Dual driver mods for single XM-L2's
29 posts / 0 new
18sixfifty
18sixfifty's picture
Last seen: 2 years 1 month ago
I’m sure someone has tried this already but I just wanted to report on a couple mods I have done with this dual driver mod.
The first was a courui big head mod. I wasn’t happy with the first driver and the XP-G2 was just too much of a pencil thin beam. So I took it out and dropped in an XM-L2 and two 8 chip njangs. High medium and low. They fit in nicely and rock the house.
I did the same thing with a ZY-T08. Only this time I used two 2,500mAh direct drive drivers from Fast Tech. I modded both drivers by jumping the three resistors that are in a row on it. I used the driver as a contact board and slaved both of them. I also potted them while I was at it.
Both lights are pumping out close to 1,500 lumens on high. The Courui is around 300kcd and the ZY-T08 is around 220kcd.
This seems to be a rather easy way to get 6amps out of batteries in parallel to a single emitter.
I’ll report back when I have run them for longer to tell you guys how well the emitters stand up to this high of amps. Both emitters are on 20mm Sinkpads and epoxied down with Wakefield Deltabond.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
Tom E
Tom E's picture
Last seen: 2 min 40 sec ago
I'm confused how you wire these things up, and why, if any, advantage there is to using 2 Nanjg's instead of piggybacking chips. I think others are doing the same thing, but I don't get it - don't understand details on the wiring and details of why there is an advantage, if there is?
Are these XM-L2's de-domed? Those throw #'s sound de-domed, and if so, the 1,500 lumens is really nice! So I'm guessing you would be getting very close to a true 6A to the LED.
18sixfifty
Tom E wrote:
I’m confused how you wire these things up, and why, if any, advantage there is to using 2 Nanjg’s instead of piggybacking chips. I think others are doing the same thing, but I don’t get it – don’t understand details on the wiring and details of why there is an advantage, if there is?
Are these XM-L2’s de-domed? Those throw #‘s sound de-domed, and if so, the 1,500 lumens is really nice! So I’m guessing you would be getting very close to a true 6A to the LED.
Yep de-domed and I’m sure I’m at right at 6amps. I have to be for the numbers I’m seeing.
Wiring is fairly simple really. Just using the existing driver slave four wires. Two positives and two negatives to the tops of the small drivers. With the 20mm sinkpads you have four contact points so there is your four spots for wires from the two drivers.
The advantage for me is not having to stack the chips, which I can’t stand doing. Plus I’m thinking it must be easier on the drivers themselves less heat from only pushing three amps each rather than six amps through one driver. Possibly even easier on the emitters because of less surging when changing modes. I’m getting zero flickering during mode changes.
The direct drive 2,500mAh driver had three resistors that totaled 6.7 when I measured them all at once. I’m not sure exactly what that would bring the driver up to once I jumped them. 3.17? 6.34 total minus loss.
Maybe comfy will chime in and explain this a little better.
Tom E
Tom E's picture
Ok - my bad, I'm still not getting it. Let's just take the 2 Nanjg setup as an example, because I know these drivers well (not really I'm think'n now). You have the stock driver still present, but it's only a contact board - I understand that so far. Now: "Just using the existing driver slave four wires" -- what is that? What does this mean?
Also, which of the Nanjg's is controlling modes? Are they both so they would have to be programmed the same?
Sorry - I'm having the same problems following comfy and others - it's something in the language used I'm not familiar with or understanding... I understand a bunch of things bout these drivers, but apparently have a ton more to learn... comfy is specially difficult to follow (though I love the comfy!) - he throws a picture or statement out there (classic teaser) and leaves me hang'n. Where? How? etc.... If he does explain, I can't follow it all anyway, so maybe not so bad... Frown
18sixfifty
Yes slaving just means using negative and positive contact points on the back of the driver (after wiping it clean) and wiring them to the negative and positive contacts on the next driver. Nothing on the original driver is used at all so it’s not doing anything really. (well I do save the parts in case I need them for something else)
Yes both have to be the same mode. I messed up one and forgot to solder the third star. It was pretty funny how it worked.
