The battery has nearly constant capacity up to 1A, this is a good performance.
Yezl%2016340%20880mAh%20(Gray)-CapacityTimeHours
Yezl%2016340%20880mAh%20(Gray)-Energy
Yezl%2016340%20880mAh%20(Gray)-PowerLoadTime
Yezl%2016340%20880mAh%20(Gray)-TripCurrent
Yezl%2016340%20880mAh%20(Gray)-Charge
Conclusion
The battery has a good capacity, but the voltage can not match the best batteries.
I will rate it as good for a cheap battery.
Notes and links
Comparison to other LiIon batteries
Edited by: sb56637 on 08/26/2014 - 17:45
Woody
Woody's picture
Last seen: 4 days 7 hours ago
Is it just me, or are the batteries a little beaten up? They look well enough packaged, but slightly dented at the end.
Nice review as usual, HKJ, thanks.
HKJ
HKJ's picture
That must be you, remember that the bottom has the protection PCB and the PCB is slightly slanted on one of the batteries.
Woody
Woody's picture
Ah right, thanks. I’ll just go and take my medication. :bigsmile:
ri chevy
Thanks again for doing these tests for us!
Tecmo
Tecmo's picture
Thanks for the tests!
MattSPL
Last seen: 3 months 4 weeks ago
Thanks for the test Smile
Not bad, but not as good as i thought they would be.
Cheers
Matt
pounder
pounder's picture
just got some of these..seem to be decent..still the trustfire flames I use are close in capacity for 1/3 the cost I paid for them..
Lumatic
Lumatic's picture
Last seen: 7 years 11 months ago
on BLF they were gonna be something else and then some. Guess what. :~
“When I buy something in bulk you should prolly buy at least one too.”…..“They that have light shall rule the night.”…..“Flashaholics feel depressed without darkness.”…….“I’m a very terminal torchaholic. My entire life just flashed before my eyes
MattSPL
Using an Olight S10, I managed 1 hour and 11 minutes of runtime on high using the Yezl’s, compared to around 55 minutes runtime as tested in an Olight S10 review, so, although the Yezl’s don’t come out on top in testing, they do seem to perform very well in use.
HKJ
HKJ's picture
MattSPL wrote:
Using an Olight S10, I managed 1 hour and 11 minutes of runtime on high using the Yezl's, compared to around 55 minutes runtime as tested in an Olight S10 review, so, although the Yezl's don't come out on top in testing, they do seem to perform very well in use.
In some lights you will get longer runtime, if the LiIon battery voltage is slightly low. I.e. a good battery with high voltage will not have as long runtime as a cheap battery with lower voltage.
ky70
Last seen: 8 years 2 months ago
Cheers
Matt
Compared to the other 16340 batts reviewed by HKJ, I think it did great as it looks to have the 2nd highest capacity (more than the AW) of the reviewed 16340s behind the Eagletac.
ky70
But shouldn’t this be expected (longer runtime with Yezl vs. AW) since you measured the Yezl with a higher capacity than the AW (per your review charts)?
fishinfool
fishinfool's picture
Last seen: 2 years 4 months ago
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
MattSPL
I suppose it all depends in the light used, and how much current it pulls.
HKJ
HKJ's picture
ky70 wrote:
But shouldn't this be expected (longer runtime with Yezl vs. AW) since you measured the Yezl with a higher capacity than the AW (per your review charts)?
You are correct in this case, but as I wrote above more capacity is not always the same as longer runtime, it depends on the light/driver.
ky70
Ok, I get it. Thanks for the clarification.
xevious
xevious's picture
Last seen: 2 hours 57 min ago
Where can you buy these? I’ve searched around and so far turned up “sold out” everywhere I looked… Sad
