Tiny led voltmeter - help needed in finding the smallest one
54 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 4 years 4 months ago
Hi,
I want to put a volt meter in a light using 2S Li-ion. I remember a long time back, someone on CPF had come up with a tiny one and they used it in a Maglite body. I would love to find the smallest one possible, even if it's just something that would only light if the voltage dropped. I have seen some with led readouts, but they are just too big at 30mm or so.
Anyone have any suggestions on anything very small? (less than 20mm)
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 05/05/2014 - 22:35
AlexGT
AlexGT's picture
Last seen: 4 hours 43 sec ago
wight
Last seen: 1 year 1 month ago
I’d say you want a 2s lipo alarm. Unfortunately most of the modern ones are built for connecting to the balance connector of a battery pack, you won’t have that (a tap between two two cells). It looks like this one is widely available though:
Doohan 2S Audible Voltage Lipo Alarm
Just remove any buzzers / LEDs you don’t want.
The first place I looked was at Hobbyking but it looks like they only carry the balance tap ones these days.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 11 months 1 week ago
I use these, very good little voltmeters, won’t power up unless there is 3.2vdc however
I have one tied into one of those cheap portable power units to monitor the voltages going to the battery
https://www.fasttech.com/p/1222900 <-blue
https://www.fasttech.com/p/1222901 <-green
https://www.fasttech.com/p/1222902 <-red
wight
31mm is too big…
Helios-
Helios-'s picture
ebay.com/itm/LED-Battery-level-voltage-monitor-meter-indicator-Alkaline-Nicad-NiMh-LiPo-L
For the smallest one possible you could have someone make you one using a dedicated voltage monitor chip. They can light up an indicator led when the voltage drop to the level the chip is preset for. 3.0v Voltage Monitor
Counterfeit 18650s, 2,<a href=“http://
wight
Wow, that one’s really sweet Helios-. Where did you come across that?
WarHawk-AVG
Yeah they are…that’s pretty cool!
AlexGT
AlexGT's picture
This is the one jayrob over at CPF uses on his mag mod with voltmeter in this thread
http://www.candlepowerforums.com/vb/showthread.php?335007-FS-1000-Lumen-...!
This is the voltage monitor used
http://www.wr-store.com/product_info.php?cPath=21&products_id=104
HTH
AlexGT
Helios-
Helios-'s picture
I don’t recall. i came across it some time ago. Its sort of expensive for what it is IMO.
Old-Lumens
Thanks for the ideas. Helios- Love those links.     AlexGT- Yep, that's the thread, Thanks.
larryk
Last seen: 4 days 2 hours ago
These are what I use on some of my spotlight builds. They are smaller at 23mm X 15mm X 10mm, but might fit in a Maglite. They are cheap and work great.
http://www.ebay.com/itm/gib-Mini-Digital-Voltmeter-DC0-100V-LED-Panel-Voltage-Meter-with-Three-Wires-/171124030115?pt=LH_DefaultDomain_0&var=&hash=item27d7c97aa3
Rufusbduck
Rufusbduck's picture
Last seen: 2 weeks 1 day ago
For just a single 3-5mm panel led could you use an op amp and a few resistors? Might fit on a small board ~ 15mm.
Edit-Like this maybe Matt could help you with the board
Scott
islisis
Last seen: 5 years 1 month ago
seems these days programmable drivers offer a lot of flexibility…it might be possible to program one of these drivers to get the functionality needed
http://budgetlightforum.com/node/30788
re. Star firmware: http://budgetlightforum.com/node/29150
Rufusbduck
Looked up the data sheet on the 3.0v voltage monitor linked by Helios and found this schematic
Looks pretty simple to use for just one led.
Scott
Helios-
Helios-'s picture
Thats whats so nice about them. Tiny, easy & uses very little current (0.5 uA typ). Also don’t need to be able to program chips. Just connect the voltage monitor chip, indicator led & resistor (aim for <50mA led current).
