You said you don’t smoke and you don’t plan to…be helpful to yourself and don’t ever bother to try. E-cigs are relatively new and there is still no short or long term study on its effects to the human body. Whatever it will be, personally I’m scared of inhaling some kind of chemical. You are a lot better off now without it, don’t you think?
There has been short term and long term research on ecigs. There has been studies done since the 40s on inhaling vapors of the main ingredient of ejuice, pg. I can do some searching and find some to link here
Pg and vg (vegitable glycol, can’t remember what pg stands for) are the base ingredient for ejuice. The basics of the test from back in the 40s, inhaling pg vapor was found to clear lung infections along with other things. It’s been probably 2 years since I read the article so I don’t remember much more.
Those ingredients are also used for medicinal uses, such as a child’s nebulizer for asthma.
Now the flavors, there’s only been short term tests done, but I don’t believe there has been any negatives found
And the nicotine they say is no worse than caffeine
If you don’t smoke cigs please don’t start a nicotine addiction with e-cigs. They may or may not be safe. However, compared with cigs it’s a safe bet that they are “safer”. However, inhaling anything into your lungs, even not so clean air, is something to take seriously. Not to mention a nicotine addiction is expensive and well addictive, very addictive it doesn’t take long for most people to get completely hooked.
If you are a smoker, I would highly recommend trying them out. Any reduction in cigarette smoking as a result of e-cig smoking is a positive thing. If you are not a smoker, it is highly unlikely that you could become addicted to nicotine through one of these things- but why even try?
I guess I just don’t see the point. But I struggled with nicotine addiction for decades and I have seen it destroy lives so it’s simply not cool to me to see anyone smoking or acting like they smoke. I think e-cigs should be used to quit smoking and I would hate to see them be used in a way that could even possibly lead the way to smoking cigs.
However, to each their own, I’m sure there are more dangerous things in life.
