Built-in heat and fault (short-circuit) protection
Does that mean that they are a protected battery and the chance of them having an issue due to one being lower voltage than the other is minimized?
I am in need of 4 for a camping trip coming up and I can buy Surefire’s local…I want to order some 18650’s so I can run single cells but don’t have the time to get them before we leave so am looking at the CR123A option…just want to be as safe as possible…
I’ve always mixed and matched different makes, capacities and not had a problem in all my years, I’m now 47, done this with all battery types not just NIMH NICD, but also Lion etc.
tabs
Hm, and what does happens when two CR123A’s are being used in series at current too low to be affected by PTC?
Would something bad happen when one cell completely depletes, and due to capacity mismatch, which is always there (even if it’s miniscule) gets reverse charged? :s
I have not seen the test procedure for CR123 batteries, but I would expect it to include some reverse charge tests.
But sometimes they do explode when reverse charged, i.e. if you light goes out due to depleted batteries, it is important to turn it off (or remove the batteries).
