Tear Down of the 2AA Defiant light - Question about driver
89 posts / 0 new
ImA4Wheelr
Last seen: 1 month 1 week ago
They had these marked down to $7.98 at my HD.
tallboybass
tallboybass's picture
Last seen: 2 years 7 months ago
Even better! Very impressive for a $4 light!!
relic38
relic38's picture
Last seen: 3 years 10 months ago
I’d guess the resistors are in parallel, and the medium mode is done via PWM. While in Medium mode, wave something shiny like a screwdriver tip in front of the light. If the motion appears smooth, it’s not PWM. If you see 20 screwdriver tips all at the same time, it’s PWM.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
texaspyro
Last seen: 2 years 3 months ago
Or you’ve been drinking too many screwdrivers… Party
relic38
relic38's picture
Precisely, and I recommend not waving screwdrivers around while drinking screwdrivers. Someone could lose an eye… plus you’ll look really stupid in the flashlight aisle at HD. Big Smile
Welcome the night.
texaspyro
Meh… you got two…
relic38
relic38's picture
I’ve got two of a few things, and just fine and dandy with keeping them all in pairs Wink
Welcome the night.
MorePower
Maybe based on somthing along the lines of the PAM2805? Similar layout, same modes. Vref would be 0.095V, however, which would put the LED current on high at only 125mA, so clearly it’s a different chip.
Link to PAM2805 eval board document: http://www.diodes.com/_files/evbd/PAM2805%20User%20Guide.pdf
tallboybass
Has anyone done a simple ‘dedome only’ on these? How did you like it? The tint on one of mine is spotty…changes across the beam. I thought a dedome might even it out. Help me out fellow BLFers!
Slim Pickens
Slim Pickens's picture
Last seen: 1 day 17 hours ago
The phosphor is deposited on the dome—dedoming will even out tint variation in the beam if you need or want a blue light.
I just read here that it’s actually not a remote-phosphor in the sense that I thought. Shows how much I know!
So I’m not sure what this LED would do when dedomed. Only one way to find out Big Smile
tallboybass
Thanks Slim, I keep reading that a dedome will warm the tint some, is this emitter different?
ImA4Wheelr
Quote:
TrakTuned wrote:
. . . HD also has some home lights that have “X” leds in them for like 12 bucks with tons of them in there! Thought about buying one to use for a little the rip it apart and make a new contraption. Big smile
EDIT: looked at the 60w and there are 20leds in it!
Is this the light your talking about? Did the light contain XB-D or XT-E’s? Wondering, because it may be a cheap way to put warmer emitters this light and in other in cheap lights.
http://www.homedepot.com/p/Cree-9-5-Watt-60W-A19-Warm-White-2700K-Dimmable-LED-Light-Bulb-1-Pack-BA19-08027OMF-12DE26-1U110/203991774#.Ucs20py0Qil
nottawhackjob
Last seen: 2 hours 44 min ago
This little rascal with its ‘lowly’ XTE emitter has to be the brightest 120 lumens I’ve ever come across especially on strobe. It really smarts the peepers. Maybe it’s the particular OP reflector and/or the nature of the XTE itself but whatever it is it’s surprisingly no slouch. I’m even tempted to dedome an XTE and see what’s what.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
True Color Rendition (TCR)/Simplified Definition: “On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
The TCR Reference Standard is the Walmart Ozark Trail OT 50L , Model No. 6103.
It has a TCR rating of ‘10’. $1.00 including batteries.
ImA4Wheelr
Yeah, it’s a surprisingly nice little light. I find the beam pattern much nicer without the centering ring. Smoother transition between the hot spot and spill.
dchomak
Last seen: 3 years 3 months ago
Has anyone tried to take off the head? Does it come off? The tail end screws into a an Sipik 68. I am on the road and don’t have the tools to get the head off to try. I’m thinking it would be nice to have a SK68 running off 3 – NiMH.
ImA4Wheelr
O-L was the first to report that the bezel screws off, but not the head. Everything is accessible when you take off the bezel though. Very easy light to work on.
dchomak
All a man needs is the right tools. The head does come off but it’s glued on. I used the brute force method but there is another, more clever way. I think I read here that some sort of soak will do it, or was it heat?
