Anyone have/disassembled this 1xAA light?
14 posts / 0 new
ohaya
Last seen: 2 years 7 months ago
Hi,
I recently got a couple of these 1xAA lights, mainly as potential (cheap) 1xAA hosts:
http://www.eachbuyer.com/f5-led-270lm-aluminum-alloy-waterproof-flashlig...
This uses one of those “strawhat” LEDs with a small driver/contact board (joule thief maybe?) that go into one of those plastic sleeve/pills.
I can get the driver and LED board out from the battery end of the head, but can’t figure out how to get the reflector out. I’m pretty sure that there isn’t a bezel ring, so it almost seems like they put the reflector (which is wider than the battery-end opening of the head) into the head from the front, and then either press fit or glued the (plastic, I think) lens in from the front.
Does that make sense? Has anyone had this or similar light and know how to get the lens and reflector out?
Thanks,
Jim
musicmagic
Last seen: 5 years 9 months ago
it sounds similar in construction to the mini C8’s, if I read you right.
If you can’t blind them with your brilliance, baffle them with your bullcrap.
The real currency in the world is not money, it’s trust.
DBSAR
DBSAR's picture
Last seen: 1 week 1 day ago
Its much the same setup as the 3W police lights, MXDL AA Lights, mini C8, etc that uses a 5mm Strawhat LED (usually a clone/no-brand name of the old Luxeon Strawhat wide-angle emitter) with a boost Driver. ( sometimes a simple Joule thief design) If the driver has a ferrite-coil with the 3 or 6 pin IC its the better one, ( the ones with the Transistor and resistor joule thief are not as good less efficient.)
ohaya
Ahh. Thanks. Found this:
http://budgetlightforum.com/node/30220#comment-561946
I’ll give that a try in a bit…
ohaya
Hi,
I finally got around to trying to get the lens and reflector out. They wouldn’t come out when pushing from the back, so I tried a 1/2” copper tube in from the battery end and hit that with a hammer. The lens came out, but I also damaged the reflector :(…
I haven’t tried to see if the lens will pop back in again yet, but is there any less destructive way of getting the lens/reflector out?
Thanks,
Jim
ohaya
Here’re some pics of the light:
- Disassembled (the piece in the front is what is left of the reflector):
- Driver and emitter:
- Tailcap:
lagman
lagman's picture
Last seen: 6 days 56 min ago
Did you take a picture of the other side of the driver by any chance?
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
hank
hank's picture
Last seen: 53 min 30 sec ago
ohaya
Do you mean the contact side? I can, but there’s nothing on that side.
lagman
lagman's picture
Ok thanks. I was asking because I can’t see any chip on the picture.
ohaya
Here’s a pic of the other side, just for the record :):
lagman
lagman's picture
Is there a chip hidden behind the black component (probably inductor) on the first picture?
Thanks for the pictures BTW! Wink
ImA4Wheelr
Great thread and info.  Thank you Ohaya.
That light has a cool look to it.  It would be cool if there is a readily available replacement reflector.  Do you have an idea what the depth and width of the reflector is?
ohaya
That’s actually something I hadn’t thought of… to see if I have any other reflector that might serve as a replacement.
I may be able to measure the diameter of the one that I destroyed too ;)!
