HD2010 with Yezl extension for 2x26650 - PICs inside
10 posts / 0 new
HarleyQuin
HarleyQuin's picture
Last seen: 1 year 2 days ago
Gearbest offers the Yezl Y3 extension seperately, and yes, it fits the usual HD 2010. Usual means: the ones with 31mm threads. There are HD2010 with 32mm threads and different pill threading on the market as well… chinese lottery at its best.
The threads of the extension are a good match, it screws without force on HD2010 body and tailcap. Only the red o-ring makes it slightly too tight, yet doable.
The threads of the Y3 seem to be longer, the 2010 body does not reach the bare part inside the extension to make electrical connection. I will have to remove the anodizing on the extension’s threads.
The extension tube is slightly more matte than the black Fasttech Fandyfire shown on the pictures.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
Edited by: HarleyQuin on 09/24/2014 - 09:33
antiparanoico
HD2010 with two Y3 extensions for 4xC (alkalines).
The mine are from CNQG GB. They fit “as is”.
P.D.: The extensions came perfectly packed but with many scratches…
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
TheGloriousTachikoma
Last seen: 5 years 9 months ago
That…
is actually kinda cool. Though I can’t help but feel that the Y3 with its side switch is much more suited for these sorts of shenanagins. Party One extension on the HD2010 is a good idea if you can get a flexible enough driver for it. Or put a Zeiner-modded BLF-DD and a MT-G2 in there. It expands the possibilities sure. Now I wish I’d gotten in on the HD2010 group buy earlier this year.
Gj
Gj's picture
Last seen: 8 months 4 weeks ago
Tangsfire HD2010 was $23 just a week or two ago @Tmart.
bikenber73
bikenber73's picture
Last seen: 2 weeks 1 day ago
I did that on my Tangsfire HD2010 Smile. The problem is that the batteries don't fit tight enough and if you shake it a little the modes change.
feilox
Last seen: 6 months 1 day ago
Is it safe to run 2×26650 on stock HD2010 drivers?
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
bikenber73
NO
Barkuti
Barkuti's picture
Last seen: 15 hours 51 min ago
Mmm, another Yezl Y3 extension tube related thread, nice.
I have an M31×1 threaded host which I'm sure could make use of those Y3 extensions but, so far, no one has been able to provide me comfirmation as to what is the thread pitch on them (seems 1mm to me). May someone shine some light?
Thanks.
Cheers Party
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
HarleyQuin
Confirmed.
It’s M31×1 on the Yezl extension (2 turns, 2mm) and on the HD2010 where it fits (5 turns, 5mm).
Oshpark Boards:
Barkuti
Barkuti's picture
Thank thee, HarleyQuin.
I'll probably be getting one of those Y3 extension tubes (along with a LD-29S driver) once my economy gets healthier. Thumbs Up
Cheers Party
