17mm 12x7135 drivers with custom firmware (Group Buy Interest thread)
133 posts / 0 new
18sixfifty
18sixfifty's picture
Last seen: 2 years 1 month ago
FlashPilot wrote:
18sixfifty, thanks for all of your efforts. I realize this is a monumental undertaking and requires a lot of effort.
Will they flash 2 versions of the FW as we had discussed?
Will they accept 500 min order?
They haven’t gotten back to me on that question yet.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
FlashPilot
FlashPilot's picture
Last seen: 5 hours 2 min ago
I’ll keep my fingers crossed for us. Thanks again.
Ledsmoke
Ledsmoke's picture
Last seen: 1 year 4 months ago
I'll be interested in this one to supply the Euro zone modders too.
If there is any interest in the BLF17DD that I started offering I'll pick up 50 of these. If not then... Substantially less Sad
But I do hope they can be ready made to have off time memory. I am trying to figure out how to make a "scroll one mode back" for clickie switches like Werners UI for momentary switches.... So that'd be cool if the off time memory hardware was there already Smile
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
NightSpy
NightSpy's picture
Last seen: 4 years 8 months ago
I wanted to see how 12× 7135’s would fit. The spring pad I cam up with is nearly the right diameter. 7.5mm is what I got away with in this arrangement. I also got 5× 7135 on the opposite side with the MP and 4 discrete comps. No stars, but that can be solved at the MP. After all, stars are just shorted outputs. Anyone see a problem putting the 7135’s to the edge to maximize the spring OD at the base? This is one thing the 105C limits… spring deflection.
FlashPilot
!https://lh6.googleusercontent.com/-rk1PEkRojmY/U9_NBwPJGcI/AAAAAAAAGqI/c...!
What a great rendering! Thank you for taking the time to model this concept.
18sixfifty
Just another update. They have agreed to do more than one set of modes. So one is going to be THE’s firmware and another set of mode selections my flashpilot.
_the_
_the_'s picture
Last seen: 1 day 12 hours ago
Great! Best of both worlds!
Did you ask about adding a 1uF capacitor for supporting off-time memory?
Edit: Please don't get me wrong. I'm not forcing or pushing anyone to select TheStar. If most people want a simpler/better/less hated FW, I'm totally ok going with a single batch with that FW. [I don't have any problem flashing my own drivers with TheStar]
=the=
18sixfifty
I did that just a few minutes ago and I’ll post here when they get back to me.
wight
Last seen: 1 year 8 months ago
Retaining rings won’t work. Not too common on 17mm stuff though. I certainly can’t think of an example. You’ll almost certainly have to route traces under the large GND pad on the 7135’s if you keep the top as crowded as you mentioned. http://budgetlightforum.com/node/32318
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
FlashPilot
Thanks 18sixfifty! That is great news for everyone. This should make a wide range of people very happy and stimulate sales. Thank you for hanging in there and not giving up. Huge kudos go to you sir! The 1uF capacitor would make it all the more appealing.
WarHawk-AVG
WarHawk-AVG's picture
Nice…the only problem…the 7135’s on the top need a clearance space, otherwise they sometimes hit the inner lip of the pill and the driver won’t seat properly
On the bottom I think it needs a ground ring
Very cool looking render!
wight did an AWESOME 22mm with 6 on top and bottom but there is ALOT more acreage on the driver when you from 17mm to 22mm
Still blown away by that render…awesome!!!!
wight
He’s got a GND ring, it’s under the (GND) tabs. Is there some need for unpopulated space at the edge of the board on the bottom? I’m sure we need unpopulated area around the edge on the top.
FWIW the 22mm board has 8/8, not 6/6. Space dries up fast as you add components ;-). IIRC 6/6 can be done on 20mm, didn’t someone do that?
18sixfifty
Off time memory is supported!
