Enlan EL-01. Outstanding knife
150 posts / 0 new
Thoth
Thoth's picture
Last seen: 9 years 5 months ago
jekostas wrote:
Thoth, what did you grind with?
Since this was a small job I did it by hand with sandpaper and leather.
First I started by sanding the shoulder between the primary and secondary bevel with 400, I did this using a piece of thick leather as a backing to the sandpaper. The give of the leather behind the sandpaper naturaly creates the convex curve in the edge. Some people use a foam mouse pad instead of leather, but I find that the foam is to soft and the end result is a deep convex, stronger but with inferior cutting performance, good for big choppers and less appropriate to a folding knife.
Then I repeated the process with 600, 800 and 1000 sandpapers.
In the end I stropped in leather with coarser polishing compound then finally with fine polishing compound.
The hole process took aprox. 30 minutes.
Match
Match's picture
Last seen: 5 years 9 months ago
That is a good method, Thoth.  I sharpen my Khukri's the same way, but use the mousepad method.  Like you said, it's good for big choppers.
boomhauer
Last seen: 7 years 2 months ago
Would it be quicker, and perhaps more precise, to use a sharpening system like a Gatco to file a shallower fixed angle at first, to remove the shoulder, and then go to leather/sandpaper to finish the convex?  Or are you counting on the compliance of the leather for the entire process to get the correct curvature?  Was just wondering about my ability to accurately free-hand for the entire procedure.
Thoth
Thoth's picture
I assume that you could use that system, but I dont think that it would be faster, since each stage with the sandpaper wont take more than 5 minutes, plus as you pointed out I count on the compliance of the leather for the entire process to get the correct curvature.
In my experience leather (3 or 4 mm thick) has the right amount of resistence to give a optimal curvature, without having to be very carefull with the pressure applied in the process. You could achieve the same result using a mousepad, but because it is softer one must take care not to apply much pressure, or the result will be a deeper convex and you can easily round the tip of the edge.
If you never tryed it before and dont want to risk the new knife, train on a old knife even a kitchen knife will do. If you start with 600 or 800 sandpaper the process will be slow enough so that you can observe and correct any mistake.
This process seems to be more complicated when reading it, than it really is in practice.
Watch the video that I embeded earlier in this thread and you will have a very good understanding of the procedure, the guy even uses a small microscope to show macros of the edge. Smile
boomhauer
Thoth, thanks.  I'll have a go at it with one of my larger, less coveted blades.  One trick I use with my conventional file sharpening system is to paint the edge with a black marker to help establish the correct file angle.  This might also be useful as a visual aid for gauging the progress of a convex edge.
Thoth
Thoth's picture
Yes you can certainly do that.
I find the sharpening one of the most interesting aspects of owning knives, it's a very rewarding feeling when one master the different techniques.
maico
Last seen: 10 years 7 months ago
I'm struggling to open the Pdf diagram of the axis lock patent to compare it to the SRM one, do you need to subscribe ?
http://www.patentstorm.us/patents/5755035/fulltext.html
boomhauer
Just got mine.  Wow.  Fit and finish are as good as any SRM/LAND/Bee knife I've gotten recently.  Great value.
Don
Don's picture
I don't have a clue about sharpening. Any chance of an article about how to do it?
I'd be very interested in reading it..
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
devman
Last seen: 7 months 2 weeks ago
I see this same(?) knife listed on the sanrenmu.com site as the "EL-01 Commando"
Are Enlan/Sanrenmu the same company, or is one sourcing theirs from the other?
Smelly
Last seen: 9 years 9 months ago
Enlan is a separate company from Sanrenmu/Land.
All the "Athletic" models displayed on the Sanrenmu website are Enlan models.
According to the guy that runs Exduct (I've forgotten his name), "sanrenmu.com/en" is not an official Sanrenmu website.
devman
Wow.  I assumed it was their real site.  Ah well, that makes my life simpler.  Now I only have to look for one knife*, and not be worried that there are two similar knives Silly  Thanks, smelly
*for now
raccoon city
raccoon city's picture
Last seen: 8 hours 57 sec ago
...According to the guy that runs Exduct (I've forgotten his name), "sanrenmu.com/en" is not an official Sanrenmu website.
According to the eBay seller sanrenmu.knife (who has the eBay store Knife.Made.in.China) Sanrenmu's official (Chinese) home page is http://www.srmknives.com, but unfortunately that site cannot be opened at the time of this posting.  Enlan's official home page is  http://enlanknives.com  Wink
Vectrex
Vectrex's picture
Last seen: 1 year 1 day ago
I updated my overview post a bit with manufacturer links.
boomhauer
This sounds like an excellent topic for jekostas's knife primer thread.
Thoth
Thoth's picture
I can try to write something about the topic, but it will take some time especially because it is not easy to convey in words techniques that consist primarily in hand movements.
It would be much easier if I could link to some already nicely made videos on youtube.
KumaBear
KumaBear's picture
Newbie Here: WHY IS CONVEXING A GOOD THINK?
Regards,
Bob
KumaBear
gcbryan
Last seen: 10 months 3 weeks ago
Regards,
Bob
I think it’s primarily for two reasons and those are simplicity and economy. It’s easy since you don’t have to worry about matching a bevel angle and it’s inexpensive since you can get a “scary sharp” blade just using sandpaper.
gcbryan
Regarding the thread topic…this really is an outstanding knife.
