Test/Review of Cooper 300F supercap
22 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 20 hours ago
DSC_6365
Official specifications:
  • Rated capacity: 300F
  • Rated voltage: 2.70V
  • Absolute maximum voltage: 2.85V
  • Operating temperature range: -40°C to 65°C
  • Life: 10 years at 25°C and rated voltage.
Cooper%20300F%20supercap-info
Supercaps are a alternative to batteries at least in some cases, but their abilities are very different. I have performed the test as a battery test, making it easy to compare to batteries.
Something to note:
Supercaps has a fairly low voltage rating, for higher voltage they must be used in series and this will require a balancing circuit.
This type of supercap can handle extremely high current both charging and discharging.
The discharge and charge curve is linear and the capacitor can be discharge to zero without damage.
The capacitor has a fairly high self discharge.
DSC_4476 DSC_4479
DSC_4477
DSC_4478
DSC_4475
This supercap is roughly the size of a D cell, but the capacity and energy contents is much lower (about 1/10 of an AA cell).
Note: I cannot maintain the 20A discharge below 1.4 volt, at 1 volt it is about 15A.
Cooper%20300F%20supercap-Capacity
The discharge is very linear and can go all the way to zero volts.
Cooper%20300F%20supercap-CapacityTimeHours
Cooper%20300F%20supercap-Energy
Cooper%20300F%20supercap-PowerLoadTime
1 watt for about 15 minutes can the capacitor deliver.
Cooper%20300F%20supercap-TripCurrent
First test run discharged the supercap.
Cooper%20300F%20supercap-Charge
I only charge with 1A current, it is possible to charge considerable faster.
Conclusion
Compared to batteries the capacity is very low and cannot really replace a battery. It is more useful for high current pulses or equipment that only needs a low amount of energy and stays on a charger most of the time.
Notes and links
Battery test main index
A 3000F supercap
HKJ
HKJ's picture
Last supercap review, this capacitor is 1/10 of the other one: http://budgetlightforum.com/node/33167
Bort
Bort's picture
Last seen: 33 min 30 sec ago
Thanks for the review!
What brought you to supercap testing?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
HKJ
HKJ's picture
Bort wrote:
Thanks for the review! What brought you to supercap testing?
People that say then can be used instead of batteries. I did know that capacitors was considerable less, but I wanted directly comparable result.
Here is one of the silly examples: https://www.kickstarter.com/projects/shawnpwest/30-second-charging-recha...
He is using a better capacitor that the ones I have tested, but it is very far from being good enough (Probably 40F @ 3.8V).
Bort
Bort's picture
thats nuts, though i want to understand how only a few Wh can start a car
http://laserhacker.com/?p=110
https://www.youtube.com/watch?v=z3x_kYq3mHM
HKJ
HKJ's picture
Bort wrote:
thats nuts, though i want to understand how only a few Wh can start a car http://laserhacker.com/?p=110 https://www.youtube.com/watch?v=z3x_kYq3mHM[/quote]
What you need to start a car is lots of amps for a short time.
300A for 3 seconds at 12 volt is only 3Wh
Wh is measured over on hour and there is 3600 seconds in an hour, i.e. something that uses 300*12 -> 3600 watt, will only use 1 Wh each second.
lagman
lagman's picture
Last seen: 2 weeks 5 days ago
It’s not the Wh that matters to start a car, it’s the Watts (i.e. current) the battery can deliver.
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
lagman
lagman's picture
@HKJ: About that kickstarter project using supercaps:
I quite often hear people saying that one day we will have smartphones or electric cars that can be charged in 1-2 minutes.
Although the battery/capacitor technology may become available one day, what people don’t realize is that you would need an AC to DC transformer 10 times bigger than the smartphone or the car to achieve that.
Bort
Bort's picture
thanks, that makes a lot of sense now
the unbalanced circuit that is used with 6 supercaps in series, would that reduce their life drastically?