FlashPilot
Just how many cases of premium beer did you send these folks to make them like you so much? :bigsmile:
Cheers! Beer
18sixfifty
Cheers! Beer
LOL
I’m guessing they hope to sell us a bunch of these and if they do it right they will be correct. I can see me going back to them over and over if they are always this easy to deal with. If they are just blowing smoke up my backside then they won’t even get this order. Nice that they offered a sample right away though. That tells me they at least have confidence that they can get it done correctly.
NightSpy
NightSpy's picture
I got all the traces routed on the primary side along with leaving the 1/2mm clearance ring on the outer edge for the pill shoulder.
A conventional 5× 7135 is possible with no signal vias going through the board… only the ground ring and the positive spring pad.
It is surprising just how much room there is for routing 5× 7135’s. This would be the old AK-47A on ‘roids.
To make it two sided, the 7× 7135’s are fed with strategic vias back to the primary side.
I have no intention to compete with 18650 here. I just wanted to have a quick look. And yes, it is doable.
I have my own projects and certainly have a different requirement for the modes. Stacking 7135’s on top of each other is much easier for a 1-4 off.
WarHawk-AVG
Doing that on a 15mm board was difficult…well…5 total chips (not 5 on each side)
http://budgetlightforum.com/node/31315
bibihang
bibihang's picture
Last seen: 4 days 20 hours ago
- TheStar FW or simpler Qlite FW (2 choices)
- Off-time memory
- Come with 4.2A
Thank you very much 18sixfifty! How can I not ordering a few (plenty…)!
You guys are awesome. Beer
_the_
_the_'s picture
Off-time memory sounds great! I need to update TheStar to support it well..
wight has now been testing the TheStar Off-time v0.1 (which I coded kind of blindfolded, as I don't have any 1uF caps for testing at the moment)
The challenges in porting TheStar to off-time are the lack of memory and especially stars.. We can't have all the options we have in the on-time version. Sad
At the moment I'm planning to have mode order and tacticool switches => Options are L->H (with off-time memory), H->L (with off-time memory), Tacticool (no memory) & Single mode (no memory). Is this ok for everyone, or would it be better to provide only mode order and memory switches? => Options would be L->H (with off-time memory), H->L (with off-time memory)L->H (with off-time NO memory) & H->L (with off-time NO memory)
Any comments / opinions?
=the=
wight
I prefer to have the ability to setup offtime with no memory.
scottyhazzard
scottyhazzard's picture
Last seen: 2 years 5 months ago
wight has now been testing the TheStar Off-time v0.1 (which I coded kind of blindfolded, as I don’t have any 1uF caps for testing at the moment)
The challenges in porting TheStar to off-time are the lack of memory and especially stars.. We can’t have all the options we have in the on-time version. Sad
At the moment I’m planning to have mode order and tacticool switches => Options are L->H (with off-time memory), H->L (with off-time memory), Tacticool (no memory) & Single mode (no memory). Is this ok for everyone, or would it be better to provide only mode order and memory switches? => Options would be L->H (with off-time memory), H->L (with off-time memory)L->H (with off-time NO memory) & H->L (with off-time NO memory)
Will the Tacticool be strobe first then H > L?
"Those who hammer their guns into plows will plow for those who do not."
scottyhazzard
- Off-time memory
- Come with 4.2A
Yup +1, in total agreement.
djozz
djozz's picture
Last seen: 57 min 34 sec ago
off-time without memory is the best Smile
_the_
_the_'s picture
Strobe -> Turbo -> Low (no memory).
=the=
NightSpy
NightSpy's picture
“default” mode select and no memory :bigsmile:
scottyhazzard
SWEET! When do we order?
18sixfifty
Once I get everyone on board with exactly what firmware, I’ll have them send a sample for inspection. After that I’ll set up the actual group buy. I’m not worried about them being able to input the firmware but I am a little worried about how they are going to stack the resistors.
_the_
_the_'s picture
Tacticool config is currently losing 1-3 to plain old memory switch.
However, I can always flash some tacticool drivers and send them to you in case the other option wins. Smile
=the=
scottyhazzard
That will be great. I’ll be getting a bunch. These will be a hit a work.
bibihang
bibihang's picture
So is this driver GB a go or no-go?
