SA04
930lumens RGB LED Variable color temperature
Effective range of 280 metres
lntegrated solutions to all kinds of lighting applications
Features
Utilizes two Cree XM-L2 LEDs and two RGB LEDs with a lifetime of up to 50,000 hours
Multi-functional LCD touch screen display indicate the running level and the remaining power with low-power warning
Constant current circuit, constant output
Electronic reverse battery protection
Effective range of 280 meters
Intensity: 14800 cd
Uses 4xAA batteries
Working voltage: 2.8~8 V
Optimized deep metal reflector maintains great throw distance and spread with an ideal beam pattern
Dimensions: 119.5mm (length) x 43mm (head diameter) x 40mm (tail diameter)
Weight: 208g (battery excluded)
Aerospace-grade aluminum alloy body
Military Specification Type III- hard anodized
Waterproof accords with IPX-8 standard
Ultra-clear tempered glass lens resists scratches and impacts
Tail stand capable- can be used as a candle
Accessories: O-rings, Holster
http://www.imalent.com/a/chanpinzhongxin/S_Series/2014/0707/1.html