To be honest I didn’t know if I would actually double the amps or not. I was afraid they would somehow sense the amps and shut off at 3amps. But they didn’t!! I don’t know if this will work with all drivers or not.
Now I’m wondering if it would work to run a MT-G2. Unless someone stops by and tells me it won’t work, I’ll probably try one on a SRK. I have a good reflector for them that fits in the SRK. It’s for a P7.
http://dx.com/p/52-75mm-aluminum-reflector-for-ssc-p7-led-emitters-12229...
Legolas Jr.
Legolas Jr.'s picture
Last seen: 1 week 1 day ago
So, do you wire both of the Nanjg’s in parallel to the contact board, or are they attached together?
“Strive to be a warrior and a scholar. Be forged in fire and tempered by knowledge. If not, you will either lack the courage to fight for your ideals or lack ideals worth fighting for.”
Tom E
Tom E's picture
Ok - so this is pure, true parallel drivers. Battery + split out to the 2 drivers, Battery - (ground) to the 2 drivers, output LED + and output LED - of both drivers going to the LED.
Effectively this results in the same voltage getting to the LED, but adding the amps up for each driver. Hhmmm. Thinking heat related issues of the 7135's is better because spread over 2 boards - more paths, as opposed to piggybacking on 8 chips to one board. Not sure about the relationship of volts/amps. I would speculate since the LED is getting high amps (about 6A), that the Vf would be driven a little higher too, so not sure if it would help in lowering overall driver/circuit resistance -- can't be sure. Think comfy and others may know this - understand a whole lot better.
This true parallel wiring of drivers is opposed to the Nanjg master/slave wiring, which basically uses a second Nanjg as a farm of 7135's to effectively add amps to the primary Nanjg. This is the master/slave relationship I understand. The "contact board" technique I didn't think was called master/slave, because when the original driver is used as a "contact board", nothing electronic is used off the original driver - it's just used to contact with the batteries and provide the + and grounds contact points.
Another variation is using the power (generated output) of the original stock driver, and using a "slave" board to control the output via it's own PWM (mode control). This design I think is specific to the original driver, and this is what comfy and werner have been working on with a couple (at least) lights.
So I think you came up with a 4th variation here.
Edit -- Wait... If both driver put out PWM's, it's impossible to time sync them?? So mid, low modes would be kind of funky?
18sixfifty
Tom E wrote:
Ok – so this is pure, true parallel drivers. Battery + split out to the 2 drivers, Battery – (ground) to the 2 drivers, output LED + and output LED – of both drivers going to the LED.
Effectively this results in the same voltage getting to the LED, but adding the amps up for each driver. Hhmmm. Thinking heat related issues of the 7135’s is better because spread over 2 boards – more paths, as opposed to piggybacking on 8 chips to one board. Not sure about the relationship of volts/amps. I would speculate since the LED is getting high amps (about 6A), that the Vf would be driven a little higher too, so not sure if it would help in lowering overall driver/circuit resistance — can’t be sure. Think comfy and others may know this - understand a whole lot better.
This true parallel wiring of drivers is opposed to the Nanjg master/slave wiring, which basically uses a second Nanjg as a farm of 7135’s to effectively add amps to the primary Nanjg. This is the master/slave relationship I understand. The “contact board” technique I didn’t think was called master/slave, because when the original driver is used as a “contact board”, nothing electronic is used off the original driver – it’s just used to contact with the batteries and provide the + and grounds contact points.
Another variation is using the power (generated output) of the original stock driver, and using a “slave” board to control the output via it’s own PWM (mode control). This design I think is specific to the original driver, and this is what comfy and werner have been working on with a couple (at least) lights.
Edit — Wait… If both driver put out PWM’s, it’s impossible to time sync them?? So mid, low modes would be kind of funky?
Ok I see, it’s me using the term slave wrong.
