Test/Review of Efest 18650 2200mAh (Black) 2014
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 4 hours ago
DSC_6783
Official specifications:
  • Weight: 50g
  • Length: 65.40 mm
  • Diamter: 18.44 mm
  • Top: Button top
  • Bottom: non-procted
  • Typical Capacity: 2200mAh
  • Min capacity: 2200mAh
  • Max discharge current: 22000mA
  • Max charge current: 22000mA
  • Max continuous discharge current: 22000mA
  • Cycle life: 300 times
  • Discharge cut-off voltage: 3.0V
  • Voltage: 3.7V
  • Full Charge voltage: 4.2V
  • Discharge temperature range:-10°C—60°C
  • Charge temperature range: 0°C—40°C
  • Storage: 1 year:-20°C—25°C, 3 months:-20°C—45°C, 1 month:-20°C—60°C
Efest%2018650%202200mAh%20(Black)%202014-info
This is a normal (i.e. not high current) 18650 cell. I believe the 22000mA in the specifications is a typo.
DSC_6782
DSC_6784 DSC_6785
DSC_6787
DSC_6788
DSC_6789
Efest%2018650%202200mAh%20(Black)%202014-Capacity
There is good tracking between the two cells at lower current and the capacity is fairly constant up to 7A.
Efest%2018650%202200mAh%20(Black)%202014-CapacityTimeHours
Efest%2018650%202200mAh%20(Black)%202014-Energy
Efest%2018650%202200mAh%20(Black)%202014-PowerLoadTime
Efest%2018650%202200mAh%20(Black)%202014-TripCurrent
Efest%2018650%202200mAh%20(Black)%202014-Charge
Conclusion
Up to a few amperes the battery looks good, but both capacity and current capability is rather low by today’s standards.
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
Edited by: HKJ on 12/07/2014 - 16:57
202bigmike
Last seen: 14 hours 40 min ago
It works , but it’s so-so ? Not quite up to today’s speed.
HKJ
HKJ's picture
202bigmike wrote:
It works , but it's so-so ? Not quite up to today's speed.
The battery is fine, if:
  • You can get it to the right price
  • Your application only needs 2 to 3A.
  • You do not need the longest runtime possible.
202bigmike
It’s worth what it’s worth , if it fits someone’s need$ .
Those words are mine. Thanks for the review HKJ.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 6 months ago
Depending on price, these could be some decent daily driver (5A and below) batteries
At 7 and 10 amp the batteries sag WAY too much
Awesome review…thanks!!!
