Test/Review of Eizfan IMR26650 3500mAh (Gold)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 11 min ago
DSC_8521
Official specifications:
  • Model No.: IMR 26650
  • Rated capacity: 3500mAh
  • Nominal voltage: 3.7V
  • Size: Diameter 26.13, height 65.56mm
  • Weight: 95g
  • Resistance: 23±2 mOhm
  • Temperature range: -20~+60 ºC
  • Monthly Self-discharge rate: Temperature range: Discharge: -20~+60 ºC, Charge: 0~45 ºC
  • Maximum discharging current: 35A
  • Maximum charging current: 6.5A
  • Maximum pulse discharging current: 65A
Eizfan%20IMR26650%203500mAh%20(Gold)-info
A high current 26650 battery according to specifications, as can be seen below that is not correct.
DSC_8520
DSC_8522 DSC_8523
DSC_8524
DSC_8526
DSC_8527
DSC_8646
When the test was finished and I removed the battery from my test station the plastic wrapper was damaged due to heat, as was my test station.
This means that the curves for the second battery may be a little bit off, due to the damaged test station as was my next few battery test, until I discovered the damage and fixed it and has started a retest of the affected batteries.
Eizfan%20IMR26650%203500mAh%20(Gold)-Capacity
Some of the differene at high current is probably due to the damaged test station, but the capacity difference in the 0.2A track cannot be from that.
The curves looks like the battery can deliver 30A, but obvious it gets to hot doing it.
Eizfan%20IMR26650%203500mAh%20(Gold)-CapacityTimeHours
Eizfan%20IMR26650%203500mAh%20(Gold)-Energy
Eizfan%20IMR26650%203500mAh%20(Gold)-PowerLoadTime
Eizfan%20IMR26650%203500mAh%20(Gold)-TripCurrent
Eizfan%20IMR26650%203500mAh%20(Gold)-Charge
Conclusion
The batteries has some capacity difference, this means that they must not be used in series and I would stay well below 30A when using them.
Notes and links
The batteries was supplied by Efan for review.
Compare to 18650 and other batteries
ryansoh3
ryansoh3's picture
Wow, the battery became hot enough to melt the wrapper and damage your test station? Shocked
BLF ≠ B-grade Flashlight Forum
HKJ
HKJ's picture
ryansoh3 wrote:
Wow, the battery became hot enough to melt the wrapper and damage your test station? :O
Yes.
I use this type of clamp to hold the batteries:
Some of the yellow plastic melted, making the connection a bit unstable, but not enough to make it obvious when I replaced batteries. The copper rods do transfer heat rather well.
It is, of course, easy enough to fix, I just need to tighten the copper rods.
