Test/Review of Efest IMR18350 700mAh (Purple) BT 2014
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 7 hours ago
DSC_6792
Official specifications:
  • Weight: 28g
  • Length: 34.63mm
  • Diameter: 18.31 mm
  • Top: Nipple
  • Bottom: non-procted
  • Typical Capacity: 700mAh
  • Min capacity: 700mAh
  • Continuous Max. Discharging Current: 10.5A
  • Continuous Max. Charge Current: 2.15A
  • Cycle life: 300 times
  • Battery WH: 125WH\Kg
  • Discharge cut-off voltage: 3.0V
  • Voltage: 3.7V
  • Full Charge voltage: 4.2V
  • Temperature: dishcarge temperature range:-10°C—60°C, charge temperature range: 0°C—40°C
  • Storage: 1 year:-20°C—25°C, 3 months:-20°C—45°C, 1 month:-20°C—60°C
Efest%20IMR18350%20700mAh%20(Purple)%20BT%202014-info
A button top high current 18350 cell, being 18350 and high current means low capacity (exactly the specified capacity).
DSC_6791
DSC_6793 DSC_6794
DSC_6795
DSC_6796
Efest%20IMR18350%20700mAh%20(Purple)%20BT%202014-Capacity
The two cells is tracking fairly well and, as can be seen, deliver 10A. The voltage drop is significant at 10A, it is better to stay below 7A.
The flat top version is slightly better at high current.
Efest%20IMR18350%20700mAh%20(Purple)%20BT%202014-CapacityTimeHours
Efest%20IMR18350%20700mAh%20(Purple)%20BT%202014-Energy
Efest%20IMR18350%20700mAh%20(Purple)%20BT%202014-PowerLoadTime
Efest%20IMR18350%20700mAh%20(Purple)%20BT%202014-TripCurrent
Efest%20IMR18350%20700mAh%20(Purple)%20BT%202014-Charge
Conclusion
This cell has very impressive high current capability, but do not get it if you want a lot of capacity.
It looks like a good cell.
Notes and links
The batteries was supplied by Efest for review.
Comparison to other LiIon batteries
HKJ
HKJ's picture
Last review in 2014.
I have add 7A and 10A tracks in the small cell comparator, it was necessary due to the many high current cells. All cells that have been tested at these current are available in it.
nofearek9
nofearek9's picture
Last seen: 3 days 16 min ago
thanks ,great review as always.