As for PWM, I’m not a person who is sensitive to it. But I just went and ran the shower to check it out against a stock C12. The C12’s PWM was way more noticeable to my eye. Maybe when they are out of sync it’s not as bad because one driver stays on so there is no actual “off” for that tiny bit? So I guess it would be faster but less noticeable. I don’t know what effect this would have on someone who is sensitive. Might be good might be bad. We would have to talk someone who is PWM sensitive into trying it.
I took the light out and played with it last night while it was snowing and didn’t notice the PWM at all. But, like I said I’m not sensitive to it so I’m not looking for it.
18sixfifty
Parallel.
comfychair
comfychair's picture
Last seen: 5 years 6 months ago
Using two drivers in parallel, while both still have functioning MCUs, can cause problems. If you've ever had two identical lights with identical drivers, set them to strobe, and let them run a while, they go out of sync. Like a twin engine boat with the throttles not set right. No way around it, it's caused by just the slight variation between the cheap parts used on the drivers. The real problem is in the lower modes. If your low mode is 15% PWM, it'll be fine when both drivers are on at the same time and off at the same time, but when they get out of sync the light output will cycle around bright and dim and all over the place.
Best to only have one controller for all the boards. All the common small drivers just use one output pin on the MCU to drive the thing that regulates the current (whether that's a 7135 or a SOIC8 FET or a TO-252 FET, they all use a PWM signal to control what the LED is doing), you just have to find which pin it is and add a jumper from the brain board over to the dummy board that's had the MCU removed. With common drivers it's easy, they've been poked and prodded enough that all the pins and traces are well known already. With others it's just a bit of poking around with a DVOM.
The slave/brainless drivers do not need any connection to BAT+, all these drivers only regulate through the negative path, between LED- and ground (and any fancier driver that doesn't work like that shouldn't be used for this anyway). At high currents (and why else would you do this?) running the BAT+ through a driver's PCB can be a restriction; the brain-board only needs a tiny bit of BAT+ to run the MCU, nothing else on the board uses any positive voltage at all. Run the main LED+ wire around the drivers and straight to a big fat connection to the battery, then split off that point with just a small wire to feed the single MCU.
This is, essentially, a master/slave setup just like two 105Cs. Just that 10 of the chips happen to be on a board that's not a 105C. All the pins and traces do the same things. (the red wire from the BAT+ pad to underneath the 105C is only there to feed the MCU, it has nothing to do with the BAT+ to the LED at all)
http://75.65.123.78/Dsc06334annotated.jpg
This is all you need to do if you want the easily programmable attiny with a nice UI to control a totally different driver:
http://75.65.123.78/Dsc06964.jpg
http://75.65.123.78/Dsc06989.jpg
http://75.65.123.78/Dsc07005.jpg
18sixfifty
Thanks for the info Comfy. How long does it take for the PWM to get wonky? I have this one sitting here on low right now for about 10 minutes and it’s just a nice steady low. Did I just get lucky with this particular driver? I’ll leave it running and see but so far I can’t notice anything wrong with it at all.
comfychair
There can also be a spread between the time measured for a half-press, if you always stay inside the window for both drivers when changing modes it'll be fine but if by chance you get too close to the time limit one can change modes while the other one doesn't. The issue with 'potential problems' is that it may work perfectly fine, right up until it doesn't...
18sixfifty
comfychair wrote:
There can also be a spread between the time measured for a half-press, if you always stay inside the window for both drivers when changing modes it’ll be fine but if by chance you get too close to the time limit one can change modes while the other one doesn’t. The issue with ‘potential problems’ is that it may work perfectly fine, right up until it doesn’t…
Thanks again, I’ll keep this thread updated and post if I have any problems. I messed around with it quite a bit and now I’m giving it goofy half presses and still no problems. Supper fast changing, clicking it on and off rapidly over and over still no problems.
