Test/Review of Charger Xtar WP2h
12 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 days 16 hours ago
Charger Xtar WP2h
DSC_8039
DSC_8041 DSC_8040
This is the latest version of the WP2 charger. The other versions I have tested are WP2 II 2014, WP2s, WP2 II and WP2, most of them has been good chargers.
This charger has a few significant updates: It can do 3 currents and 3 voltages. This makes it suitable for many types of LiIon batteries. It can also be used as a usb power bank.
DSC_7986 DSC_7987 DSC_7988 DSC_7989
It comes in a cardboard box with a lot of specifications on.
DSC_8038
The box contains the charger, a power supply, a car adapter (This might be optional), a warranty card and a instruction sheet.
DSC_8042
The charger has a 12V input and a usb output.
DSC_8029 DSC_8043
The user interface is 6 leds, a button and a 3 position slide switch.
3 of the blue leds is used to show voltage and current selection, the last blue led is on when usb output is on.
The red/green leds show charger status: Red=Charging, Green=Not charging, flashing red=error.
The button is used to select current.
The slide switch is used to select voltage.
DSC_8046 DSC_8047
The slots uses the usual slider system and works fine, it can handle batteries from 31.8mm to 71.0mm.
supportedBatteryTypes
The sliding switch on the charger is used to select nominal voltage.
supportedBatterySizes DSC_8030 DSC_8031 DSC_8032
DSC_8033 DSC_8034 DSC_8035 DSC_8036
The charger can handle 71 mm long batteries, including flat top cells.
Measurements
  • When not connected to power it will drain about 4mA from a battery in channel #1 and 0.5mA in channel #2.
  • Selected voltage is shown flashing on blue leds when no battery is present and charger is powered.
  • When charging blue leds shows selected current with a steady light.
  • Changing current or voltage will always be displayed on the blue leds for a few seconds.
  • The charger will charge with 2.8mA from 0 volt and not report any battery (led is green).
  • From about 1 volt the charger will report error (Flashing red led), if the battery stays low in voltage.
  • From about 2 volt the led will change to a steady red and apply about 45mA (80mA in 1A mode).
  • At 2.9 volt regular charge current will be applied.
  • Charger always starts with the 0.25A setting.
  • When charge is finished the charger will charge with 0.4mA.
  • Charger will restart if voltage drops to 3.9 volt (3.6V & 3.8V mode).
  • Charger will restart if voltage drops to 3.3 volt (3.2V mode).
  • Charger will restart charging after power loss, or battery insertion.
Xtar%20WP2h%201A%20(PA18650-31)%20%231
The charger does a nice CC/CV charge with a 100mA termination current.
Xtar%20WP2h%200.5A%20(PA18650-31)%20%231
At 0.5A charge current the termination current is down to about 50mA.
Xtar%20WP2h%200.25A%20(PA18650-31)%20%231
At 0.25A charge current it is down to about 25mA, this is very nice and means the charger will work well when charging smaller cells.
Xtar%20WP2h%201A%20(BE18650-26)%20%231
Xtar%20WP2h%201A%20(PA18650-34)%20%231
No surprice with different capacity. My 2600mAh cell enters the CV phase a bit early, this is both because it a 2600mAh cell and because it is a bit old.
Xtar%20WP2h%201A%20(PA18650-31)%20%232
The second channels looks like the first.
Xtar%20WP2h%201A%20(AW16340-IMR)%20%231
My old 16350 is charged fine, even at 1A.
Xtar%20WP2h%200.25A%20(AW16340-IMR)%20%231
Reducing the current to 0.25A will fill a bit more enegy into the cell, due to the lower termination current.
Xtar%20WP2h%200.5A%20(AW18350-IMR)%20%231
Xtar%20WP2h%200.5A%20(KP14500-08)%20%231
The two mid sized batteries is charged fine with 0.5A.
Xtar%20WP2h%201A%20(2xPA18650-31)
Doing two batteries at once does not affect the charge speed.
Xtar%20WP2h%201A%2012V%20(2xPA18650-31)
The charger uses slightly below 1A on the 12V input when charging two batteries with 1A each.
Temp1408
M1: 38,6°C, M2: 38,2°C, M3: 47,5°C, HS1: 65,5°C
As usual chargers gets very hot inside, this charger keeps an acceptable temperature on the batteries.
Temp1409
M1: 38,6°C, M2: 37,8°C, M3: 47,0°C, HS1: 48,8°C
Startup
The charger needs about 8 seconds to reach 0.25A charge current.
Charge
Changing current will slowly ramp up to the selected current.
4.35 volt charging (Switch position 3.8V)
Xtar%20WP2h%201A%20(LG18650-30)%20%231
There is no surprise with 4.35 volt charging, it looks very fine.
LiFePO4 charging (Switch position 3.2V)
Xtar%20WP2h%201A%20(18650-LiFePO4)%20%231
LiFePO4 is also charged correctly.
USB output
  • Usb output only works from slot #1.
  • Press the button to turn on usb output when no power is connected to the charger.
