Test/Review of Review/Test of 17mm 2-Mode LED Driver Circuit Board for Flashlight DIY
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 days 16 hours ago
DSC_4041 DSC_4042
DSC_4043 DSC_4044
Driver is from Fasttech.com
Official specifications:
  • Product Type: Flashlight Driver
  • Constant Current: Yes
  • Driver Type: Direct drive
  • Input Voltage: 3-4.2 -volt
  • Flashlight Modes: Hi > Lo
  • Mode Count: 2
  • Depth: 3 mm
  • Diameter: 17 mm
  • Product Weight: 0.7 g
  • Suitable for single lithium battery
  • Great for DIY project or repairing your flashlight
  • Battery over-discharge protection kicks in (cuts off power) when input voltage drops to 3V to 3.1V
Measurements
Tested with: Cree XM-L2
Diameter: 17mm
Height: 3mm
Modes: Low, High
Driver changes mode with each turn on.
Low is with pwm at 207Hz and 17% duty cycle.
Driver is direct drive.
DC resistance in driver is about 0.18 ohm at 2A (Measured directly at the driver pcb).
High
17mm%202-Mode%20LED%20Driver%20(GK-003A6)%20HL
This driver is only a direct drive driver, i.e. it is only a switch with a bit of resistance in. This means that the input and led current is the same (The curves are on top of each other) and the voltage/current curve will be very close to the led voltage/current curve.
I did not test higher than 3.9 volt, because the led is specified for 3A and I passed that at 3.9 volt (Most LiIon batteries will be below 3.9 volt when loaded with 3A. See my comparator for actual data).
I cannot see any traces of a low voltage protection, but the led by itself will to a large degree protect the battery.
17mm%202-Mode%20LED%20Driver%20(GK-003A6)%20HLDriver
17mm%202-Mode%20LED%20Driver%20(GK-003A6)%20HLLed
17mm%202-Mode%20LED%20Driver%20(GK-003A6)%20LH
Starting from a low voltage, shows that the driver starts at around 2.9 volt.
17mm%202-Mode%20LED%20Driver%20(GK-003A6)%20LHDriver
17mm%202-Mode%20LED%20Driver%20(GK-003A6)%20LHLed
High%203.6V
Being direct drive, the driver does not add any noise to the current.
Low
The power and efficiency calculations does not work here, the efficiency will be very close to the high efficiency
17mm%202-Mode%20LED%20Driver%20(GK-003A6)%20HL%20low
The average current goes down when the led is switches on/off at a fast rate.
17mm%202-Mode%20LED%20Driver%20(GK-003A6)%20HL%20lowDriver
17mm%202-Mode%20LED%20Driver%20(GK-003A6)%20HL%20lowLed
Low%203.6V
The actual pwm frequency is about 207 Hz (The dip in the pulses is due to my power supply, not the driver).
Conclusion
This is a simple driver with limited applications, i.e. only LiIon batteries and led must be suitable for direct drive.
I wonder why the driver has two IC's, it is probably a microprocessor and a EEPROM (For remembering mode), but why use an external EEPROM when most microprocessors has one build in.
Notes
How do I test a led driver
List of all tested drivers
Ledsmoke
Ledsmoke's picture
Last seen: 1 year 3 months ago
Thank you for the test HKJ.
Maybe they are using up spare stock that has become obsolete or something. Sure seems strange when you explain it like that why they should use 2 IC's...
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
Werner
Werner's picture
Last seen: 2 years 2 weeks ago
These atmel EPROMs are used a lot on drivers, I always wonder why? Maybe that is kind of recycling old EPROMs which no one wil buy, just solder them in devices and ship them in the west…
