zebralight h600 mod potential?
Hi folks, does anyone know if this light would be an easy emitter swap, or is it a pita with loads of glue etc…
From everything I´ve read all Zebralights are just a PITA to mod…
Yes thats what I thought, I just hoped that this one was different :frowning:
Not sure that breaking the glass to lever out the bezel is what I want to do…I prefer non destructive mods.
http://www.cpfitaliaforum.it/viewtopic.php?f=8&t=8069&hilit=modding+h600
Ho fatto modding in H600 e H602 H600 è abbastanza facile, mentre H602 è molto difficile! E 'difficile rimuovere l'obiettivo se posto molta pressione .. ma è la sostituzione di fasttech! ;) Io sono qui se hai bisogno di aiuto!
It seems I stand corrected…. I don´t speak italian, but looking at the pictures in the link it looks moddable…
The screws holding the led looks glued though…
https://translate.google.it/translate?sl=it&tl=en&js=y&prev=_t&hl=it&ie=UTF-8&u=http%3A%2F%2Fwww.cpfitaliaforum.it%2Fviewtopic.php%3Ff%3D8%26t%3D8069%26hilit%3Dmodding%2Bh600&edit-text=&act=url
https://translate.google.it/translate?sl=it&tl=en&js=y&prev=_t&hl=it&ie=UTF-8&u=http%3A%2F%2Fwww.cpfitaliaforum.it%2Fviewtopic.php%3Ff%3D8%26t%3D8061%26hilit%3Dmodding%2Bh602&edit-text=&act=url
https://www.youtube.com/watch?v=_4gyZIVBgUg&feature=youtu.be
I inserted the link translated, I'm bad with BLF forum interface,
I do not work well options!
The H600 is easy MOD, need a soldering iron of at least 50W
good pond and a bit of flux, if the screws are not covered by the pond,
it is easy to remove the pond, otherwise, while warm pond quickly enter the screwdriver and tin comes out.
I had problems on the SC600.
If the metal ring does not jump off easy, you have to break the glass has a change of fasttech
if you want to control the measurement.
test before removing the ring of the glass, to freeze the torch for 1-2 hours
the ring should narrow to very little!
