Test/Review of Keeppower IMR18650 2000mAh (Black) 2014
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 3 days ago
DSC_4407
Official specifications:
  • Brand Name: KeepPower
  • Type: Li-Ion
  • Cell: Made in Korea
  • Maximum Constant Discharge Current: 22A
  • Min Capacity: 2000mAh
  • Typical Capacity: 2000mAh
  • Normal Voltage: 3.6V
  • Quality Lithium Ion rechargeable cell made in Korea
  • Maximum Capacity and Reliability
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Button top: Yes
  • Dimension: (D)18.50mm*(H)66.90mm
  • Weight: 46.0g
Keeppower%20IMR18650%202000mAh%20(Black)%202014-info
This is a unprotected high current cell.
DSC_4406
DSC_4408 DSC_4409
DSC_4410
DSC_4411
Keeppower%20IMR18650%202000mAh%20(Black)%202014-Capacity
The cells tracks fairly well and has nearly full capacity up to 20A.
Keeppower%20IMR18650%202000mAh%20(Black)%202014-CapacityTimeHours
Keeppower%20IMR18650%202000mAh%20(Black)%202014-Energy
Keeppower%20IMR18650%202000mAh%20(Black)%202014-PowerLoadTime
Keeppower%20IMR18650%202000mAh%20(Black)%202014-TripCurrent
Keeppower%20IMR18650%202000mAh%20(Black)%202014-Charge
Conclusion
This is a very good high current battery.
Notes and links
The battery was supplied by Keeppower for review.
cellguy
cellguy's picture
Last seen: 2 years 10 months ago
Did you happen to remove the shrink wrapped and look at the internal cell?  I am assuming this is a KP branded Samsung 20-R.  I inquired directly with KP and never received a response.  Looking at your comparator the results seem to prove out the theory.  Since there is no protection circuit I am not sure why the KP brand is worth a premium.  Interestingly enough, the 20-R OEM is no longer listed on the KP site.
Current Favorites:
BLF Q8, Thrunite TC20, Convoy L6
HKJ
HKJ's picture
No, I did not remove the schrink wrap. One thing you pay for where these cells is the button top.
cellguy
cellguy's picture
Good point, I had not consider that.
Current Favorites:
