Romisen RC-I3 goes into strobe mode when battery is low
4 posts / 0 new
sb56637
sb56637's picture
Last seen: 12 hours 48 min ago
Hello all,
Wanted to mention some rather strange behavior with my new Romisen RC-I3, I wonder if anyone has an explanation.  In a runtime test I did, as the alkaline battery starts to drain, it seems to maintain a fairly linear light output on low mode.  But when the battery becomes quite depleted, it switches into the strobe mode and blinks brightly.  I can not switch it out of the strobe mode with a dead battery.  Yet, the strobe is surprisingly very bright for running on a dead battery.  What would be the explanation for this?
Thanks for the tips!
Don
Don's picture
At a guess, some sort of capacitor sucking out enough charge, discharging and then starting again. This is just a guess though. Certainly lets you know it wants feeding.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
sb56637
sb56637's picture
Hmm, could be that it's not actually the strobe mode, but rather a capacitor charging and discharging.
alfreddajero
alfreddajero's picture
Last seen: 7 months 1 week ago
I know when the cells are low in my RC-N3 that it will slowly strobe.....but it is not as bright as you say.  I took it as an indication that the light wants and need fresh cells.
With Darkness, there will always be Light.
