4x18650 battery box question
45 posts / 0 new
Shadowww
Last seen: 5 hours 17 min ago
malt0se wrote:
should the charger be cutting off before 4.28v? is that overcharging the batteries?
Yes it should.
My 6 cell one stops charging at 4.2V, and in few hours, voltage drops to 4.17-4.19V, so it might have better charging circuit than 4x one.
Werner
Werner's picture
Last seen: 2 years 2 months ago
I have not tested charging of unprotected cells yet but we all have to think of that a cheap dmm could do measure wrong too.
I’m just right now charging my phone
malt0se
Last seen: 4 years 7 months ago
I ve been using mine to charge my iphone all week. Last night it started flashing and my iphone kept making the sound it makes when you first plug in your charger. Think it would mean its low on battery?
Ian2381
Ian2381's picture
Last seen: 4 years 5 months ago
I just bought a similar power box with 18650 on parallel,
One question, is it safe to mix match cells as it is in parallel?as in using different cells or different starting voltage.
Sorry if this is a stupid question. :8)
Thanks guys
HKJ
HKJ's picture
Last seen: 1 day 9 hours ago
Ian2381 wrote:
I just bought a similar power box with 18650 on parallel, One question, is it safe to mix match cells as it is in parallel?as in using different cells or different starting voltage. Sorry if this is a stupid question. :8) Thanks guys
Different cells is not a problem, but it is best to keep them fairly close in staring voltage (Say 0.1 volt).
Ian2381
Ian2381's picture
Thanks a lot for the response HKJ
How safe is usingunprotected cells on one of these?
HKJ
HKJ's picture
Ian2381 wrote:
How safe is using unprotected cells on one of these?
Depends on the box, the one I have reviewed is safe with unprotected cells.
Ian2381
Ian2381's picture
Mine seems to be different.
battery box
Feature:
Output voltage: 5V
Output current: 0-2.5A (MAX Dual outputs total 3A)
Charge voltage: DC 5V,1A (recommended more than 1A ).the center PIN of Charging port is +. Battery protection: full auto stop, protection against overcharge, the battery voltage is below 2.9V start protection, turn off the output, you can perfect or protect the lithium polymer battery 18650! Charging time: 4pcs 18650 would take about 15 hours
Box size: 105 × 82 × 23mm
You can use 1 to 4 battery. Use four 18650 2600MAH battery, Capacity up to 10000MAH.
Please use the 18650 battery without protection. because this power box Circuit built-in protection. otherwise would burn the power box.
Ian2381
Ian2381's picture
battery box
Feature:
Output voltage: 5V
HKJ
HKJ's picture
Ian2381 wrote:
Mine seems to be different. "battery box":http://www.ebay.ph/itm/370770122511?ssPageName=STRK:MEWNX:IT&_trksid=p39...
There are many different models on the market, I plan on testing a few more, but at the current time I cannot help you with that one, you must test it yourself.
Connect a meter to the battery while it is sitting in the box, if you have a min/max button select min and then discharge, until the box stops.
If the meter shows any voltage below the minimum of the battery, do not use it without protected batteries.
For 2900/3100/3400 the minimum voltage is 2.5 volt, other batteries can have a minimum voltage up to 3 volt.
Ian2381
Ian2381's picture
Thanks hkj,
Will test it once it arrive.
Hopefully its a good one.
Thanks for all your effort testing batteries and chargers in the market, you helped guys like me. Smile
itguy08
Last seen: 8 years 8 months ago
Werner wrote:
Batteries are parallel so no chance the will get balanced, but just for playing around it should be ok. I would not put unprotected cells in it when I would only charge it through this device, if you have a cell which has lower capacity it will over discharge it. Not sure how CCCV will work with parallel cells?
Parallel will always “automatically” balance. You should use batteries that are close (a few .1’s of a V) but they will balance themselves. CC/CV will work just the same as it will look like a pack of the capacity of all the cells added together – for example, 4×2500mah’s in parallel will look and act like 1×10000mah pack.
Werner
Werner's picture
This only works if you have equal cells, but the Chinese crap a lot of people use are going boom. Also these laptop pulls…?
You can see this with the cheap bicycle battery packs, sometimes they are Realflames.
Also could it happen that if 3 cells are empty the 4th has to handle all the power this is very inefficient. After use the cells with higher voltage charge the ones with lower voltage…and so on. There are a lot of effects which I don’t want.
But you are right, theoretical they balance themself, this is done in battery packs for ebikes or ecars all the time but only with brand cells of the same build.
And as the most batteries are stronger than we think it will probably nothing happen if you make everything wrong…but perhaps you will burn your house…
GottaZoom
GottaZoom's picture
Last seen: 3 years 3 months ago
Werner wrote:
Realflames
There is a flashlight product name!