This is the driver I’m using. I jumped one of the three resistors on the bottom. Between the three the registered something like 6.7 before jumping them.
http://www.fasttech.com/products/1612/10001713/1124800-2500ma-5-mode-led...
comfychair
http://75.65.123.78/1124800-2.jpg
Old-Lumens
Old-Lumens's picture
Last seen: 4 years 11 months ago
I don't know if these diagrams help, but here's how I use more than one NANJG style driver with one led.
dr1
dr2
dr3
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
18sixfifty
Thanks old lumens, great info.
FlashPilot
FlashPilot's picture
Last seen: 1 day 13 hours ago
Thanks for the great posts. This sure takes most of the guess work out of paralleling these drivers.
Tom E
Tom E's picture
Thanks OL - this takes the guess work out of the wiring. I like the idea of running the battery + directly to the LED(s), so there is no flow through high resistance traces on a driver. Also, the way it looks, the slave 7135's should have better heat dissipation paths than if stacked all on one board because of the additional tracings and wiring of the slave board?
RMM
RMM's picture
Last seen: 1 year 9 months ago
I was also gonna say that it works great with an MT-G2.  I've done it in a ZY-T08 and I think that Old-lumens has done it with several of his builds (including the recent Courui MT-G2 mod).
Mountain Electronics : batteries, Noctigon, and much more! What's new?
18sixfifty
RMM wrote:
I was also gonna say that it works great with an MT-G2.  I’ve done it in a ZY-T08 and I think that Old-lumens has done it with several of his builds (including the recent Courui MT-G2 mod).
Excellent. Thanks for letting me know this. I was going to try it with a MT-G2 in a SRK. Extra heat sinking of course.
RMM
RMM's picture
You can see the drivers in this thread.
18sixfifty
Hmm, thanks. I did see that but I assumed it only worked because he was using 8volts.
Can this work with 18650’s in parallel?
Old-Lumens
I believe it helps. It sure couldn't hurt. I have come to the point where I don't want to stack any more unless absolutely necessary and if I do, then I want a copper wrap to help with the heat.
Old-Lumens
18sixfifty wrote:
Hmm, thanks. I did see that but I assumed it only worked because he was using 8volts. Can this work with 18650's in parallel?
The drivers are in parallel. The batteries are in parallel series only because I need the voltage thru the chips. Otherwise, as long as the drivers are master slave, the batteries can just be parallel for a 3.xx volt led.  The master has the zener mod, to protect the mcu and the 7135 chips do need extra heat sinking. If not, the light gets dim very quickly, due to reduced 7135 output. The last time I tried using .010" thick copper sheet and wrapped the drivers, soldering the copper to the tabs of the chips and it seemed to help a lot.
18sixfifty
Old-Lumens wrote:
18sixfifty wrote:
Hmm, thanks. I did see that but I assumed it only worked because he was using 8volts. Can this work with 18650’s in parallel?
The drivers are in parallel. The batteries are in parallel series only because I need the voltage thru the chips. Otherwise, as long as the drivers are master slave, the batteries can just be parallel for a 3.xx volt led.  The master has the zener mod, to protect the mcu and the 7135 chips do need extra heat sinking. If not, the light gets dim very quickly, due to reduced 7135 output. The last time I tried using .010” thick copper sheet and wrapped the drivers, soldering the copper to the tabs of the chips and it seemed to help a lot.
Thanks again this helps a lot. Your pics in particular were fantastic.
nwonknu
Last seen: 7 years 2 months ago
Is there any change when connecting these drivers to 2x XML’s?
Cereal_killer
Cereal_killer's picture
Last seen: 1 year 11 months ago
Do you want to combined the output’s and then run the emitters hooked in parallel or do you want each individual driver to run one emitter independent of the other (but still controlled from only one MCU)?
nwonknu
I don’t know, what is the best way to do it?
My setup is 2x XML-U2, 1× 32650 battery and I’ll order 2x NANJG 2.8A drivers.
Ledsmoke
Ledsmoke's picture
Parallel the drivers like 18sififty and parallel the led´s too. Should give no issues.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