Haven’t ordered one yet since the attiny can do low voltage detection.
antoninodattola
Last seen: 2 years 1 month ago
Pulsar13
Pulsar13's picture
antoninodattola wrote:
http://www.ebay.com/itm/micro-3-digits-0-28-LED-DC2-7-30-0V-variable-precision-GREEN-Digital-voltmeter-/251359299908?pt=LH_DefaultDomain_0&hash=item3a862e8944
I ordered one weeks ago, I think it is the smallest, with digits
Whoa that is small – size of a sim card. I looked around – cheapest is $5 shipped for these (vs $1.40 for the bigger guy), quite a jump in price for tinyness.
Interesting why the red is always cheaper than green/blue version – easier to build due to Vf probably?
Old-Lumens
I like the readout style over the lights. It's larger, but if I can fit it in, I will use the readout style. I don't really need a low voltage warning, I just think a readout of voltage would be kind of different.
Jerommel
Jerommel's picture
Last seen: 11 months 3 weeks ago
Cheapest I could find:
RED:
http://www.ebay.com/itm/0-28-Digital-Panel-Meter-DC-2-5V-30V-Red-LED-Power-Monitor-Lithium-Car-Motor-/251303490316?pt=LH_DefaultDomain_0&hash=item3a82daf30c
Starts as low as 2.5V
YELLOW:
http://www.ebay.com/itm/0-28-Digital-Voltmeter-Power-Monitor-DC-2-6-30V-...LED-/390625402570?pt=LH_DefaultDomain_0&hash=item5af3169eca
Starts at 2.6V
Pulsar13
Pulsar13's picture
Found some better prices now, $1.90 for red to $2.46 for blue:
http://www.ebay.com/itm/gib-Two-Wire-0-28inch-LCD-Mini-Digital-DC-Voltmeter-Gauge-Voltage-Detector-/171173023012
I don’t think they get cheaper than these. I’m probably going to grab some afterwards. I already have the bigger version in many colours, and I must say the blue LED is the most beautiful – kind of classy, expensive looking.
WarHawk-AVG
Dang! Making em smaller and smaller!
Chloe
Chloe's picture
Last seen: 4 years 9 months ago
The numerical LED blocks are standard size. Three digits is too wide (>20mm). Maybe replace it with two digit block if one decimal place resolution is acceptable?
The ones from gigibaobao are better quality than FastTech, with trim pot and work to lower voltage, but still too big.
Another idea, maybe use two or three of the kind Helios posted set to different voltages?
antoninodattola
It would take an OLED monitor this type of PLX
http://www.plxdevices.com/product_info.php?id=MOBLLEGION055
What do you say to use the monitor like that?? I think you can try!
definitely finding the lowest prices!
http://www.fasttech.com/products/0/10007685/1665901-vstar-s7-0-6-oled-variable-voltage-apv-mod
Old-Lumens
I never thought of OLED! Gotta research that!
antoninodattola
look forward to hearing from you!
Ricflair
Ricflair's picture
Last seen: 2 years 4 months ago
I ordered a few of them from Fasttech and they won’t read voltage until it rises above about 3.3 volts. They do work great for RC lipo monitoring & portable solar cell and checking batteries in the field with out lugging a huge Fluke meter.
RicFlair is on the air with blonde hair & pink underwear!! Whaoooooo!
scottyhazzard
scottyhazzard's picture
Last seen: 1 year 11 months ago
That’s James Bond kinda cool!
"Those who hammer their guns into plows will plow for those who do not."
WarHawk-AVG
Here is a “tindie” build with an OLED display…perhaps something can be modded up
https://www.tindie.com/products/FriedCircuits/usb-tester-oled-backpack-w...
Adaruits
https://www.adafruit.com/products/661
128×32 SPI OLED graphic display
Even smaller
http://www.buydisplay.com/default/96×39-pixel-0-83-inch-small-oled-disp...
96×39 Pixel 0.83 inch Small OLED Display
Smaller still
http://www.buydisplay.com/default/oled-display/64×48-dot-matrix-0-66-ol...
scottyhazzard
18.4 × 18.1mm, that last one is really cool but how the heck do you program it for a voltage readout?
WarHawk-AVG
That is why the adafruit has the control board breakout
needs a tiny circuit to run it…and firmware
