This is kind of an oddball question, but per the subject, does anyone know of an extension tube, or maybe part of a different AA light that could be used as such, to make an RC-G2 into a 2xAA light?
Or, did Romisen ever make a 2xAA light that was the same dimensions (head, etc.) as the RC-G2 except that it was 2xAA?
Thanks,
Jim
EDIT: I have changed the Subject. Anyone out there with a lathe that might be willing to make an extension tube with threads that would fit a Romisen RC-G2, and to make it into a 2xAA?
It’s because I have been building a couple of quads with the RC-G2, and the head size is absolutely perfect for that (Romisen RC-G2 Nichia quad).
I’m using a small buck driver in these, and I have a couple of 14250 batteries that I bought awhile ago from lighthound, but they’re kind of puny, plus I can’t seem to find (rechargeable) 14250s anywhere anymore, so if I could get something to make the RC-G2s into 2xAA then I could use 2x14500.
Sorry, I forgot to mention that I have tried extension tubes from two different brand C3s, the UF C3 and the Fandyfire C3, and neither of them work with the RC-G2. I was really hoping that Romisen might have a 2xAA light that was the same shape as the RC-G2, but it doesn’t look like that’s the case?
……but I don’t have an RC-G2 to compare head or other dimensions.
It has a ‘pill’ that screws into the back of reflector, like P60, but the reflector also threads into the head (no spring).
Like most Romisen: nice build quality and beam profile.
I put XM-L2 and BB Nexgen drivers in them for maximum efficiency from 2AA or 1 CR123A.
Yes, I know it’s a tall order, and, that unless I get really lucky and someone actually has a solution, I may have to try a couple of different things.
It seems like with a lot of the “AA” lights, they make the tubes to fit both 16340 and AA and also the front end of the tubes is male threaded (as opposed to female threaded), which is all making the search even more difficult.
I might have to do that eventually, but in the meantime, I’ve found a couple of different extension tubes, and will post if any of them fit. To hedge my bet, I’ve also got an A6 inbound, but I’d really like to get this little RC-G2 set up. It works quite well with the 2x14250, pulling about 5+ amps, but just for a few seconds at at time.
I’ve failed to either find an extension tube or an alternate 2xAA host, so am looking for someone who might make/fabricate an extension tube for the RC-G2.
I think that I may’ve found a 2xAA host that I can/would like to use (but probably not for a quad), see:
Also, I think that I’ve found someone who can make an extension tube for the RC-G2. This is still really my preferred option, because it gives the flexibility of a short (1x14500), but slightly less bright quad and being able to go to brighter quad, with more capacity (2x14500), albeit with a slightly longer host (with an extension tube).