I didn’t like the look of this knife (before I got it) initially I think because of the flat spot on the spine of the blade.
Once it came out in rosewood I liked the looks and now that I have it I can really appreciate the attention to detail in the design.
The flat spot serves as a thumb rest, there is jimping just behind that, there is jimping on the liner lock for the forefinger, more jimping toward the back of the liner for the last two fingers and yet more jimping on top near the back where it contacts the heel of the palm.
No thumb stubs to snag a pocket or to make sharpening more difficult since it uses a flipper which in itself also serves as a finger guard both while in use and upon closing.
My blade is perfectly centered and hair cutting sharp.
This has to be the best of the budget knives.
Gurthang
Last seen: 3 years 4 months ago
GC,
I’ve got several Enlans on order from Lazy Lizard [JoBen] including the 01. Can’t wait for them to arrive. I’ve got to study the “convexing” video so I can use that technique. All the users / reviewers have high regard for the Enlan/Bee knives so I’m really stoked to begin using them.
Woody
Woody's picture
Last seen: 1 month 1 week ago
I just ordered one of these from Exduct. I realise it won’t be UK edc legal, but it just struck me that it may be illegal fullstop. Is there any likelihood of UK Customs confiscating this?
I certainly don’t plan to carry it, just want it on my boat to cut rope in an emergency. What are the chances of it actually arriving?
Don
Don's picture
It is an assisted opener. Under UK law that’s a totally illegal flick-knife and may well be confiscated. If they check the package.
They may, or may not do so. Just don’t get stopped by a cop with it on your person. I believe that’s 5 years in prison these days.
Any assisted opener is liable to confiscation by the UKBA – Think TSA without the niceness…
Americans are much nicer people than Brits.
Assisted openers from DX don’t arrive. Form other places they may, or may not.
Bitter experience.
Don
Don's picture
Mine got here no bother (Can’t now remember where it came from) – but no assisted opener from DX ever did.
Woody
Woody's picture
Oh sh1t!! I clearly didn’t read the thread properly, and just thought it sounded handy. Didn’t realise it was an assisted opener (even I sussed out that assisted opener meant flick knife). Not sure I want it now – good job, as I probably won’t get it!
Thanks Don – I’ll try reading with my specs on next time.
Steve_the_Chief
Steve_the_Chief's picture
Last seen: 2 years 9 months ago
Don wrote:
It is an assisted opener. Under UK law that's a totally illegal flick-knife and may well be confiscated. If they check the package. They may, or may not do so. Just don't get stopped by a cop with it on your person. I believe that's 5 years in prison these days. Any assisted opener is liable to confiscation by the UKBA - Think TSA without the niceness... Americans are much nicer people than Brits. Assisted openers from DX don't arrive. Form other places they may, or may not. Bitter experience.
Not familiar with UK laws, but I was under the impressions that assisted openers use some kind of spring mechanism to open the blade, which the EL-01 doesn't.
It's basically just like any other one-hand-opener, only with a flipper instead of a thumbstud.
Don
Don's picture
But under UK law, any assisted opener is a flick-knife. The rules are crazy, but I didn’t make them.
Blame the moral panic around “knife crime” on our scummy tabloids.
Steve_the_Chief
Man, that's crazy.
I'm not particularly fond of the german kife laws either, but at least they male a difference between mechanically opened and assisted/automatic knives.
Don
Don's picture
Steve_the_Chief wrote:
Don wrote:
It is an assisted opener. Under UK law that’s a totally illegal flick-knife and may well be confiscated. If they check the package. They may, or may not do so. Just don’t get stopped by a cop with it on your person. I believe that’s 5 years in prison these days. Any assisted opener is liable to confiscation by the UKBA – Think TSA without the niceness… Americans are much nicer people than Brits. Assisted openers from DX don’t arrive. Form other places they may, or may not. Bitter experience.
Not familiar with UK laws, but I was under the impressions that assisted openers use some kind of spring mechanism to open the blade, which the EL-01 doesn’t.
It’s basically just like any other one-hand-opener, only with a flipper instead of a thumbstud.
More than one shipment containing assisted openers has been opened by UKBA and the knives confiscated.
Like I’m about to stab anyone. The penalties for using such a device and being caught here start at 5 years in prison….
And given the hysteria about “knife crime” here (Read up on “moral panic” and “UK Tabloid” to see what a crappy place the United Kingdom of Great Britain and Northern Ireland can be) just don’t get caught.
I’d rather get caught with a Type 56 loaded than a flick-knife. The penalties would be lower.
And anything semi-automatic with a calibre larger than .22 is completely illegal since Barry Ryan went postal in 1987. Handguns became completely illegal after Thomas Hamilton in 1996. I was about 5 miles from Dunblane at the time.
Handguns are now absolutely banned here. More than a decade in jail for being caught with one.
Speedsix
Some Enlans are better than others. The EL-01 is a good knife for a large heavy folder. I wish they wouldn’t use those goofy pivot screws. What’s wrong with torxs or Allen heads?
gords1001
gords1001's picture
Last seen: 3 years 7 months ago
They don’t even like knives that can be one hand opened here – thumb studs, spyder holes etc, all are frowned upon. Sad :~ don’t even get started on locks, sheath knives, machetes, kukri’s.
In my other hobby (off roading, green laning, wheeling, call it what you will) the advice is to carry a bill hook rather than any kind of knife as its a gardening tool…. It’s also an f off stick with a blade on the end, but who am I to argue….
