Test/Review of Sibeile IMR18650 2200mAh (Black)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 2 min ago
DSC_3077
Official specifications:
  • Model: 18650 li ion battery
  • Brand: Sibeile li ion battery
  • nominal capacity: 2200mAh
  • nominal voltage: 3.7V
  • battery material: Li-ion rechargeable battery
  • positive pole: Flat top
  • rechargeable battery: Up to 500 times
  • impedance: cycle life: >500 Cycles
  • Operation temperature: Charge(0 ~ 45°C)Discharge(-10 ~ 60°C)
  • Storage Temperature: -20 ~ 45°C
  • Dimension: Diameter 18mm, Height 65mm
  • Weight: About 46g
Sibeile%20IMR18650%202200mAh%20(Black)-info
DSC_3044 battery%20pack-1
After shipping the samples to me, some print was added to the box.
DSC_3078 DSC_3079
DSC_3080
DSC_3081
Sibeile%20IMR18650%202200mAh%20(Black)-Capacity
Fairly good tracking between the batteries and they work up to 7A.
Sibeile%20IMR18650%202200mAh%20(Black)-CapacityTimeHours
Sibeile%20IMR18650%202200mAh%20(Black)-Energy
Sibeile%20IMR18650%202200mAh%20(Black)-PowerLoadTime
Sibeile%20IMR18650%202200mAh%20(Black)-TripCurrent
Sibeile%20IMR18650%202200mAh%20(Black)-Charge
Conclusion
The battery has good capacity, but there is a slight difference between the batteries, I will rate it as acceptable.
Notes and links
The batteries was supplied by Sibeile for review.
djozz
djozz's picture
Last seen: 12 hours 15 min ago
Thanks for the review again Smile , it looks like a decent battery.
What would your guess be?, does this Sibeile company rewrap Panasonics and other batteries (because some perform very similar to existing batteries) or do they make (some of) their batteries themselves? And if they just rewrap, why does such a company exist?
The chinese ways are very unclear to me...
HKJ
HKJ's picture
I expect they rewrap, these type of companies are all over the world, not only in China.
While doing the rewrap they often add some value, like protection or button top.
Another job, that some rewrap companies does, is select the good Chinese batteries.
