[Review] NITECORE HC90 (XM-L2 T6 / 5mm RGB LEDs, 1x 18650 / 2x (R)CR123a)
24 posts / 0 new
UPz
UPz's picture
NITECORE HC90
LED: CREE XM-L2 + 3× 5mm Color LEDs
Battery: 1× 18650 / 2x ®CR123a
Modes: Variable magnetic control.
Switch: Electronic (Magnetic Slider)
Date: April 2014
Links:
Nitecore Global / Nitecore UK / Flashaholics.co.uk / RdL / ForoLinternas
INTRODUCTION:
Following the launch of the first dedicated headlamp few months ago by the Nitecore brand, just arrived the second raid by the famous Chinese manufacturer in the headlamps range. The Nitecore HC90 is similar in design to the HC50, but incorporates some new interesting features, such the magnetic control and the ability to stepless adjust the light output. Another interesting function implemented in this new proposal by Nitecore is embedded battery charging through standard microUSB port, as well as incorporating RGB multicolor light through three small LEDs of 5mm and a maximum output much higher than the previous base model HC50.
The product packaging is very similar to what we saw in the HC50 , and common in design and presentation to the recent launches of the brand. The Nitecore HC90 comes in a compact cardboard box printed in full color with the usual colors of the brand, including a brief description of the product and some of its specifications.
Inside the headlamp unit is accompanied by a similar to HC50 the elastic bands, a set of replacement o-rings, USB-to-MicroUSB cord and including extra dust-cover-plug for charging port, and the usual documentation with an user manual in English and SYSMAX warranty card.
EXTERIOR FINISH:
Construction of HC90 headlamp is quite broadly similar to that we saw with the HC50 , with identical optics characteristics in the center of a large passive heatsink integrated into the front of the headlamp featuring a mono-block design.
On one side of the optics, we find the three small RGB LEDs in charge of the color lighting. Unlike SRT series, rather than using 5mm RGB LEDs , this time each of the three small LEDs emit only one color, largely avoiding the typical aberrations caused by the eccentric position of each die within encapsulated.
White light is provided by XM-L2 T6 CW located behind a small, very shallow smooth reflector, which is hold in place by a flat bezel and AR coated glass.
At the top of the unit we find a sliding part made of yellow plastic. Through this piece we can select the mode, sliding to the right for different colors, or left to adjust the brightness of the XM-L2.
The slider runs smooth and has several detents in strategic position. The track comes generously lubed from factory, and is extremely comfortable to adjustment with one hand, easily detecting the various detents (more details in the user interface section below).
At one end of the headlamp there is a cap whereby we access the interior of the battery compartment. This cap has square cut and anodized threads. The negative contact is made by a gold platted spring located in the cap, while the positive is at the bottom of the housing for the battery and has a mechanical protection against reverse polarity.
Although I have not had problems using flat top batteries like NCR18650A , the reverse polarity protection system makes using button top batteries recommended. There is enough to room for accommodate protected batteries up ~ 71mm long.
At the opposite extreme is another of the most interesting developments implemented in the HC90, an integrated charging port with microUSB connector. The port is protected by a silicone dust cover, and features a translucent lining allowing you to see the light of the charging status indicator small red LED.
The elastic bands are very similar in length and quality to the HC50 , with a generous section and very good elastic properties, so the weight of the headlamp when installed in our head and adjusted the bands is well distributed. Unlike the HC50, the front unit clamping is made by a part of semi- rigid plastic which is installed directly on the headlamp , and which has a curvature designed to successful engage our forehead comfortably .
The elastic band is between this piece and our forehead skin, avoiding friction with the semi – rigid plastic support and ensuring optimal support and nice comfort.
USER INTERFACE:
The Nitecore HC90 has a simple user interface , wherein the magnetic slider takes all the merit. In addition to the three modes of light color, we have stepless brightness adjustment for the XM -L2 allowing us to fine adjustment the light output between 0.2 and 530LM. There is an extra position on the left end of the slider rail, with a detent, reserved for the Turbo mode.
  • Standby / OFF position: Right between the red LED detent and the beginning of the variable slider, there is a position in which the headlamp is off/standby.
  • Variable white light mode: Moving the slider to the left, we enter the variable output mode setting for white light. We can select the output that suits us better for any situation, within the range between 0.2 and 530LM, point at which the slider has a detent. There is approximately 25mm of travel, so finding the right output is easily archived.