Anyway, the tube DOES fit the Sipik 68 here is a pic of the new, just released, Defiant HD-68 (HD=Home Depot)
Runs on 3 – AA
ImA4Wheelr
Nice work. Thanks for the info.
StorminMatt
Last seen: 4 years 10 months ago
I was never really interested in these lights until I saw here that I can get the pair for less than $8 at Home Depot. I have to say that I am actually VERY impressed with them. Build quality is, well, less than top notch. But these are definitely top notch performers, even without considering the price.
The funny thing about Defiant is that, despite the fact that they are often cheaply made, I’ve NEVER had one that wasn’t a good performer. These lights are rated at 120 lumens. And they put out AT LEAST that. Not only is output good, but so is tint. No blue or green casts. Just a nice, creamy white. My Minimag LED (the standard 77 lumen model) may be better built. But it doesn’t put out near the light. Heatsinking is nonexistant. And the tint is VERY bluish. As far as performance, there’s NO COMPARISON with this Defiant.
As far as modding this light, I’ve certainly been thinking about it. After all, it didn’t cost much. And it seems like it could possibly do ALOT better with a better emitter (maybe an XP-G2 or XM-L2). Of course, I also like the light as it is, and don’t know if I really want to try my first mod on it. Oh wait! You actually get two of them. So I can have it both ways.
Without lamps, there’d be no light.
Aftrburnr
Last seen: 7 months 4 weeks ago
Don’t know if this is news or not, but, I just bought 1 2 pk on 6.20 and the price was $11.98 + tax = $12.95 I was then in the store last Friday, 6.28 and I now see the price is $7.98 + tax for this 2 pk. w00t! Bought another one lol. There was one left at the store I was at. H Depot clerk said I could bring receipt on 1st purchase and get refund of the difference. Also, thought I’d give a try posting a pic from photobucket. I wonder if the album has to be public or can it be private? Anyhow, just wanted to share Smile
nottawhackjob
The XTE now throws a good bit further subject to the fact that it has an OP reflector which tends to stifle that aspect.
tallboybass
Cool! I went to HD today, and they are still $11.98 here in Tulsa.
Aftrburnr
tallboybass: Maybe print out my pic above and get HD to pricematch themselves. I took my receipt down today and got $4.32 back :bigsmile: I’ve done 3 or 4 price matches with them at the service desk very recently and didn’t have any problems with getting them to price match what I wanted.
dchomak
That’s right. I had a problem with HD recently concerning replacement windows. They wanted to charge for “Custom order” prices for window sizes that were for sale on their website.”………until I made them price match their own website!
tallboybass
I’ve done that with Guitar Center and Musician’s Friend…they’re basically the same corporation but GC didn’t want to match MF’s total out-the-door price!
dchomak
cat eyes wrote:
we should always share prices here on BLF
it won’t be long before some of the home depots
drop their price on the defiant thrower, and we should
help all on blf to get the bargain when it happens….
I am in a HD almost every day. I will know within a day or 2 of them going on clearance and will post the pic.
BTW, the Bloomfield HD just sold their first 5C Defiant 2 days ago. I never bought one, but was gifted one by a friend that bought one and liked it so much he gave me one. Apart from needing 5 C cells to run, I like it. That one too will go on clearance.
Aftrburnr
I guess you’re going to use the inventory checker? #469 #473 off hand but there were also others that were out of town where I got them to also do a price match to Costco’s MagLite combo pack. I got 3 at 2 different stores :bigsmile: These lights though, do not show up on their website. Hope this helps.
Aftrburnr
I was wondering what the max voltage these lights could do in their stock form. I was thinking the light could do a 14500 with a dummy cell mebbe? Wonder if would be brighter? Then, possibly 2 14500? That would prolly poof the light tho lol So, what say you all?
panthervision23
Last seen: 7 years 9 months ago
Two FLs in a package for $10? That’s something! Love
lightning210
lightning210's picture
Last seen: 8 years 2 months ago
Went to HD to buy some more before they take them off the shelf (heard the discontinued rumor) Seems to be true- none on shelves or displays and apparently they are totally off the computer inventory. That sucks, I was going to buy a couple more packs!
« Stay out of trouble (or don’t get caught). »
