Test/Review of Efest IMR16340 550mAh (red) 2014
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 4 hours ago
DSC_6771
Official specifications:
  • Size: 16340.
  • Type: Li-Mn (High Drain)
  • Rated Capacity: 550mAh
  • Nominal Voltage: 3.7V
  • Peak Voltage: 4.2V
  • Cut-off Voltage: 3.0V
  • Dimensions: 16.41mm (Diameter) x 34mm (Length)
  • Rechargeable: Yes
  • Style: Flat Top
Efest%20IMR16340%20550mAh%20(red)%202014-info
This is a small high current battery.
DSC_6770
DSC_6772 DSC_6773
DSC_6774
DSC_6775
Efest%20IMR16340%20550mAh%20(red)%202014-Capacity
The battery works fine up to 2A, but above that the cells has problems.
Efest%20IMR16340%20550mAh%20(red)%202014-CapacityTimeHours
Efest%20IMR16340%20550mAh%20(red)%202014-Energy
Efest%20IMR16340%20550mAh%20(red)%202014-PowerLoadTime
Efest%20IMR16340%20550mAh%20(red)%202014-TripCurrent
Efest%20IMR16340%20550mAh%20(red)%202014-Charge
Conclusion
This is fairly standard performance for a good 16340 IMR cell
Notes and links
The batteries was supplied by Efest for review
Comparison to other LiIon batteries
Martini
Martini's picture
Last seen: 11 months 2 days ago
Thanks for the review.
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
sesgum
sesgum's picture
Last seen: 2 days 1 hour ago
Thanks for the great reviews!
Desmo
Last seen: 1 year 1 month ago
always appreciated
sixty545
Last seen: 3 months 4 days ago
0.70 Ohm must be a typo
HKJ
HKJ's picture
No, but it is because it is calculated between 6A and 7A where the curve drops and I always uses the worst value from the two tested batteries.
THE_dAY
Last seen: 8 hours 32 min ago
Thank you for the review.
The previous Efest IMR16340 you tested were version 2 and they seem to perform better at the 2A.
So these V.1 look like they have similar performance to the Kinoko IMR16340 according to your comparator.
Btw, love the comparator, so very useful!