  • Turbo Mode: Located at the left end of variable adjustment, we have an extra position beyond the detent for the High mode, in which the headlamp enters turbo mode, with 900 Lumen. This mode is located at the top left end of the slider, so it is easy and fast to access it from any position.
  • Auxiliary light color modes: From the standby position, moving the slider to the right are three detents, each corresponding to an auxiliary color LED. The first detent is the red, then the green and the next on the right end of the slider gives access to blue light.
  • Mechanical block-out: The headlamp can be blocked by the thread to avoid parasitic consumption that is always present in this type of tools that lack a mechanical switch. After checking with a fully charged battery I get a measurement of between about 8 mA for the first 30 seconds after a sudden drop to ~0.18mA . Nitecore mention in the user manual refers to this block-out, recommending it if we are not using the headlamp over a long period of time, also indicating that the current needed to maintain alive the HC90 interface should take 6000 hours (about 250 days) to completely drain an 18650. This obviously also prevent accidental activation of the headlamp when we carry it in a backpack or pocket.
  • Integrated charger: The HC90 features an integrated charger, allowing us to recharge the 18650 battery installed without removing it. This charging system is powered by a microUSB port and can be connected to any USB common power supply, such as a wall charger for Smartphone or Tablet , a USB port of a PC, a powerbank … The charge current is limited to 500mA ( 515mA according to my multimeter) regardless of input system specifications we use, so fully charge a 3100mA 18650 battery will takes more than 6 hours. The final charge voltage to the battery is 4.2V, and shows a correct CC/CV algorithm , gradually decreasing current when charging reaches ~4V, to finish charge properly. The charging port is equipped with a red LED that will inform us of the state of charge through various sequences: One blink approximately every 2 seconds denotes a charge in process, rapid blinking a problem with the battery (charge stopped) and if the light remains steady on indicates that charging is complete.
NOTE: Although the HC90 can be powered by one 18650 battery, two primary CR123a or two rechargeable RCR/16340 , the system only supports charging 18650 battery.
(All measurements are taken following the ANSI NEMA / FL1 procedure using a peak measurement between 30 and 120 seconds after activation. More details in my ForoLinternas thread.)
As happened with the HC50 , measured in integrating sphere performance is somewhat above that specified by the manufacturer, reaching a staggering 1040LM after 30 seconds of constant power at its Turbo mode, and close to 600LM for High mode.
PERFORMANCE:
The HC90 inherited basic version HC50 temperature control, which replaces the usual time controlled stepdowns (typically 3 minutes), and offers a more dynamic performance depending on the environment in which we use the headlamp. Thus, the thermal sensor inside the guts of the HC90 makes this reduces its light output when it reaches a temperature above 55 ° celsius.
In the graph we can see two separate tests, one with the headlamp at room temperature and another in which I’ve have helped with a small fan to keep the temperature down. You can clearly see as at room temperature and without the fan, at about 10 minutes of continuous use the headlamp exceeded 55 degrees Celsius and lowered its output from Turbo to High mode, where thanks to the lower current has been capable of lowering the temperature again and Turbo mode automatically entered into action. These ups and downs are performed gradually (making a sort of fade in and fade out) and are hard to notice by the naked eye.
Compared with the performance of HC50 , this new HC90 shows step forward in efficiency , obtaining a very similar type of runtime thanks to the nonlinear regulation which Nitecore has provided in its configuration for a 18650.
BEAM PROFILE:
The beam profile of the HC90 is almost identical to that already seen in the HC50 , at 100 º angle of light output, with a huge hotspot and a generous peripheral light , covering a wide illuminated area . Thanks to the extra output, the throw is now 110m and 3.000cd (NEMA ANSI FL1), 25 extra meters than the HC50.
The XM-L2 T6 tint is cold, with a familiar yellowish hue in the gradient between the hotspot and spill.
The auxiliary color lighting has surprised me with homogeneous beam, as Nitecore has chosen to use each of the three 5mm LEDs for a specific color, instead of using RGB LEDs (able to offer three colors in a single package) such as used in SRT range. Having single DIE, small 5mm LEDs offer a pretty good projection and almost free of any ring or artifact.
PERSONAL CONCLUSION:
Broadly speaking, the HC90 comes to offer a more complete alternative to what its basic version, the HC50 offers some spot functional improvements and robust and easy to use design.
