How many amps will a 15 watt driver put through a single XM-L2 on copper?
20 posts / 0 new
18sixfifty
18sixfifty's picture
Last seen: 1 year 12 months ago
How many amps will a 15 watt driver but through a single XM-L2?
OK I got this driver and I don’t know what to do with it. It says it’s for 5xQ5’s and is 15watts. Now cree says 10watts with an XML=1,000 lumens or so. Would 15watts give me 1,500 lumens and therefore be around 7 amps or so? I see the calculation that is something like amps=watts/volts but that doesn’t make any sense at all for this application. So does anyone know if I can run a single XM-L2 on a noctigon with good heatsinking with this driver?
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
bdiddle
it would likely work terribly for an xml. Most of those are wired for series, so 5× 3volts == 15v. Current at 1 amp would give 15 watts.
Newb
Flomotion
Flomotion's picture
Correction:
That Driver puts out 17.5 Volts
http://img.dxcdn.com/productimages/sku_26106_2_small.jpg
- Output current: 17.5V(800mA) with 5*P4/5*Q5 emitters
- 26mm diameter base, 13mm overall depth
- Voltage: 5V-8.4V
- Mode: High 800mA±20mA; Mid 450mA±20mA, Low 210mA±10mA; Fast Strobe 400mA±20mA; SOS:800mA±20mA
- Memory: fastter than one second is changing mode; slower than 1~2 seconds is stocking memory
Won’t work…
This is the Driver You Want:
http://intl-outdoor.com/xml-multicell-circuit-board-45a-ouput-55126v-p-5...
P = A x V
15watts = 4.5 × 3.3
Flomotion
comfychair
comfychair's picture
Last seen: 5 years 5 months ago
If it's a boost driver, it's a no-go for a single LED. Input voltage must be lower than the output voltage for a boost driver.
18sixfifty
Flomotion wrote:
Correction:
That sounds right. How did you work out the math? Any Idea what I could run with it? 3XM-L2’s? 2MT-G2’s?
18sixfifty
comfychair wrote:
If it’s a boost driver, it’s a no-go for a single LED. Input voltage must be lower than the output voltage for a boost driver.
Must be a boost driver. Is there anything I could use this for that you know of? Or is it only good for underdriving 5 Q5’s?
18sixfifty
Flomotion wrote:
Correction:
- Voltage: 5V-8.4V
Won’t work…
P = A x V
15watts = 4.5 × 3.3
Thanks I actually do have that driver on the way. Now I’m wondering if there is anything I can do with this one other than tossing it in a drawer or maybe using it as a contact board.
mattthemuppet
Last seen: 5 months 6 days ago
screw a series of cheapo Nichia 119 LEDs to a chunk of aluminium, wire ‘em in series and hook the driver up to a decently chunky wall wart of the appropriate voltage. Then hang it above wherever you’re working and you’ll have an awesome work light Smile
there can never be a part that will be unused, only a part that you haven’t thought how to use yet!
18sixfifty
Right on!
Tom E
Tom E's picture
Last seen: 1 hour 7 min ago
18sixfifty wrote:
Flomotion wrote:
Correction: That Driver puts out 17.5 Volts http://img.dxcdn.com/productimages/sku_26106_2_small.jpg - Output current: 17.5V(800mA) with 5*P4/5*Q5 emitters - 26mm diameter base, 13mm overall depth - Voltage: 5V-8.4V - Mode: High 800mA±20mA; Mid 450mA±20mA, Low 210mA±10mA; Fast Strobe 400mA±20mA; SOS:800mA±20mA - Memory: fastter than one second is changing mode; slower than 1~2 seconds is stocking memory Won't work... This is the Driver You Want: http://intl-outdoor.com/xml-multicell-circuit-board-45a-ouput-55126v-p-5... !http://intl-outdoor.com/bmz_cache/6/60518a94b0f6392d133fa3ba363e477b.ima...! P = A x V 15watts = 4.5 x 3.3
Thanks I actually do have that driver on the way. Now I'm wondering if there is anything I can do with this one other than tossing it in a drawer or maybe using it as a contact board.
This is a buck driver all the way. You should have more cells than LED's for this driver. I know - hhhm, me thinks I went thru 3 already, 3 more laying here. Ohh - also it's the same, exact, I mean specifically, driver as the LCK-LED 5A one, just the LCK-LED has more resistors piled up. So, Hank, I guess in his wisdom, had them change or add more resistors to go from 3.5 to 4.5A, otherwise, same exact driver.
This is the driver I've been using in the Shocker, although, with 3 cells, 3 LED's it goes into direct drive mode, but you still get the 3 modes -- well used to at least...
gadabout
Last seen: 1 week 4 days ago
there can never be a part that will be unused, only a part that you haven't thought how to use yet!
Hmmm...
I think that kind of attitude is why I fear I'll one day end up making a guest appearance on "Hoarders" Laughing
mattthemuppet
gadabout wrote:
Hmmm…
I think that kind of attitude is why I fear I’ll one day end up making a guest appearance on “Hoarders” Laughing
it’s a fine line, that’s for sure. Almost everything I hoard comes in useful eventually. This morning, for example, I used some very thing enameled wire that I kept from salvaged laptop batteries to fix the back light cable in my laptop. Saved me $60 right there, though in exchange for a couple of hours very tense scraping and soldering Smile
the only thing I struggle to use are CW LEDs that I swap out for nicer tints. I usually just give those away.
18sixfifty
gadabout wrote:
Hmmm…
Dedome them CW’s and you will get more throw and much better tint.
mattthemuppet
I might try that, but I do like the (slightly) better colour rendering and contrast from NW LEDs.
Gtamazing
Gtamazing's picture
15 watts boost driver. I’d try it on the 12v MKR with 2 lithiums
Bort
Bort's picture
Last seen: 10 hours 41 min ago
your tossing and i just bought some cool white xm-l2 i like lights with maximum lumens
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 3 years 1 month ago
Vinh is getting over 1700 lumens on his 6.5 amps TN31 XM-L2.
18sixfifty
I’m not surprised at all. I have a T-90 with a XM-L2 that I am running at 7 amps and it’s amazing how much light it puts out. It took me a bit to get the focus right but man does it throw, it’s de-domed and the reflector is 70mm so the beam it very tight. Just unreal that it can be run with that many amps.
ILIKEFLASHLIGHTS
I should add that I am talking about a dedomed XM-L2.
ILIKEFLASHLIGHTS
Here’s some lumen numbers from rdrfronty for his vinhnguyen54 modded TN31 de-domed XM-L2 6.5 amps.
Level 1 – .4
Level 2 – 18
Level 3 – 471
Level 4 – 1050
Level 5 – 1515
Level 6 – 1740
