Test/Review of Brillipower 18650 3400mAh (Black)
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 19 hours ago
DSC_5735
Official specifications:
  • Nominal voltage: 3.7 Volt, fully charged: max. 4.20V
  • Capacity: 3400 mAh
  • Temperature range: -20°C to 60°C
  • Top: Button Top
  • Size:: 68 mm (Length) x 18 mm (Diameter)
Brillipower%2018650%203400mAh%20(Black)-info
A protected 3400mAh battery, capacity is as expected.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
DSC_5733 DSC_5734
DSC_5736 DSC_5737
DSC_5738
DSC_5739
Brillipower%2018650%203400mAh%20(Black)-Capacity
The curves are as expected for this battery. The difference between the two 5A traces is probably due to component tolerances in the protection circuit. For one of the batteries the protection circuit trips just before the trace is finished.
Brillipower%2018650%203400mAh%20(Black)-CapacityTimeHours
Brillipower%2018650%203400mAh%20(Black)-Energy
Brillipower%2018650%203400mAh%20(Black)-PowerLoadTime
Brillipower%2018650%203400mAh%20(Black)-TripCurrent
Brillipower%2018650%203400mAh%20(Black)-Charge
Conclusion
A good 3400mAh battery, the protection does a good job in protecting the cell from misuse.
Notes and links
Compare to 18650 and other batteries
lagman
lagman's picture
Last seen: 2 weeks 5 days ago
Thanks for the test!
Looks like an other rewrapped NCR18650B to me…
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
WarHawk-AVG
WarHawk-AVG's picture
Nice…alot of capacity as well
Great review as always HKJ!
leaftye
Last seen: 1 year 1 month ago
Nothing wrong with rewraps if it makes them more accessible and increases competition.
I like that type of button a lot better than the regular flat top button that comes on an unprotected NCR18650B.  That other button is weak.
The low mode should be lower.
FlashLion
FlashLion's picture
Last seen: 4 years 6 months ago
I have two of these batteries from more than a year now.
Decided to see finally,is it a Panasonic inside,or not.
I cut part of the wrapping. Light green color underneath.
Yet,not 100% sure,because there’s no marking where I cut.
