Test/Review of Efest IMR18650 3100mAh (Purple) 2014
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 2 days ago
DSC_6281
Official specifications:
  • Top: flat top
  • Bottom: non-protected
  • Typical Capacity: 3100mAh
  • Min capacity: 3100mAh
  • Max discharge current: 10A
  • Pulse discharge current: 20A
  • Quick charge current: 3000mA (1C)
  • Quick discharge current: 2000mA
  • Cycle life: 300 times
  • Charge cut-off voltage: 4.2V ± 0.5V
  • Charge cut-off current: 5A
  • Initial Impedance: Max: 15mOhm
  • Discharge cut-off voltage: 3.0V
  • Temperature: discharge temperature range:-10°C—60°C, charge temperature range: 0°C—40°C
  • Storage: 1 year:-20°C—25°C, 3 months:-20°C—45°C, 1 month:-20°C—60°C
  • Size: weight: 50g, Length: 65 mm, Diameter: 18mm
Efest%20IMR18650%203100mAh%20(Purple)%202014-info
High power and high capacity in the Efest purple line of high current cells.
DSC_6279 DSC_6280
DSC_6282 DSC_6283
DSC_6284
DSC_6285
Efest%20IMR18650%203100mAh%20(Purple)%202014-Capacity
Looking at this curve I will say that 20A is a bit high for continous load, but 10A is handleded very fine.
Efest%20IMR18650%203100mAh%20(Purple)%202014-CapacityTimeHours
Efest%20IMR18650%203100mAh%20(Purple)%202014-Energy
Efest%20IMR18650%203100mAh%20(Purple)%202014-PowerLoadTime
I had an accident during testing and I am missing one cell in some tests. The problem was that my load did not turn off after the 20A and discharged the cell completely.
Efest%20IMR18650%203100mAh%20(Purple)%202014-TripCurrent
Efest%20IMR18650%203100mAh%20(Purple)%202014-Charge
Conclusion
The cell cannot match the ultra high current cells in power, but easily surpass them in energy at 10A. This is very good performance.
I will call it a acceptable cell.
Notes and links
Compare to 18650 and other batteries
Edited by: HKJ on 08/25/2014 - 11:34
D10ten
D10ten's picture
Last seen: 1 week 3 days ago
Thank you HKJ for the review. I compared this to the NCR18650BD using HKJ’s 18650 comparion and they were exactly the same.
leaftye
Last seen: 11 months 3 weeks ago
As always, great test!  I'm especially happy to see this because I'm actually about to start testing a pair of these today.
You might want to start using a darker gray for your 20A graphs because it's almost impossible to see on my screen.
The low mode should be lower.
dangerous
dangerous's picture
Last seen: 6 years 9 months ago
NCR18650BE*
http://dampfakkus.de/akkutest.php?id=531
http://dampfakkus.de/akkutest.php?id=536
BLF
D10ten
D10ten's picture
Strange, I thought BD was the hybrid battery (successor of the PD) capable of 10A discharge, while BE was the cheaper version of NCR18650B with only a 3.5A discharge.
