Ok, this year i went all thru the flashlight thing, spent few hundreds euros in stuff and appareils
I’have a Courui D01, which i thought needed an improvement. So i bought a 2in1 soldering/reflow hot air station and went for few basics steps
Changed the tail cable with a 14AWG silicone from a famous R/C site. Good, didn’t see any improvement, but seemed obvious to me, since the emitter cables where still untouched.
So the plan was, change the emitter cables, and than stack a R120 in parallel over his sense resistor which i bought at Fastech on pourpose…maybe do a wire bypass instead, i’ll decide later, i thought
well I’ve the manual skills of a dead opussum, anyway…never you try, never you learn…
so i went for the emitter cable swap 14AWG was pretty thick to handle, anyway led lit for a while, few seconds, not very steadly.
but since i was holding things with my hand i don’t know what happen precisely, but at certain point i stopped holding it, but the light won’t turn on again (the led was free and the flashlight not re assembled…just in case someone thought of a short caused by the reflector)
i double checked if some solder touched something it shouldn’t and wasn’t able to see anything. also the star had the + contact eradicated by the bending cable…i thought nevermind i’ll scratch some mm^2 of the covered trace and solder there instead that using the missing pad
Later i checked with the continuity test on the dmm and on the star and also on the pin of the led soldered onto the star, and i got continuity, meaning the led is somewhat shorted…WTH? i didn’t even still mod the sense resistor……
ok I had a terrible zoomie 2S cells called T5 or T6 something i could do more tests.
but before that i would like to see if i can improve that, stacking a resistor over a suspected R200 should do something magic i thought, hum….
well my SMD resistors are bigger than that so I’ve tried with a simple solder bypass, but what i got is getting the light always in moon mode, well, i have modes, steady lightining, SOS, blinky, yeah, but they are all in moon mode!
I must have touched something right? so i started to try cleaning everything seemed to go outside his pads…maybe some solder is in contact with the outer ring (GND) well, i even used a cutter to scratch solder away, but still don’t know if something is compromised or is just some sort of short
I’ve tried to let the tin flow itself gainst the proper pads, using a hot air gun, but what i got is just a whole mess, i think I’ve moved an unknown R270, the original R200 and a white thing that could be a cap.
Well i think i’ve finally managed to place again things in their places, with the hot air gun again, placed with tweezers and then melted the whole place hoping that they will position themselves (and so it seems) I also placed one of my R120 instead of the original R200, but still I got moon mode only.
Lately I tried the second led in the Courui driver and got nothing :_(
For some minutes my delusion was so big i barely managed to not kick the whole pieces out of the window
Now my room is a mess, full of cables, and pieces, drops of solder everywhere, pills, reflector, batteries, soldering gun,tin, boxes ahhhhhhhhh and i got nothing…
should i give up….yes i should….for today….