Negatives: In the now common trend in the use of colored light , the HC90 offers a much better performance than seen in other same brand flashlights, such as SRTs, but still a step behind in efficiency and performance than theoretically could be achieved with CREE RGBW powerLED. I wonder what would have been the result would have become if instead of using the three 5mm color LEDs, they installed instead a XM-L Color behind a small aspherical lens, offering the same range of color, but incorporating the CREE power and efficiency, way above the unfortunately usual 5mm LEDs.
Positives: I especially liked how easy and intuitive it is to take control of the headlamp, thanks to the well-designed slider system. As in the HC50, simple and robust design is one of its virtues, and the successful combination of hybrid beam profile, capable of offering a floody projection but without giving up a decent range due to huge hotspot. Temperature control rather than time is something we are all looking forward to evolve and be incorporated into other models of the brand, thus avoiding those unnecessary stepdowns when the actual temperature of the unit can hold it. Efficiency seems to be one step ahead of the previous version, sacrificing the linearity of its output (in its version for 18650) for excellent runtime. The 5mm LEDs beam is, fortunately, not as bad as expected, having seen how it performs in the SRT range. The USB compatible charging port is a great improvement that allows us to maintain our headlamp always charged and ready by using our Smartphone or tablet charger adaptor, without carrying a dedicated charger or extra batteries. The design of the elastic bands makes the weight distribution very nice, forgetting in a few seconds you have it installed on your head. In short, if the budget allows, the HC90 is a recommended option that for sure will please all who try.
Nitecore HC90 headlamp provided by Nitecore.co.uk for review. Thanks!
Edited by: sb56637 on 09/02/2017 - 12:28
Jerommel
Jerommel's picture
Last seen: 4 days 16 hours ago
Great interface!
It’s what I would like to have on torch.
(A slider or a thumbwheel)
UPz
UPz's picture
Thanks for reading!
DayLighter
DayLighter's picture
Last seen: 5 years 8 months ago
Thanks for the review.. I was debating if I should get this as I already have Nitecore HC50.
Is it possible for you to provide outdoor beamshots? Big Smile
The only way to do a great work is to love what you do.
M4D M4X
M4D M4X's picture
thanks for the review!
btw: at Hkequipment.net with Code “ncusbhl” for 82 $ shipped
was on stock yesterday Wink
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
UPz
UPz's picture
DayLighter wrote:
Thanks for the review.. I was debating if I should get this as I already have Nitecore HC50. Is it possible for you to provide outdoor beamshots? Big Smile
Sorry, not possible for now Sad
Already having the HC50, think that the beam profile is 100% identical, with an extra output, and 25 more meters of throw based on power and not reflector form.
Thanks for your comment!
Racer
Racer's picture
Last seen: 6 years 7 months ago
Thank you for the review. So, no PWM like the HC50? What are your thoughts on the robustness of the slider? Looks like it would pick up lots of dirt and debris. I also wonder if it can be re-greased since friction grease has a limited life span. That HC90 looks like some hot action, but that slider just looks a little dicey, especially with the lube exposed on the top. I think I’ll give this model a while and see what people report about the slider after lots of use.
UPz
UPz's picture
Unlike SWM control rings, this slider doesn’t use friction grease for retaining the position. It has some sort of spring loaded pin inside, so it stops in detents and stay in place betwen the variable output track. The grease is just for smooth operation, and won’t be hard to re-lube with the usual superlube-silicone grease-teflon based grease if necesary.
If I find time, I’ll try to dissasembly the slider and share some pics of its internal contruction.
djozz
djozz's picture
Last seen: 2 hours 27 min ago
very nice review on a very nice headlamp. This is almost everything I would want from a headlamp Smile
roberta
Last seen: 5 years 2 weeks ago
Good Day Señor UPz, Smile
Arrow Right Great review :exmark:
Btw, I have the Nitecore HC90, & I am VERY Happy with its features & functionality.
Muchisimas Gracias,
Roberta 0:)
Greetings from The Land Downunder
_the_
_the_'s picture
Last seen: 7 months 5 days ago
Thanks for the great review!
This headlamp looks very very nice! A bit on an expensive side, but still.. very intriguing.
[Goes to PM section and starts chatting with Neal..]
Edit: Got a good deal, see here.
=the=
blfdemigod
blfdemigod's picture
Last seen: 5 years 1 month ago
Great review. I know this is wrong, and should be commenting about the HC90, but would you mind telling me what headlamp that is next to the 18650 here. It's very sexy!
My collection 2 Small
Disclosure:
_the_
_the_'s picture
Looks like a Spark SG3 to me.
