18650 powered soldering iron?
10 posts / 0 new
Speedsix
Last seen: 7 months 5 days ago
I’m looking for a good battery operated soldering iron for work. I would only need it for an occasional electronic solder, nothing serious so 10-15 mins runtime would be fine.
It doesn’t have to be 18650, AAs will work if there are any good ones. A co worker has a 4 AA unit he got at Radio Shack for like $20. It seems to work ok but 18650 would be better.
atbglenn
atbglenn's picture
Last seen: 3 years 7 hours ago
I bought a Hakko FX-901 several months ago. The build quality is decent. Runs for about an hour continuously with 4 AA Eneloops. It's not designed for heavy duty soldering, but for normal light duty, up to #16 wire, it's more than capable. I bought mine on ebay for around $31
http://www.hakko.com/english/products/hakko_fx901.html
Boycott Nike
Pulsar13
Pulsar13's picture
Last seen: 1 month 1 week ago
I have a couple of hobbyking’s 3xAA. They’re cheap, yet works pretty good.
http://hobbyking.com/hobbyking/store/__24757__Portable_Battery_Powered_S...
http://hobbyking.com/hobbyking/store/__39433__Portable_Battery_Powered_S...
I modded them to use single 14500 (4.2V) and another 2×14500 (8.4V). My favourite is the 8.4V – draws 2.3A, heats up to solder temp well under 10s. You do get only around 10min working time though, but since it heats so quickly you need only 20-30s per joint.
Speedsix
It’s been a year since I first asked about an 18650 iron. I still haven’t found one but its screaming to be made. Anyone see one yet?
ryansoh3
ryansoh3's picture
I’ve seen a DIY soldering iron powered by a 18650 battery pack (6-8 cells IIRC) on a Korean forum, but nothing commercially.
Here are two that I’ve found with a quick search.:
https://www.kickstarter.com/projects/249225636/cordless-3d-print-finishi...
http://www.bunnings.com.au/tradeflame-3-76v-li-ion-cordless-soldering-ir...
BLF ≠ B-grade Flashlight Forum
LSX
LSX's picture
Last seen: 2 days 15 hours ago
Can you use a gas one?
I use a Snap On YAKS32A butane powered iron (25-125w). Have been extremely happy with it! Not overly cheap though.
Casemods
Casemods's picture
Last seen: 2 weeks 2 days ago
Any updates? Looking to get into soldering.
Lumintop: Fw3a XP-L HI 3D 5000k, B01, fw21 x9l SBT90.
D4v2 sst20 4000k, FF e01 sst40w n5 5700k, olight s2r b2 cu, s2+ cu sr, s2+ sr, c8, BLF A6 3d, acebeam pt40 sst20 95cri, YLP panda 3r
East bAy area, California
thefreeman
thefreeman's picture
Last seen: 5 hours 34 min ago
There is the Pinecil, powered by USB-C or barrel jack :
Quote:
USB type C: PD and QC 3.0 12V-20V 3A
Barrel Jack: DC5525, 12V-21V DC 3A
Therefore usable with a USB C power bank, a li-ion battery or wall plug.
Plus it uses TS-100 cartridges which are pretty good (infinitely better than classic tips)
homegrown
Last seen: 2 weeks 1 day ago
My first post:)
I am a fan of Ryobi 18v one plus battery tools. So far I have only used (and own) their pruning and digging gear for the garden and an amazing and very bright Hybrid Worklight, which with the battery out, accepts an AC plug for power (in Australia at least).
I have noted that they have two soldering irons that plug into the same batteries. I will report back if and when I trial either.
https://www.ryobi.com.au/power-tools/products/list/category/soldering-irons.
Amazing forum, thanks all.
Casemods
Casemods's picture
homegrown wrote:
My first post:) I am a fan of Ryobi 18v one plus battery tools. So far I have only used (and own) their pruning and digging gear for the garden and an amazing and very bright Hybrid Worklight, which with the battery out, accepts an AC plug for power (in Australia at least). I have noted that they have two soldering irons that plug into the same batteries. I will report back if and when I trial either. https://www.ryobi.com.au/power-tools/products/list/category/soldering-irons. Amazing forum, thanks all.
The $85 cordless solder thing is $50 at home depot.
I was actually going to grab one today to try out, since I have a ryobi to dewalt adapter. I have the ryobi single hand inflator and glue gun. Both work great so far. Im still a dewalt guy but I buy other brands if they make something dewalt doesn’t make.
