Thrunite TN30 developed a yellow XML2 LED
27 posts / 0 new
xed888
Last seen: 8 months 14 hours ago
Hi guys,
As per thread title, has anyone any advice?
One of the LEDs turned yellow (it was a CW TN30 XML2 version). I sent it back to be replaced but it came back the same plus I think another one is turning yellow too! Sigh
I wasted postage and have sent them an email asking for an explanation but I was wondering if anyone knew of any fixes?
Cheers!
https://www.dropbox.com/s/3ycguru9p1dl8nc/CameraZOOM-20130722114322302.jpg
Edited by: xed888 on 07/22/2013 - 00:15
ohaya
Last seen: 3 years 6 months ago
Hi,
If you look at some of the reviews on Amazon:
http://www.amazon.com/ThruNite-TN30-Flashlight-Cree-Lumens/product-revie...
a couple of them mention yellow:
Quote:
But it wasn’t, one of the LED had some sort of bubbles in it and had a yellowish tint to it. This is going back to the seller for a replacement!
Quote:
then I noticed a yellowish glow but only in one spot… so I decided to return it for replacement, which I did and guess what? a new light (different S/N#) shows up about 10 days later and , you guessed it, 2 blue/white and 1 yellow!!!!
Were either of those reviews yours? If not sounds like it’s not a problem that’s unique for you (tho that was for XM-L U2)?
xed888
thanks for the reply ohaya.
No i haven’t written anything on Amazon but you’re right. It sounds like a prevalent problem. It’s annoying as I have just wasted the time taken for transit and postage! I am currently waiting for a reply from them.
ohaya
I wonder if they’re over-driving the emitters by design to get performance – the “bubbles” comment sounds like the domes on the emitters melted. Have you been running the light for long periods, and have you ever smelt something burning?
xed888
My lights are usually shelf queens so i dont use them often. Just once in a while.
There aren’t any bubbles and the dome is in perfect condition. It’s just that a diagonal half of the LED is yellow when current passes through the LED, thus giving it a yellow tint.
Hikelite
Last seen: 7 months 3 days ago
I think I've someone else on the forum mentioning different LED tints for his TN30.
Can you take a clear photo of the emitters?
xed888
https://www.dropbox.com/s/dx7omgu0xhfm8sw/CameraZOOM-20130722135410483.jpg
https://www.dropbox.com/s/j8bjnhlqzar3931/CameraZOOM-20130722135419282.jpg
You will need to zoom in, i think. It’s the best I can do with a camera phone.
The vertical lines are due to PWM.
In both pics, you can see that part of the LED is yellow. In one of them, half is yellow and in the other, a small corner is yellow.
Slewflash
Slewflash's picture
Last seen: 2 months 4 weeks ago
Wow that’s crazy. I’ve never seen anything like it before.
Slewflash
NightCrawl
Last seen: 5 years 7 months ago
I have seen XML2 turn yellow from too much heat, too. The old XML didnt have that problem. Can be really annoying if you notice a tint shift after reflowing..
33696933
33696933's picture
Last seen: 6 years 10 months ago
Mine has 1 led that has the same thing too. :_(
Steve_the_Chief
Steve_the_Chief's picture
Last seen: 2 years 6 months ago
In these pictures it looks like the "borders" of the yellow areas on the die are the same as the vertical pwm lines.
Do you really see that a sharp bordered diagonal half of the LED has turned yellow, or is that just the pwm messing with the camera?
xed888
So it seems like I’m not the only one. That’s annoying.
My point of annoyance is that I actually sent it for replacement and it came back worse! (I had one before but now 2)
33696933
33696933's picture
Well time for me to open it up
djozz
djozz's picture
Last seen: 7 hours 29 min ago
Those are good pictures for a camera phone! It looks like the silicone of the dome detached partly from the die, which results in the same effect as dedoming: tint shift and some output loss. Interesting that it happens easier on the xml2, this will also be the reason that the dedoming is easier with those newer leds.
Anyway, that is very annoying if it happens in such an expensive flashlight, I hope they come up with a proper solution for you.
xed888
They told me to ship it back to them!
$$$$ disappearing fast!
What do you guys think?
ohaya
I know this may sound like a kind of dumb suggestion, but maybe do a full dedome on the emitters? At least that way the color would be uniform.
Is this going to be a problem with ALL XM-L2 emitters/lights? Or is this only a problem with the TN30?
xed888
I dont think I wll de-dedome.
I like my lumens too much Smile and not too bothered about throw.
Perhaps I will send it back :S
ohaya
I hope that they can fix it, and esp., I hope that this is not a latent defect in the XM-L2 emitters, because I have several lights incoming that have XM-L2 emitters in them, and I’ll be ticked off if they all start doing that (dome de-laminating partially) :(!!
Slewflash
Slewflash's picture
If it’s only happening in TN30s then it probably has something to do with the way Thrunite reflows the XML2s on. They might be using temperatures way too high. Perhaps a worker slipped and pushed a knob?
I don’t think it’s a problem with the XML2, but rather the manufacturing process of the TN30. Otherwise we’d be seeing other XML2s having this effect.
Slewflash
ohaya
I’m not at all familiar with the TN30, but how long have the ones with XM-L2 been out/available?
Slewflash
Slewflash's picture
They came out very quickly after the XML2 was released (December 2012), probably around March or April I think.
Slewflash
ohaya
I was just checking, and one of the Amazon reviews was from Nov 2012, and the listing was under XM-L U2, vs. XM-L2, so it seems like it’s not just with the XM-L2 emitter versions, so maybe (hopefully) you’re right, that it is just a TN30 problem, rather than a generic XM-L2 problem, since the XM-L U2s have been out for awhile already?
Slewflash
Slewflash's picture
If it happened with the original model of the TN30 with the XML, then it’s definitely not Cree at fault here but Thrunite. XML U2 came out when XML came out in 11 Dec 2012 Source
Slewflash
ImA4Wheelr
Last seen: 1 month 1 week ago
I took apart my TN31 (xml2 version) this weekend and was surprized to find just a small dap of thermal paste under the emitter base. Less then 30% of the base had thermal grease contacting it. The bigger problem though was that there was a big bump in the center of the pill. This lifted the led base off the pill so that only 3 small spots were touching the pill. The center bump and the points were the 2 screws hold the base down. Furthermore, the led itself was not fully seated. It was tilted up and has a partial gap between the base’s thermal pad and the led. I bet if I would have got the yellow led too if I kept using the light like this. Maybe, there is a similar QC issue with the TN30.
Slewflash
Slewflash's picture
Ah good point, it might not be manufacturing but rather QC issues. I wonder if this is how they brought their price down by so much.
Slewflash
RedForest UK
RedForest UK's picture
Last seen: 1 year 11 months ago
If you take a look at THESE pictures you can see a couple of serious QC issues in a TN31 with direct effects on thermal characteristics. The LED was reflowed on with not enough solder on the middle heat dispersion pad and kapton tape was even left attached to the base of the PCB.
Cereal_killer
Cereal_killer's picture
Last seen: 1 year 9 months ago
It really looks like a overheated emitter to me, I was thinking that from the start then I read this whole thread where you say there is only a tiny, inadiquate amount of thermal compound and it makes me think that even more. From someone who has burned up multiple multiple emitters that’s exactly what it looks like to me.
Do you have a way to measure lumens/lux/cd? I would be welling to bet the yellow one(s ) are lower output than the others.
