I’ve spent the past couple of days looking through the forums and reading HKJ’s reviews and I still can’t figure out what I need. I already have a Nitecore i4 to take care of most all of my charging needs. However, there’s two things I’m looking for:
1) A charger that will do 4.35V
2) A charger or something to test my cells…capacity, discharge, etc.
I’m not sure if I should look for both of these items in one unit or if I would be better off getting a XTAR SP1 from RMM and a (fill in the blank, maybe Lii-260 from Ebay) for testing purposes.
I don’t need something to do plots or anything like that. Just something that can test old cells, laptop pulls, etc. to verify that they’re still good. Or would a charger like the XTAR VP2 be good enough for what I need???
Pardon my ignorance. I was starting to get really frustrated from researching and studying and I know that you guys can help me out with what I need a lot easier than me figuring it out on my own and probably getting the wrong thing :bigsmile:
For testing cells, I would recommend the Turnigy Accucell-6 hobby charger. It doesn’t have USB port, so it can’t plot graphs on a computer, and it can’t do 4.35V, but it does everything else. It’s generally considered the best bang for your buck in inexpensive hobby chargers. I could be wrong, but I am not aware of a reasonably priced “hobby charger” that can handle 4.35V. Your best bet for that would probably be one of RMM’s Xtar 4.35V chargers.
Ok, so I’m down to the Opus, Tenergy TB6-B from Amazon, or the IMAX B6-AC from Hobby King. Need some help, guys. I feel like a tennis ball bouncing back and forth between all of these.
You’ve got your feet in two+ entirely different camps. IMO you’ve got to decide what you want to do. (The third charger you linked is not a “traditional” hobby charger in that it has a built in AC PSU. That almost makes it a black sheep - is the PSU good? Does it provide enough to run the unit full tilt?)
As far as I’m concerned the Opus is effectively 4 separate chargers in one box: you can tell it to do any function you want on any channel - simultaneously. The hobby chargers can only really do one cell at a time if you need to do different things to the cells. The hobby chargers are probably significantly more precise and can provide a higher charge current. Will the chargers you linked to do 4.35v charging? (I doubt it. You listed that as a requirement so…)
