Broken Fenix E05
13 posts / 0 new
Christian
Last seen: 10 months 4 weeks ago
Broken Fenix E05
Hello, this is my first post.
I found one of my Fenix E05 wasn’t working anymore, so I disassembled it (thanks to this post ). The led is working, so the fault must be in the driver circuit.
On the tiny pcb there is an IC marked CFC1H, I found on some Chinese forum that it could be a PAM2803 (Data sheet ).
Can someone confirm this? Is there someone who traced the circuit from the pcb?
Many thanks
Christian
Edited by: Christian on 10/26/2014 - 04:59
eebowler
eebowler's picture
Last seen: 1 week 1 day ago
Before you do all that, connect a cell to the head with a piece of wire to see if the LED lights up. Sometimes a leaky cell can cause corrosion between the spring and body.
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
ericandor
Last seen: 3 years 1 month ago
Yes, it seems to be PAM2803.
Check this post for PAM280x markings.
Christian
Hi, thanks for your answers.
@eebowler, I hoped it was a bad contact issue, but the cell was not leaking, and just to be sure I swapped the battery housing with my other Fenix E05 that still works. I also measured the impedance between battery contacts on the faulty head and compared to the working one. On the working one I measured about 4 kΩ, on the faulty head it was infinite.
@ericandor, thank you for the link.
I also measured impedance between pins 1 and 6 of the IC, expecting a very low value because of the inductor, but I got infinite. I am not sure but it seems to me that one solder joint of the inductor is cracked. I’ll check when I can use a microscope and let you know.
Regards.
Christian
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 11 months 6 days ago
Can you just hit the bad solder joint with a hot air reflow gun?
Let us know if it fixes your issue
Christian
Hello all.
My Fenix E05 is now fixed Smile
As you can see from the photos, the inductor core is damaged (in the first photo the broken piece is still attached to the red resin).
Maybe this caused the bad soldering joint, which after some time cracked.
Regards
Christian
Halo...
Halo...'s picture
Last seen: 4 years 8 months ago
Congrats on the fix. Beer
And welcome to BLF. :bigsmile:
Streamer
Streamer's picture
Last seen: 1 year 4 months ago
CoolI have 2 E05's ...Love it when a light is SAVED!!  Congrats
eebowler
eebowler's picture
Party
wight
Last seen: 1 year 1 month ago
Thanks for that informative link!
Christian wrote:
Hello all.
http://imgur.com/HipA9Lf
http://imgur.com/A8ciFip
Regards
Christian
I see the damaged inductor. What fixed the E05? Did you simply need to reflow the cracked solder joint?
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Christian
Yes, I only resoldered it.
Regards.
Christian
wight
Regards.
Christian
Sweet!
Ricflair
Ricflair's picture
Last seen: 2 years 4 months ago
Nice fix. Nothing worse than a cold solder joint. I test my larger electronics by tapping them with a pencil. It helps me track down the area.
RicFlair is on the air with blonde hair & pink underwear!! Whaoooooo!
