I got the TR-J18 from FastTech a couple of weeks ago, and I'm not very happy with this it do far. Here's why:
- for the size and amount of LED's in the head, it's fairly light weight, which is telling me it probably doesn't have much in heat sink
- on 26650's, it drops amps in one instance: on 3 batts, drops from 3.25A to 2.2A, on 2 batts, it drops from ~6A down to ~4A after running a few seconds, maybe a minute. I swapped batteries, even tried King Kong unprotected, same thing - very consistent and seems to be temperature related, like the driver has some temp sensor protection. Why is the driver getting hot though? I can tell it's temp related because if you try it again quickly, the drop happens quickly. If you let it sit a couple of minutes, it takes longer to drop. Also note the amps drop correlates to brightness drop -- very noticeable quick flicker. I haven't been able to reproduce this drop with 3 18650's. 3 EagleTac 3100's work fine, but only about 3.75A, but amps drop continuosly it seems like. Trying 2 EagleTac, the amp draw is 5+ amps and quickly shuts off - think the batteries are tripping.
- can't figure out how to dismantle the LED head area, maybe the reflector is glued?
- the driver has been changed along the way or has 2 versions - not sure if it's FastTech's source or what. Mine has a perpendicular mounted board, while the earlier, other driver has 2 parallel PCB's.
I can see why NZ Shooter is giving his away after only a few weeks and not giving any reason, after an initial posting of being blown away by it. I too was blown away after first seeing it.
I think this light can be salvaged, but I'm wondering what the best driver to use would be, and if anything can be done to beef up the heat management. Does anyone have experience with this light doing upgrades? I see KD and IO have drivers for it that should fit, in theory (7 LED's, 26mm PCB). IO's 3 mode driver is cheaper than KD's and they look to be the same exact driver. Has anyone used one of these drivers, if so, did it work out well?
Picture of the J18 head and driver - bought from FastTech, Rcv'd 12/24/2012:
