LOOKING FOR CHEAP WALKIE TALKIE
11 posts / 0 new
zelee
zelee's picture
Last seen: 6 days 17 hours ago
Hi guys
i want to ask if someone here an expert about walkie talkie,i need an advice which one i should buy and where to buy.
first time to use walkie talkie so i’m very noob about this.
thanks for the help before.
transposon
Last seen: 4 years 6 months ago
You can always buy the junky gmrs bubble pack handhelds. These are the typical ones you will see at Walmart or best buy. The advertised range on these is no where close to being accurate. Expect 1-2 mi.
You are FAR better off spending a couple hours studying for a HAM radio licence and getting a 70cm/2m HAM handheld.
Not only will you have much better range you can also add an external antenna to go even further.
On top of that you will be able to use repeaters in your area enabling you to get upwards of 20 or 30 miles of range.
ham handhelds or “HTs” are very inexpensive nowadays. They can be had for the cost of those crappy bubble pack radios.
take a look at the Baofeng
brand. They can be had for as little as $35.
the uv-b5 is probably the best buy. I own this one.
ham radios are far more useful in an emergency as you can almost always get a hold of someone. Not so with GMRS.
GottaZoom
GottaZoom's picture
Last seen: 3 years 2 months ago
+1
leaftye
Last seen: 10 months 1 week ago
If that.  I've noticed they get much better range in the city than out in the boonies.
The low mode should be lower.
Bumble
Last seen: 7 years 6 months ago
2 plastic cups and a piece of string Smile lol
ill get my coat…..
transposon
1/2-2mi is probably more accurate. the only time I’ve gotten over 1.2 mi was when my contact and I were facing each other high up on adjacent mountains with just open air in between. Hardly a typical scenario.
Empire
Last seen: 7 years 10 months ago
leaftye wrote:
If that.  I’ve noticed they get much better range in the city than out in the boonies.
The opposite is true you have it back to front.
leaftye
You're telling me what I've noticed?  I didn't say it makes sense, but it is indeed what I've noticed.
zelee
zelee's picture
thanks for the help,i must studied first before i start using it.
i have my eye on baofeng uvr series because its size is so small
transposon
you can listen without a license but you can’t transmit without one.
The uv-b5 is a better radio than the uv-5r. But the uv-5r does have more accessories and a larger user base and a few extra features. Both are the same size.
zelee
zelee's picture
got it.
don’t want to violate the regulation for illegal using of the frequensi
