12 volt nicad charger
9 posts / 0 new
luke
Last seen: 10 months 4 weeks ago
Can you use a car battery charger for charging a 12 volt nicad battery from a cordless drill?
flydiver
Last seen: 1 day 6 hours ago
Different chemistry > different termination > not a healthy idea.
To Air is Human, to Respire….Divine.
WarHawk-AVG
WarHawk-AVG's picture
Yes, but it is manual charging…but you MUST monitor it contantly
http://batteryuniversity.com/learn/article/charging_nickel_based_batteries
Pretty much you watch not only the temperature but the voltage,
Quote:
When inserting a fully charged battery, the terminal voltage rises quickly, and then drops sharply to trigger the ready state. The charge in this case lasts only a few minutes and the cells remain cool. NiCd chargers based on the NDV full-charge detection typically respond to a voltage drop of 10mV per cell.
To obtain voltage drop of 10mV per cell, the charge rate must be 0.5C and higher. Slower charging produces a less defined voltage drop and this becomes difficult to measure, especially if the cells are mismatched. In this case, each cell in a mismatched pack reaches the full charge at a different time and the voltage curve flattens out.
You can manually charge them…but you literally have to sit there and monitor constantly…always better to use a charger designed for the pack
Charge pattern for NiCd Delta V look something like this
http://www.mpoweruk.com/chargers.htm
as battery fills up to maximum charge capacity voltage drops, then the heat builds up…if you monitor constantly and see the voltage drop, that is full charge..but like I said. you have to monitor constantly…chargers do that for you
Safe answer is ALWAYS get the proper charger…period!
Then of course there is the DIY method
http://www.instructables.com/id/Homemade-Cordless-Drill-Battery-Charger/...
As I said before…Safe answer is ALWAYS get the proper charger…period!
Bort
Bort's picture
Last seen: 9 hours 16 min ago
IF you can find a 12V input charger for your 12V pack then i would recommend it, otherwise i would not
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
xv-750
xv-750's picture
Would do it right.
Riding for 57 years, last off was black ice in ’73.
First paid computer job was in ’75, writing an extra report for HAPAS accounts on a Wang Computer.
luke
What is a good value hobby charger for 12 volt nicad packs and 18650 li ion.
http://www.valuehobby.com/gt-power-c6-charger.html
Would this be ok?
CyrusAM
Last seen: 3 years 7 months ago
I have this charger and it works great, I’d highly recommend getting one
Socorro Search and RescueI wear my sunglasses at night
flydiver
Trivial difference between the one you linked and CyrusAM. The one in your link looks a tad better ‘on paper’.
CyrusAM
Sorry, my last suggestion was poorly phrased, I meant that I had one similar from them and I’m happy with the charger itself and value hobby. Didn’t mean to imply one model or another is better. If you know how to finesse all the settings you can do anything you’ll come across with that charger.
