C3 SS driver burned out, modding suggestions?
17 posts / 0 new
SirJohn
SirJohn's picture
Last seen: 8 years 4 months ago
Put a 14500 in my C3 SS today, turned it on and got a flash and then no more.Yell
I guess it is now modding fodder. Give me some suggestion as to what would be some beginning mods for me to try that would work on a C3SS. I'll try them the next time I have access to a soldering iron, or is there a module that will just screw right in to a C3 SS?
Edited by: SirJohn on 05/24/2011 - 19:43
brted
brted's picture
Last seen: 2 days 2 hours ago
I have an Aurora SH-035 which is just like the C3. It uses a 17mm driver which is rare for AA lights, but perfect for modding since a lot of 17mm drivers are available.
SirJohn
SirJohn's picture
Can anyone suggest a good, cheap driver for the C3 SS? Preferably one with pre-soldered wires sinceI wil be new at this. Also, I know that heat may be an issue, but should I try an R5 upgrade as well? Will an XP-G R5 work with the stock reflector or not? Since I would have to resolder the wires to the star with the new driver anyway, it wouldn't be hard just to remove the old star and put in an XP-G star would it?
I need some tutorials.
Budgeteer
Budgeteer's picture
Last seen: 8 years 2 months ago
If you want li-ion only try the universally good AK-47.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
JohnnyMac
JohnnyMac's picture
Last seen: 2 weeks 10 hours ago
For driver I'd go with this: http://www.shiningbeam.com/servlet/the-133/3-dsh-Mode-Regulated-Circuit-Board/Detail
or this one if you still want the option of using AA cells: http://www.shiningbeam.com/servlet/the-252/**NEW**--3-dsh-Mode-Regulated/Detail
For emitter go with an R4 or R5. Not sure the emitter diameter but it's eith 14mm or 16mm. If it takes a 17mm driver then I'm sure it'll take a 16mm star.
Neutral R4 16mm: http://www.shiningbeam.com/servlet/the-24/**NEW**-Cree-XP-dsh-G-R4/Detail
Cool R5 14mm: http://www.shiningbeam.com/servlet/the-23/cree-R5/Detail
Getting all of this from ShiningBeam will get you exactly what you ordered at a good price and with the fastest delivery. You could always just get another C3 for about the same price but it wouldn't be as nice and it wouldn't be "yours". Smile
Good luck!
LIght_Of_Day
Last seen: 1 year 4 months ago
I don't know much but the non-stainless c3 that I have went south and the driver in it is way smaller than the 17mm ones that are so common. Take it apart and measure the size of the driver that you need. If you find one that fits let me know because I think this is the issue here.
JohnnyMac
JohnnyMac's picture
Agreed. My suggestions were based on Brted's observation that it should be 17mm. My experience with AA sized lights is that they use 15mm drivers. The 14mm R5 is still a good suggestion for emitter. Decent 15mm drivers are a harder animal to find.
15mm Single mode: http://www.dealextreme.com/p/2-7v-6v-3w-cree-circuit-board-for-flashlights-15mm-2-7mm-25518
brted
brted's picture
Unscrew the pill out of the C3 and measure the diameter of the board in there. Because it has an oversized head, it could be 17mm, but maybe not. I think Shininbeam's drivers have leads soldered in place already, but you will have to do soldering no matter what. An emitter swap is easier than a driver swap, but then you need some thermal adhesive. If you're removing the old driver, it might be easier to go ahead and unsolder the leads where they connect to the LED first. Then you can remove the driver (the amount of slack in those leads inside the pill isn't known and when you pry off the driver board from the pill, sometimes you end up ripping the leads out anyway).
Most of the 17mm drivers won't work with a single AA battery because they don't boost voltage.
SirJohn
SirJohn's picture
This driver says it is 15mm, not 17mm. Is that correct?
JohnnyMac
JohnnyMac's picture
Correct. Now that I think about it that is the driver I installed in my Sipik SK68 to make a multi-mode instead of single. A great driver, easy to install with the leads pre soldered. Grab that and the 14mm R5 and in a week you will have your C3 running like a champ.
JohnnyMac
JohnnyMac's picture
And measure the existing driver before ordering just to be sure. Also, I am sure your emitter is fine so if you're really strapped for cash you can replace just the driver but since your in there anyway... Wink
soytnly
Last seen: 5 years 4 months ago
[/quote]Agreed. My suggestions were based on Brted's observation that it should be 17mm. My experience with AA sized lights is that they use 15mm drivers. The 14mm R5 is still a good suggestion for emitter. Decent 15mm drivers are a harder animal to find.
[/quote]
I just used this driver to replace a fried driver in a Sipik SK58 - you're right, they are hard to find.  This one is good, I now have a 14500 Sk58 that's much much brighter than the original (it was very disappointing initially).
Dave
SirJohn
SirJohn's picture
[/quote]Correct. Now that I think about it that is the driver I installed in my Sipik SK68 to make a multi-mode instead of single. A great driver, easy to install with the leads pre soldered. Grab that and the 14mm R5 and in a week you will have your C3 running like a champ.
[/quote]
Do you find that the 1amp on high rating is pretty accurate or does it drive higher or lower than that?
JohnnyMac
JohnnyMac's picture
I never measured it but Manafont's drivers are rated very accurately from what I hear and I saw an improvement when I changed the driver. With an R5 attached to it I'd guess it will pull even more. Even at 1000mA an R5 should put out 350+ lumen.
trooplewis
trooplewis's picture
Last seen: 2 years 2 months ago
Was yours the 98mm version or the 93mm version?  I'm wondering if I should run 14500 battery in the C3 SS I got today from DX. It is the 98mm version with an XR-E in it.
Rats, finally sold my 2010 509hp Mustang...now I can buy more lights!
Sold the red one too! Now guess what I drive, doing my penance for 500 hp commuters...
http://dreammustang.com/
http://i884.photobucket.com/albums/ac47/Ha
SirJohn
SirJohn's picture
Mine was the 93mm version from Lightake.
Davx
Davx's picture
Last seen: 5 years 9 months ago
Seems that DX version works with both 14500 and AA. Other seller have a different version (often 93 mm) that can use only AA. It's not the first fried driver...
"There are always new jobs, women, and apartments......there is only ONE BLF." - Chicago X (27/03/2012)
