12 volt --> 5 volt buck converter
14 posts / 0 new
scaru
scaru's picture
Last seen: 5 years 1 month ago
Does anyone know of a place in the US that sells something that can buck 12 volts down to 5 volts at around 50 watts minimum? Efficiency is not particularly important, also anywhere from 5-9 volts should work.
sanka
sanka's picture
Last seen: 11 months 4 days ago
If you are looking for a finished board, this isn’t very useful information for you. But if you want to build up from the driver chip, the Linear LT3791 driver can take in 6-36V and put out Vin minus 2V at about 20A. It can be had for about $6 in single or small quantities. I think it is rated at 94% efficiency or thereabouts.
Here is the data sheet: http://cds.linear.com/docs/en/datasheet/3741fb.pdf
moderator007
moderator007's picture
Last seen: 6 hours 38 min ago
Pulsar
Pulsar's picture
Last seen: 5 months 3 days ago
http://www.ebay.com/itm/waterproof-DC-DC-Converter-Regulator-9v-35v-12V-...DOWN-to-5V-50W-10A-/271064637424?pt=US_Power_Inverters_&hash=item3f1cb61ff0
Hopback
Hopback's picture
Last seen: 5 years 2 months ago
Not US but Mouser etc might do something similar:
http://uk.rs-online.com/web/p/non-isolated-dc-dc-converters/0462013/
Woody
Slim Pickens
Slim Pickens's picture
Last seen: 2 hours 47 min ago
scaru,
have you looked at TaskLed drivers?
scaru
scaru's picture
That should work, unless there are other suggestions I'll go with that one.
Pulsar13
Pulsar13's picture
Last seen: 2 months 3 days ago
A cheap computer PSU will provide plenty of 5V and 12V power. Why convert when you can have both for cheap.
Pulsar
Pulsar's picture
he may be trying to run it off a 12v battery
scaru
scaru's picture
Exactly. Wink
PilotPTK
Last seen: 7 years 12 months ago
Battery Positive -> Big Diode -> Big Diode -> Big Diode -> Big Diode -> Big Diode -> Big Diode -> Big Diode -> Load -> Battery Negative
Smile
PPtk
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
texaspyro
Last seen: 2 years 6 months ago
scaru wrote:
That should work, unless there are other suggestions I’ll go with that one.
You will have to heatsink (or fan) the crap out of it to get the full 50W…
fyesilova
fyesilova's picture
Last seen: 8 months 3 weeks ago
link
Not in US, but it is what you want.
I do not know the quality of these but 10A is very high and it is possible to heat up.
Istanbul New YSM Bridge
Istanbul’s new bridge at night
fyesilova
fyesilova's picture
this one may be better, it has a good heatsink, and you can screw it to a metal on your car for better heat dissipation.