HKJ
HKJ's picture
lagman wrote:
@HKJ: About that kickstarter project using supercaps: I quite often hear people saying that one day we will have smartphones or electric cars that can be charged in 1-2 minutes. Although the battery/capacitor technology may become available one day, what people don't realize is that you would need an AC to DC transformer 10 times bigger than the smartphone or the car to achieve that.
Not necessary, you just have to equip the charger with a couple of supercaps too and keep it connected to mains.
But the charge connector, that might need to be rather solid. No small usb connector, but probably a docking station.
Bort wrote:
thanks, that makes a lot of sense now the unbalanced circuit that is used with 6 supercaps in series, would that reduce their life drastically?
Did that circuit not use some leds to balance the caps?
To high voltage on a capacitor can destroy it.
Bort
Bort's picture
HKJ wrote:
lagman wrote:
@HKJ: About that kickstarter project using supercaps: I quite often hear people saying that one day we will have smartphones or electric cars that can be charged in 1-2 minutes. Although the battery/capacitor technology may become available one day, what people don’t realize is that you would need an AC to DC transformer 10 times bigger than the smartphone or the car to achieve that.
no circuitry at all, just the caps in series, and the battery to recharge them with (though i suspect the car alternator charging the lipo battery won’t work well long term)
The car would charge with 14-14.4V to 6 supercaps in series (i would not use the lipo battery as the guy didn’t in the video i linked)
HKJ
HKJ's picture
Bort wrote:
no circuitry at all, just the caps in series, and the battery to recharge them with (though i suspect the car alternator charging the lipo battery won't work well long term) The car would charge with 14-14.4V to 6 supercaps in series (i would not use the lipo battery as the guy didn't in the video i linked)
As I wrote above, over voltage might* damage them, people that are used to working with capacitors always add a balancing circuit to avoid any problems.
*If the voltage is high enough it WILL damage them.
Bort
Bort's picture
HKJ wrote:
Bort wrote:
no circuitry at all, just the caps in series, and the battery to recharge them with (though i suspect the car alternator charging the lipo battery won’t work well long term) The car would charge with 14-14.4V to 6 supercaps in series (i would not use the lipo battery as the guy didn’t in the video i linked)
is there circuitry that would work in an automotive environment on 6 caps in series? (i guess each would see about 2.5V so below their max voltage?)
comfychair
comfychair's picture
Last seen: 5 years 8 months ago
Of course. It's just diodes, but you can buy it as a kit and spend more money if you'd like.
http://www.ebay.com/itm/301130956938 - balancer kit only
The complete bcap module kit includes the balancer stuff as well: http://www.ebay.com/itm/301128832966
HKJ
HKJ's picture
I saw a circuit with a led and a diode in series for each capacitor. It is not the best circuit, but it is simple and will probably work as long as the capacitors has about same value (They change value with age).
Bort
Bort's picture
cool, thanks
Werner
Werner's picture
Last seen: 2 years 4 months ago
But this balancing circuits only discharge overcharged caps and don’t prevent overcharging them or am I wrong.
If somebody would charge a couple of caps with some Amperes the leaking of 30mA seems to be no ideal thing.
Or does short time overcharging don’t harm these caps?
Bort
Bort's picture
that is a good point, i would want it to maintain charge for a few days or up to a week.
comfychair
How do you overcharge them? You'd have to connect the 6S module to a voltage source higher than 16.2 volts. So don't do that.
Werner
Werner's picture
I just followed the link to the battery starter with a lipo attached and I am wondering why not directly use a lipo pack? These are often rated for high currents…?
Maybe I have t understand how the balancing works… I will check it a bit further..
This video shows what I mean very good
https://m.youtube.com/watch?v=dAyY0D16qn4
So it doesn’t prevent overcharge in all conditions…but it works good enough for being so cheap…
HKJ
HKJ's picture
The over charge is due to difference in capacity and different leakage current and will happen slowly.
comfychair
'High current' is relative...
