Test/Review of USB Desktop Charger 12A
Official specifications:
  • Support devices: iPad, iPhone, iPod, MP3 Players, Digital Cameras, PDAs, Mobile Phones (Samsung, HTC, LG, Nokia, Blackberry, Sony, Huawei),bluetooth headset,mini speaker and external power bank.
  • Input: 100-240V 50/60HZ
  • Output: USB*6 5V
  • Maximum output: 12A
I got this charger from ebay dealer: flashman852
I got this charger in a retail package.
Measurements
  • Standby power is 0.4W when on and 0W when off.
  • All outputs are in parallel.
  • Coding top row: USB charger (DCP), Apple 1A, Apple 2.1A
  • Coding bottowm row: USB charger (DCP), Apple 1A, Samsung Tablet
First test is on a single connector, it does not look like it has any individual protection.
Doing all connectors at once I can increase the current, but not up to the promised 12A, protection kicks in at 10A. It is less than specified, but more than I believe anybody will be using.
To be reasonable with the output loads I decided to test at 8A, if it stays cool I can always do another at a higher current.
The 8A load was handled fine, except it did not stay cool (See photos below).
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
M1: 84,0°C, M2: 77,4°C, HS1: 110,5°C
It looks like it can be used to keep coffe warm. It is the transformator that is really hot.
M1: 57,4°C, M2: 47,5°C, HS1: 84,3°C
M1: 69,9°C, M2: 69,7°C, HS1: 72,9°C
M1: 78,0°C, M2: 41,9°C, HS1: 80,0°C
With a 8A load the noise is 70mVrms and 2300mVpp.
The rms noise is acceptable, but the peak-peak noise is way to high.
Reducing the load to 2A the noise is 60mV rms and 3200mVpp, i.e. lower rms noise, but higher peak noise.
With 0.5A load the peak noise increases even more: 48mV rms and 3500mVpp
Tear down
This unit was fairly easy to open, I just had to remove 6 small screws.
It contains a big transformer for the many amps, the mains capacitor is also fairly large.
The input is protected with a fuse and a NTC.
Both the switcher transistor and two diodes on the low volt side have a heatsink.
The capacitors besides the transformer is marked 105°C, but when the transformer heats the outside of the box to 110°C, they are not going to last long.
On the bottom of the circuit board is the mains switcher IC.
Nice, it is a safety capacitor.
There is a fairly good distance between low volt side and mains, it looks like the shortest distance is between 4 and 5 mm, this is not enough, but fairly good.
But it is not enough to have a lot of distance on the circuit board, there must be distance between parts with mains voltage and parts on the low volt side everywhere. In air the distance must be 4mm, the two heat sinks are a bit too close and there is no protection agains hard bumps (They do go down to the circuit board and for that reason they need >6 mm distance).
The 5000 volt test did not fail due to this, but because voltage jumped from the mains heatsink to the transformer and then from the transformer to the low voltage diodes.
The charger passed 2500 volt test, but failed a isolation test with 5000 volt, this makes it doubtful to use with 230VAC mains.
Conclusion
This usb power supply can deliver a lot of current, but the power quality is very bad and it gets to hot. Missing individual protection on the outputs is also a problem, 10A in a single usb connector is not very good. It looks like the designer has learned something about isolation distances, but obvious not enough.
Due to the power quality and the safety I will not recommend it.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
Thanks for the review/warning. As you say, it might be useful as a coffee warmer. :wink:
I’ve got this one and so far it is the best of the ones I had/have with similar design: “TeckNet® 50W 5V/10A 6-Port USB”
http://www.amazon.de/TeckNet-Ladeadapter-Technologie-Smartphones-USB-ladefähige-Weiß/dp/B00LQTJ2SK/ref=cm_cr_pr_product_top
However, it is rather rare that I really can take advantage of the available power. I like the idea of universal ports which adjust to the kind of device connected.
Thanks for the review! The charger gets hotter than my Moccamaster (92-96 °C) and is therefore not suitable for making a good cup of coffee. There might be other reasons too. :wink:
HKJ thanks for the review. Have you thought about reviewing one of those very popular units by Anker 60W 6-Port with PowerIQ (universal ports) ? You can see how some fail quickly, some work well (of course depends what the user can tell works well, since the user can only see if work or doesn't work). I would appreciate a test done by you. The main issue is that in the end that I am sure such device must have several revisions on the market, probably even parts that are changed based on stock and in the end a good conclusion or even a bad one may not apply across all the units that are sold.
searching that on Amazon finds a dozen similar-looking boxes under various different names, from $60 to $18
No telling what the hell is inside any of them, or even who’s responsible for them.
Some sold by Amazon, some sold through Amazon, and some are “sponsored” ads placed ON the Amazon page for similar things.
I have ordered one.
Just know I am writing about a usb charger where they have removed half the parts from the circuit board (The text with the part symbol and name is still present).
With all parts present it might have been a good charger.
Thanks for the review. To avoid at all costs!
HKJ any news on reviewing the xtar eneloops/lion VC4 charger? Would be great to have a review on it. Alternatively, what good xtar charger would you recommend that is not too expensive to charge lion cells? 2 bays is fine!
The VC4 review will be published tomorrow.
VC2 is a good candidate for only 4.2 volt charging.
Wow Thanks! Im really looking forward to VC4 review… I was looking reading your review on the VP2. I seems a better charger and can handle 4.3V. But I am waiting on your review first before I commit myself! Maybe the VC4 will be awesome! Thanks again man.
VC2 is at $21. Good price.
VP2 looks expensive …damn it.
VP2 can do a lot more than VC2 with 3 charge current and 3 charge voltages.
That is great HKJ!
