Test / Review: Sibeile IMR18350 800mAh (Black)
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 23 hours ago
DSC_3062
Official specifications:
  • Sibeile 3.7V 18350 800mAh Cylindrical Rechargeable battery
  • Sizes: Length: 35.99 mm Diamter: 18.13 mm
  • weight: 30g
  • Voltage: 3.7v
  • Full Charge voltage: 4.2V
  • discharge cut-off voltage: 3.0V
  • capacity: 800mAh
  • internal resistance: 100mOhm
  • max charge current: 1C
  • max discharge current: 3C
  • Top: flat
  • with PCB or not: no
  • Temperature:dishcarge temperature range:-10°C—60°C, storage temperature range: 0°C—40°C
  • storage: 1 year:-20°C—25°C, 3 months:-20°C—45°C, 1 month:-20°C—60°C
Sibeile%20IMR18350%20800mAh%20(Black)-info
The rated current is low for a IMR cell, and the actual test confirms that the cell cannot deliver high current.
DSC_3042
DSC_3049 DSC_3050
DSC_3051
DSC_3052
Sibeile%20IMR18350%20800mAh%20(Black)-Capacity
The cell does very well up to 2A, but the tracking between the cells is not perfect.
Sibeile%20IMR18350%20800mAh%20(Black)-CapacityTimeHours
Sibeile%20IMR18350%20800mAh%20(Black)-Energy
Sibeile%20IMR18350%20800mAh%20(Black)-PowerLoadTime
Sibeile%20IMR18350%20800mAh%20(Black)-TripCurrent
Sibeile%20IMR18350%20800mAh%20(Black)-Charge
Conclusion
This cell has better than rated capacity, the current capability is fine for a ICR cell, but low for an IMR cell.
I will rate it as a acceptable cell.
Notes and links
According to Sibeile the IMR text will be removed from the next batch of cell.
Comparison to other LiIon batteries
Edited by: sb56637 on 08/26/2014 - 17:45
djozz
djozz's picture
Last seen: 37 min 5 sec ago
Thanks for this first Sibeille review. It solves the yes or no IMR mystery if even the factory (is it a factory or a rebranding firm?) is leaving the IMR claim. Pity though, I would not have minded a new source for IMR batteries.
HKJ
HKJ's picture
It is the second, the first it here: http://budgetlightforum.com/node/23429
And a comment from Sibeille: http://budgetlightforum.com/node/23629
djozz
djozz's picture
Ah, missed that one, thanks. Their batteries at least appear to be consistant in not being IMR..
sb56637
sb56637's picture
Last seen: 11 hours 3 min ago
Thanks a lot for the review! Frontpage’d and Sticky’d.
biggulp
Last seen: 4 weeks 1 day ago
Seems like Sibeile just smacks an IMR label on just about any battery.
ryansoh3
ryansoh3's picture
Last seen: 10 months 2 weeks ago
+1
BLF ≠ B-grade Flashlight Forum
