Advice for COB and 3x xm-l2 drivers
25 posts / 0 new
esmi83
Last seen: 4 years 5 months ago
Helllo
I want to make a flood light and need a driver for the flashlight, the smaller the bether…. Is it possible to use something like this to drive it?
http://www.lightmalls.com/9-led-series-3-mode-for-three-lithium-battery-...
http://www.lck-led.com/26mm-3000ma-driver-modes-p-962.html?cPath=135
Edited by: esmi83 on 08/31/2014 - 10:56
Chloe
Chloe's picture
Last seen: 5 years 4 months ago
Welcome to BLF, esmi83! Party
Was there a particular COB you wanted to use?
esmi83
oh i where thinking of the bridgelux 9000 something….
esmi83
yeah and thanks for the welcome Smile
comfychair
comfychair's picture
Last seen: 5 years 7 months ago
An actual part number would be a great help.
Both those drivers you linked to are the same part, they have a max output of around 30 volts, not enough to fully drive the 32-36v arrays. And, those drivers are horribly unreliable when run at their max voltage for more than a few minutes at a time.
esmi83
of course Smile
BXRA-56C9000-J-xx
http://www.bridgelux.com/wp-content/uploads/2013/10/DS25-Bridgelux-RS-Ar...
hope this helps Smile thank you
comfychair
OK, those '9x' boost drivers, at their max of 30v, will put around 650-700mA through a C9000. That current will only give you around 2700 lumens. And it will run for about 5-8 minutes before the driver burns up.
This driver will do 3A @ 48v (it will only put out the voltage needed to reach the set current limit). You will need to study the 'tech' page for the HBFlex to make sure you understand what's required to make it work.
esmi83
Thanks mate!
..and that driver is the only one you know will work? what is the price?
how many xm-l could the drivers i linked to drive efficialy? 4-5 or something?
comfychair
Those 5x/7x/9x boost drivers should be pulled from the market, they are not reliable.
esmi83
Cool, thanks for n’lighten me, i have to read the hbflex manual i think, shimmed through it now, did not get it Smile
how are they driving this light do you think? http://www.aliexpress.com/item/Free-Shipping-ARCHON-W106W-D100W-100wswc-LED-10000-Lumens-Waterproof-100Meters-Underwater-Aircraft-grade-Diving-Video/1742494038.html
esmi83
i were just thinking, is it not possible to use two drivers to run it from a 12v battery? (series wire output on the driver….)
comfychair
Uh, no. Not boost drivers. You'd end up with the first driver powering the second one (and likely neither of them surviving).
esmi83
Incredible fast answering Smile thanks!
esmi83
http://www.kaidomain.com/product/Details.S020165
I assume this one falls under the same catagory as the earlier mentioned ones, what are they good for? 5-6 xm-l or something, or are they just unrealible in general?
comfychair
That's the same driver again. Different sellers may have them customized with slightly different firmware (different modes, levels, etc.) but that doesn't change the hardware.
Even the $40 HBFlex will struggle to hit 100W output, and to get close to that you'll need to use the highest possible input voltage, otherwise the input current goes above what the driver can tolerate. That makes it difficult to fit into something that resembles a flashlight (though, you haven't mentioned what you want to use it for yet).
There are non-flashlight drivers easily able to run it, from either DC (boost drivers) or AC powered.
esmi83
Hi
I am planning a 100w videolight, I am also looking for a good way of driving three xml,s slightly overdriven to aroung 45-50w. And really 120degree is a bit too wide so it would be great to narrow the beam down to aboute 60-80degrees, maby by using a fresnell? body will be manufactured in my lathe, so actually size does not matter….
comfychair
So fixed lighting? AC power available, or DC?
The Chinese square LED arrays have glass aspheric lenses & brackets that fit, don't know for sure about the Bridgelux but I'm sure there's something for them.
esmi83
Oh no there are only DC available… it should be portable…
comfychair
When I say 'fixed lighting' I mean that it will remain in a fixed location in space while it's in use, not that it will be anchored to the bedrock. So, stationary, on a stand? Or mounted to a camera? Handheld with someone walking around with it?
esmi83
oh sorry, me stupid Smile it is both mounted on camera and operated by light people… it is supposed to be used for uw videography…
esmi83
for the 3x xm-l i am planning on using this driver to ramp it up a bit, cooling is done by heatsinking led and driver to aluminium housing, when operated underwater it should be cool enough (maby) http://www.lck-led.com/5000ma-driver-modes-p-935.html?cPath=135
esmi83
http://www.lightmalls.com/5-2-12v-5000mah-dual-lithium-3-mode-led-circui...
This is pretty much the same i think, is this a good idea to drive three xm-l’s in series with, are there any experiences with it and how many amps it is over each led with three xm-l , i have already tried to search but could not find anything, i am sorry if i missed it
esmi83
did i move this thread myself or did it get moderated? I am really sorry if i have done something wrong Smile
esmi83
Maby something like this for the cob? or are they just crap? http://www.dx.com/p/dc11-35v-to-11-35v-10a-constant-current-constant-vol...
moviles2
Last seen: 4 years 1 month ago
this driver are good for for 100w led,i have tested this driver with 100w cinaise crap leds
in ebay it have lower price
driver
or this other
driver
