Test/Review of Efest IMR26650 3500mAh (Purple) 2014
11 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 2 days ago
DSC_6765
Official specifications:
  • Typical capacity: 3500,Ah
  • Maximum discharge current: 32A
  • Maximum pulse discharge current: 64A
  • Maximum charge current: 6.5A
  • Resistance: 13mOhm +/-2mOhm
  • Nominal voltage: 3.8 volt
  • Discharge cut-off voltage: 2.5 volt
  • Full charge voltage: 4.2 volt
  • Temperature range: -20°C ~ 60°C
  • Temperature range discharge: -20°C ~ 60°C
  • Temperature range charge: 0°C ~ 45°C
  • Monthly self-discharge rage:
    Efest%20IMR26650%203500mAh%20(Purple)%202014-info
    A high current 26650 batteries, this time Efest has printed both the pulse and the continuous rating on the battery.
    DSC_6764
    DSC_6766 DSC_6767
    DSC_6768
    DSC_6769
    Efest%20IMR26650%203500mAh%20(Purple)%202014-Capacity
    The discharge curves is tracking nicely and capacity is nearly constant up to 20A and do also match the marked capacity. The 30A curve is a bit high for the battery.
    Efest%20IMR26650%203500mAh%20(Purple)%202014-CapacityTimeHours
    Efest%20IMR26650%203500mAh%20(Purple)%202014-Energy
    Efest%20IMR26650%203500mAh%20(Purple)%202014-PowerLoadTime
    Efest%20IMR26650%203500mAh%20(Purple)%202014-TripCurrent
    Efest%20IMR26650%203500mAh%20(Purple)%202014-Charge
    Conclusion
    It looks like this battery follows the Efest style for the purple batteries with very good high current performance. The price for this high current performance is less capacity.
    Notes and links
    The batteries was supplied by Efest for review.
    Compare to 18650 and other batteries
Werner
Werner's picture
Last seen: 2 years 2 months ago
That is indeed a high current cell which deserves its name. Thanks for the review.
dangerous
dangerous's picture
Last seen: 6 years 9 months ago
Wow, the high voltage at high drain is amazing on this cell – it blows everything else away. Shocked
BLF
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 3 years 4 days ago
Thanks.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 6 months ago
Awesome review…man it sure did hold tough at those high current drain levels
Thanks!!!
Tom E
Tom E's picture
Last seen: 2 hours 10 min ago
Again, awesome! I've only got these recently and have been very impressed. For my DD light mods, they did as well as the Efest 35A, Sam 25R, LG HE2, SONY VTC5, so thought it would show well in your tests. Though the capacity is low by today's standards for 26650's, it's the SONY 26650 equal (or better) and much higher capacity.
Calmaja
Last seen: 2 years 4 months ago
Thanks HKJ.
Lothar
Lothar's picture
Last seen: 2 weeks 6 days ago
Thank you for the awesome review (as always) HKJ.
I'm really surprised to see how much better these hold their volts with high amps, relative to the Keeppower IMR26650 3500mah's. Could these be different cells than the Keeppowers?
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
Dru_dragon
Dru_dragon's picture
Last seen: 4 months 1 week ago
Wow these look like the new high discharge king! Will you be testing the green Efest 4200mahs also?
Andrew
HKJ
HKJ's picture
Comparing the 20A curve I believe they are different cells.
HKJ
HKJ's picture
I have no plans for that at the current time, but maybe Efest will send some batteries to me (They do that sometimes).
I do still have a few Efest batteries in queue from the last batch I received. At that time I had a very long queue:
I have tested most of it now.
