Ultrafire 501B R2 single mode + weapon kit
Reviewer's Overall Rating: ★★★★☆
Summary:
Battery: | 18650, fits protected np |
Switch: | tail clicky reverse |
Modes: | 1 |
LED Type: | Cree R2 |
Lens: | glass |
Tailstands: | no |
Price Payed: | * sent for review purposes by Yoki from DD * |
Date Ordered: | 03/21/2011 |
About the review:
I would like to thank Yoki from DD for the semple sent free of charge on the condition to make a review on DD. That said... let's go on objectively.
Pros:
- Compact sized (the most compact sized P60 host for 18650 cells i'm aware of)
- Came free of visual defects (not that i detected any others)
- Very well driven R2 emitter
- Very good pressure switch (required less force to activate than most others i'm used to)
- Very good universal weapon mount bundled with the appropriate hex tool
- Protected 18650 fits well, tried the XTAR 2400mAh 18700 without issues
- Above average switch assembly
Cons:
- The emitter is a bit on the cold side but that's standard for normal R2 in XR-E package
- Does not tailstand, changing ad fiddling with the tailcap silicone cap might solve the issue
- Host not suitable for higher powered emitters but for this one is about ok
- I don't like much the switch silicone caps without grip which most 501B comes with
- Wider gap than usually present in P60 hosts that needs to be filled with aluminum to help transfer the heat to the body
Features / Value: ★★★★☆
It is a 501B flashlight body with an added single mode XR-E R2 dropin. It's strength lies in the compact size. By being small, heatsinking suffers a bit but for such an emitter it gets the job done. Since we are talking about a flashlight bundle aimed for those who want to use it on a firearm the acessories are worth a comment or two. A spare tailcap with pressure switch is bundled together with a very decent universal weapon mount. Hex tool for the weapon mount was to my surprise present in the package. Thre pressure switch is unbranded and does not feel like a tiny tiny click when pressed which im used to with ultrafire branded ones. This one is very responsive but not overly. Involuntary presses are probably rare.
Design / Build Quality: ★★★☆☆
Build quality wise is not comparable with "premium budget" hosts like solarforce. Almost an oxymoron term?!? It is however fair for the price. Glass mounting and interchangeability is made in a way i will not bother fiddling with. Tailcap side threads are a bit too few for my liking but does the job anyway. I suspect it has to do with keeping it compact. Aesthetically speaking i'm not a huge fan at all. Looks very nice on a weapon but in hand a more polished look is desired. I guess we all have a P60 host we like more than others. Free of machining defects and even anodizing was present althrough the tailcap was a bit on the shiny side for a otherwise matte style body. The tailcap silicone switch cover without grip is what i don't like on any flashlight. It's an easy fix but i would have preferred it came with a better one in stock form. With the few 501B i had neither one came with a decent tailcap silicone button cover. Orings are present where needed, counting 4 in total and to my surprise even lubed.
Battery Life: ★★★★☆
Battery life is gonna be good on this one. Current draw at tailcap is 1150mA with a freshly charged 18700 XTAR 2400mA which is getting good reviews lately (i suspected but never really knew it was that awesome ). With such current draw we can expect a good 2h of good brightness and probably another one with significantly reduced output. Being single mode i'm afraid there is nothing much more to be said on the subject. Why not 5 stars? Don't really know, but the driver circuit should be doing a few more usefull things to be a contendat for 5 star award.
Light Output: ★★★★★
The emitter does get pushed well enough. Driving the emitter probably well arround 1A if we consider some circuit board losses which i will not gonna measure since it is probably not worth doing. This is 4.5 stars to my book. Emitter tint is rather cold and on par with a few other R2 i have. The reflector is adequately chosen for the emitter type and artifacts are really hard to spot by white walling. I had a few Q5 dropins and none of them had such a nice beam. But looking at the picture below judge yourself.
Lux reading at exactly 1m emitter to sensor: 8990 lux
For comparison a Q5 driven at 1040mA: 7950 lux
Beamshot taken at 120cm distance from wall to camera. The flashlight was 230cm away from wall.
The picture above shows a very nice tint but in reality was slightly colder, still good looking tho.
Summary: ★★★★☆
All put together the whole package is a good (althrough not awesome) deal for those who want a one package deal. The 501B host is not my favorite but it does look nice on a firearm. Unfortunately that cannot be said for handheld "mode" where it lacks the fine details of other P60 hosts around. For what it costs it is well featured. The battery tube is actually very close to my XTAR 18700 thickness so it does not rattle inside which is often not the case with other p60 hosts. The R2 dropin is the star of the show here. Very well driven and with a nicely picked reflector that really brings a nice hotspot with hardly any artifacts. The bundled weapon mount and pressure switch are also excellent. The weapon mount looks a very professionally made one. I'm not an expert on those but since the whole package will be gifted to a friend who will appreciate such a package it does at least look very decent.
I would like to thank Yoki from DD again for the free sample. Shipping was exceptional. 10 days after confirmed shipped, untracked. (Still waiting a ton of other stuff from other dealers that are being way overdue) Yoki requested just a review on DD for sending me this package for free. The review on BLF was my call and since this package was the only one i recieved recently worth of reviewing i had to write something to not lose the grip.
EndofreviewFoy! Whats a review nowadays without writing at least a random Foy somewhere.