  • Led shows green with fresh battery, red with partial discharged, flashing red when nearly fully discharged
  • When usb output is on and unloaded it will drain about 13mA from the battery.
  • Status led changes from green to read at 3.54V and start flashing at 3.18V
  • The status led is latching, i.e. battery must be removed to reset voltage status.
  • Output is not overload protected and will emit smoke at 2A load (Oops).
  • USB output is coded as Apple 1A
Xtar%20WP2h%20load%20sweep
The usb output from the charger is very stable, but not overload protected. Making the above curve did blow the charger.
I.e. do never use a "charge optimizer" on this usb output.
Xtar%20WP2h%20out%205ohm%20(PA18650-31)
Running at the rated 1A load the charger has very good efficiency and maintains the usb output voltage until the battery is empty.
Xtar%20WP2h%20out%2010ohm%20(PA18650-31)
Xtar%20WP2h%20out%2010ohm%20(BE18650-26)
Xtar%20WP2h%20out%2010ohm%20(PA18650-34)
Efficiency is even better at 0.5A load, the runtime will vary with the used battery.
5ohm
The noise is very low with 1A load: 5mV rms and 55mVpp.
10ohm
And about the same at 0.5A load: 5mV rms and 52mVpp.
Testing the supplied power supply with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
This is a very good universal LiIon charger, it can handle most types and sizes of LiIon batteries.
The usb output is also good, but I am missing an overload protection.
Notes
The charger was supplied by XTAR for a review.
Edited by: sb56637 on 06/25/2015 - 14:21
Calmaja
Last seen: 2 years 2 months ago
Thanks HKJ. Looks like a very good candidate as replacement for my SP2… if only they make another 2A current charge with same feature as this one.
Martini
Martini's picture
Nice review, thank you.
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
Desmo
Last seen: 10 months 6 days ago
So many chargers to choose from these days
wight
Thanks HKJ.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
hank
hank's picture
Last seen: 3 days 4 hours ago
I have a few 15270 cells — “800 mAh” — these are 3.0v “RCR2” size
I’ve been assuming they would be Ok at the low power charging setting.
But they’re ancient Trustfire brand, from long ago.
Any good advice on charging these with the WP2H?
HKJ
HKJ's picture
hank wrote:
I have a few 15270 cells -- "800 mAh" -- these are 3.0v "RCR2" size I've been assuming they would be Ok at the low power charging setting. But they're ancient Trustfire brand, from long ago. Any good advice on charging these with the WP2H?
Use the 3.2 volt setting and low current.
hank
hank's picture
Five months in, and the third blue LED on the WP2H has quit lighting up.
(It should light up to show selecting the 3.7v setting first; and then it should light up when the pushbutton is clicked to change to 1A charging)
No light at all from that LED. I wonder if this is just a failed LED, or if it indicates something else wrong with the charger.
Just curious and reporting in case it’s of interest.
I don’t expect to dig into the innards of this one myself because
— It’s within the Xtar 6-month “free repair, return to seller for service” warranty and
— fortunately I bought it from MtnElectronics, in the US as I am, so US postage to return it is reasonable.
hank
hank's picture
And I exchanged that for a new one, which worked a few times, now the second blue LED is intermittent.
It’s intermittent so far — it doesn’t light up only the first time I plug in the AC power
(not during the initial self test nor when the selector slide switch changes nor when the amperage button is clicked.
If I leave the charger on the AC connection after a little while that LED starts working and works consistently.
Another oddity is that the 4th blue LED — the one meant to indicate the USB battery output is working — doesn’t do that.
It does light up during self test, and it does light up very faintly intermittently at other times. Like it lights up faintly along with the first or third blue LEDs when 0.5A or 1.5A are selected. But it doesn’t light up faintly when the 2nd blue LED is (or should be) illuminated to show 1.0A.
Really weird. Still intermittent after a couple of days (this after a week or two of behaving properly).
I’ll keep using it to see if I get a hard failure, I guess.
I wonder if there’s any chance it’s more than the LEDs that are weird, could those indicate something wrong with the actual power sent to the battery when charging?
hank
hank's picture
Following up, after a year I continued to use the charger despite the odd behavior of the blue LEDs
Seems the only flakiness is with the LEDs lighting up.
The charging behavior has always matched the switch settings and the results have been as expected.
I’m wondering if anyone else has seen problems like that.
I’m about to buy another LiFePO4 charger for a relative and wondering whether to get another WP2H, a VP2, or I don’t know what else.
(from Xtardirect, both VP2 and WP2H cost the same $29 at present)
Any side-by-side comparison for chargers that will charge LiFePO4 cells? Pointer welcome.
(Xtar says
Quote:
The WP2H charger can be seen as a VP2 without the LCD screen. It shares all the common features and capabilities of our XTAR VP2 but at a fraction of the cost
So given they both cost the same at present, I guess I“m going with the VP2 next time.
So many choices, so little time ….
Swib
Hey Hank, Richard is selling the WP2H for $13 here if you’re interstested.
If you don’t like what it looks like on the wall, take it outside.
hank
hank's picture
Wow. That’s a stocking-stuffer holiday shopping price.
