Having read many threads. I think these are the two in the finals. Argument is welcome. Below is my perception from reading all those threads. I may easily have got some things wrong. From lack of proper understanding, or just getting confused with all the reading.
VP2:
- Seems to be the most versatile if you have no interest in non-Lithium chemistries (I don't need a charger for that - I have one).
- It takes long protected 18650 and CR123.
- Apparently very accurate and excellent analysis capabilities.
- Up to 1A charge current.
- Will physically accept CR123 cells but I am not sure it has a way to provide the proper voltage.
- Has 2 slots and costs more than the Opus BT-C3100
- Half the maximum charging current of the Opus BT-C3100
- With an adapter, this would NOT be suitable for charging C and D NiMh cells. Not really a negative - just a neutral point for completeness.
Opus BT-C3100:
- 4 slots
- Cheaper than VP2 with twice the slots and twice the max charging current in 2 slots.
- Takes larger diameter batteries in two slots.
- With an adapter, this would be suitable for charging C and D NiMh cells. With higher current than my existing NiMh charger.
- Shipping with V2 firmware, but that has not fixed all the problems
- Power supply is being upgraded but still seems too small for full rated charging current because of peak demand pulses from charger.
- I believe I have seen reports of one slot overcharging batteries.
- Charging voltage switches accessible only by opening the case. What were they thinking? Yes it lowers build cost, but?
- No identified way to apply a firmware upgrade in the field or other methods.
- Hardware issues with excessive current pulses exceeding the capability of the power supply. May require an upgraded unit to perform properly.
- Will not accept CR123 ? - not positive - from what I gather there are two parameters; ability to physically accept the cell and suitable voltage.
- Annoying approach to cooling fan operation. Instead of on and off it should be always on and use variable speed control.
- Apparently not as intuitive or extensive functions/controls as VP2.
- It will not physically allow some protected 18650 cells.
My inclination at this point: VP2. If the Opus unit was at firmware release 3 and hardware release 2; I would go that way (after seeing tests).