=the=
Ramblings
Ramblings's picture
Last seen: 2 weeks 4 days ago
I really like Nitecore. Like, really. My P25 is by far my favourite single 18650 light (well, on par with my ZL SC600 L2 even though the P25 is only XM-L)
I also have a HC50 which I am more than happy with.
But to me the HC90 looks really cheapo.
You are the light of the world. Like a city on a hill, you cannot be hidden.
People do not light a lamp and then hide it away, instead they put it where it gives lig
leaftye
Good review.  Thanks for sharing.
A color XM-L emitter would have terrible white output.  I doubt it could hit 500 lumens even if it was overdriven on a direct bond copper star, and there's very little chance that a big manufacturer will over drive an emitter in a headlamp, so it would still need to have a regular white emitter for decent white light output levels.
I like the slider idea, although a bearing and spring for tension scares me a bit since that can get gunked up and nasty with use.  If that's easily removeable for cleaning and replacement, then that's not a big deal.  I look forward to seeing what you can find out.
While this light seems like it would be a very nice headlamp, I'm not sure I can buy it.  It's too much of a gamble.  I tend to hike with my headlamp in my hand, which is easy with a right angle lights like Zebralight and Armytek make.  I'd hate to fork over the money for the HC90 to find that I won't use it because it's not easy to use in my hand, which it probably is since that headband looks like a hassle to remove.  It's also very heavy compared to its competition, and I'm weight averse.  I might give it a shot if Illumination Supply ever has a killer deal on it though.  Hopefully the competition figures out how to add a nice UI with stepless dimming without all that weight.  Dual or triple buttons would do it.  Have a top button like Armytek, but add another button on the bottom.  Those will be up/down dimming buttons.  If there's a third button on the side it'd be for on/off and changing mode groups.
The low mode should be lower.
UPz
UPz's picture
My point is: Replace the 3 color LEDs with a single XM-L color LED with small aspherical lens or diffuser lens for full flood, but keep the XM-L2 white light dedicated emitter.
Color output will be better (depending on the color, but way more lumens on any) and you will have the extra white flood from the XM-L color.
Never meant to use only the XM-L color Silly
blfdemigod
That's a really good idea UPz. Have both XM-L2 and an XM-L Color right beside it. I built a flashlight a while back with the Xm-L color, and is was pretty nice. I really liked the red,blue, and green colors that it put out. As for the white, well, I believe I had the int-outdoor driver and was pretty weak, maybe 750mah for each light color. Wasn't impressed at all with the white. But your idea is very good, maybe you should tell Nitecore!
Also, it would be really cool if they could do it in a zebralight round tube format, with anti-roll bezel, and not the square shape the HC-90 is, but still having the XM-L2 in the middle, and the XM-L color right next too it! Now that, I would buy!
Disclosure:
UPz
UPz's picture
Don’t worry, Nitecore is reading this so it is up the them.
I am also waiting for the Intl. Outdoor driver to build my own RGBW light. 8)
vēer
vēer's picture
Great review as usual, UPz ;)!
_the_
_the_'s picture
Got mine yesterday.
The tint is nice for a CW, so I'm not sure whether to swap in a L2 4D or not. Maybe soon..
As I like very floody headlamps, the hotspot was initially too narrow and bright to my liking.. But that's not a problem, as a small piece of diffuser film (similar to DC fix) on the lens made it much better. Anyways, this light is floodier as stock than my Crelant CH10 and diffuser film works better on this one => HC90 wins, hands down.
The slider UI works very well and the low mode is definitely low enough.
All in all, a great headlamp. Already loving it. Smile
=the=
Overclocker
bull$hit!
as usual, nitecore FAKES their runtime graphs. same thing happened w/ their HC50. fabricated graphs that aren’t even close to resembling their actual performance.
they have to stop doing this or they’ll lose their credibility Sad
dangerous
dangerous's picture
Last seen: 7 years 12 months ago
I love the HC90. It is too floody for my taste, but I knew it would be that way because of the shallow reflector. The slider is poorly made and controlling precise brightness levels is not great, but it works. The build quality besides the slider is excellent as one would expect from nitecore. Highly recommended.
BLF
matula
matula's picture
Last seen: 6 months 1 week ago
Could you recommend lights that have a similar control slider, but are cheaper?
UPz
UPz's picture
Maybe someone knows some but I can’t recall any budget slider-controlled lights.
