AWT cells and charger data (and other cell comparisons)
These AWT products were received free of charge for the purpose of testing. There was no agreement made to do a public test(s) or review(s), but the generosity from AWT deserves at least an honest comparison and tests to be posted publicly.
Here is their Alibaba page, but it is full of a bunch of other products thats not theirs
http://aweitebattery.en.alibaba.com/
MAH and internal resistance comparisons:
Format will be:
Brand/model - Rated capacity (mah) - Actual capacity (mah) - Internal resistance (mR) - Notes
16340:
AWT IMR 16340 (#1) - 550 - 623 - 58 - Brand new
AWT IMR 16340 (#2) - 550 - 640 - 68 - Brand new
18350
AWT IMR 18350 flat top (#1) - 700 - 847 - 29 - Brand new
AWT IMR 18350 flat top (#2) - 700 - 835 - 29 - Brand new
AWT IMR 18350 button top (#1) - 700 - 845 - 35 - Brand new
AWT IMR 18350 button top (#2) - 700 - 854 - 34 - Brand new
EH IMR 18350 flat top (#1) - 800 - 812 - 67 - 10 to 20 cycles or so
EH IMR 18350 flat top (#2) - 800 - 783 - 74 - 10 to 20 cycles or so
18490 - 18500
AW IMR 18490 - 1100 - 1286 - 21 - Unknown cycles, received as part of a trade
AWT IMR 18490 (#1) - 1100 - 1284 - 21 - Brand new
AWT IMR 18490 (#2) - 1100 - 1300 - 23 - Brand new
AWT IMR 18500 (#1) - 1200 - 1384 - 18 - Brand new
AWT IMR 18500 (#2) - 1200 - 1306 - 24 - Brand new
Efest IMR 18490 v2 (#1) - 1100 - 1223 - 26 - About a dozen or so cycles
Efest IMR 18490 v2 (#2) - 1100 - 1176 - 28 - About a dozen or so cycles
18650:
AWT IMR 18650 30a (#1) - 2000 - 2185 - 18 - Brand new
AWT IMR 18650 30a (#2) - 2000 - 2219 - 15 - Brand new
AWT IMR 18650 35a (#1) - 2500 - 2603 - 18 - Brand new
AWT IMR 18650 35a (#2) - 2500 - 2641 - 20 - Brand new
Sanyo UR18650W2 (#1) - 1500 - 1553 - 25 - New B&D tool pack pulls.
Sanyo UR18650W2 (#2) - 1500 - 1596 - 25 - New B&D tool pack pulls.
Sanyo UR18650W2 (#3) - 1500 - 1546 - 28 - New B&D tool pack pulls.
Sanyo UR18650W2 (#4) - 1500 - 1604 - 24 - New B&D tool pack pulls.
Sanyo UR18650W2 (#5) - 1500 - 1545 - 24 - New B&D tool pack pulls.
Sanyo UR18650W2 (#6) - 1500 - 1597 - 25 - New B&D tool pack pulls.
Sanyo UR18650W2 (#7) - 1500 - 1562 - 24 - New B&D tool pack pulls.
Sanyo UR18650W2 (#8) - 1500 - xxxx - xx - Cell at 0.37v. Tossed.
Sanyo UR18650W2 (#9) - 1500 - 1518 - 26 - New B&D tool pack pulls.
Sanyo UR18650W2 (#10) - 1500 - 1596 - 21 - New B&D tool pack pulls.
Trustfire Flame (#1) - 2500 - 2536 - 117 - Old. Used and abused
Trustfire Flame (#2) - 2500 - 2593 - 84 - Old. Used and abused
26650:
AWT IMR 26650 (#1) - 3800 - 4422 - 24 - Brand new
AWT IMR 26650 (#2) - 3800 - 4417 - 26 - Brand new
Trustfire Flame 26650 (#1) - 5000 - 4492 - 35 - Protection circuit. Probably 25 to 50 cycles?
Trustfire Flame 26650 (#2) - 5000 - 4725 - 30 - Protection circuit. Probably 25 to 50 cycles?
Internal resistance consistency test:
For this test I will put one specific cell into each slot five times. I will leave it in the slot until it displays the internal resistance, pull the cell and wait about 5 seconds and repeat.
This first test was my very old and very abused Trustfire Flame 18650s:
Right slot: 126, 126, 126, 124, 125
Left slot: 124, 124, 121, 121, 121
This next test I used a brand new AWT IMR 18650 2500mah 35a cell:
Right slot: 18, 18, 19, 20, 18
Left slot: 15, 15, 17, 17, 17
As seen, the difference in results are about the same between the AWT and the TFF cells. The difference from left slot to right is also about the same in both tests. So it is possible to have about a 5mR difference between slots in each test. I am not sure how big of a deal that is, and I am also not sure if doing each test within 5 seconds was skewing the results. Maybe they were getting slightly charged or discharged, and not having time to rest back to its normal state.
Will be adding some data below, such as:
- Checking voltage of cells fresh off each of the chargers
- Maybe some tailcap readings from one of my XML2 lights to see if they push harder than my current cells
Anything else you guys would like to know, or see done to test the chargers or cells, let me know. I will do the best I can
